Question about Miele (T1339CI)
How can I fix my Miele Novotronic W853 ? All of a sudden my Miele Novotronic W853 will not spin. It fills with some water and does not complete the program properly as no drum movement takes place.Also it stops and the RINSES light keeps flashing I have cleaned out the filter and that was clear can anyone help? It will also pump out water
  • sean_lott May 31, 2010
    If you try and start a program it seems at first like it is working but then it stops and does not continue with the program. It just shows a flashing rinses light and then stops .
    President:
  • 1,554 Answers
The problem is commonly found in the control board due to a blown fuse. The fuse blows when a short circuit occurs in the motor windings or in the polarity switching relay control board. Check the motor windings for short circuits and the relay on the control board. Replace the motor if a short circuit in found in the windings.
The polarity switching relay on the control board and the radial fuse need to be removed and replaced to address the issue if the relay has indeed shorted out. But you need a desoldering station to do it or else you will damage the board if you use a soldering iron.
Check the motor brushes for any sign of wear if no short circuit is found in the motor windings and the control board or if the fuse is still intact.
Posted on May 31, 2010
    President:
  • 2,468 Answers
If it doesn't fill to the proper level then i would suspect a defective water level switch on the control panel as this is what starts the cycle when the amount of water has reached the level you selected,also make sure the fill tube going from the lower tub to the water fill control is not kinked or obstructed as it uses atmospheric air pressure to control water fill
Miele 500 washing machine inlet light comes on and machine wont pump water out or spin
try leaning against door when pressing start . if it runs get the switch replaced
Jan 24, 2016 | Miele Novotronic Premier 500 Front Load...
Miele Novotronic 500, 10 years old, noisy filling, no error light, inlet filters clean. Any suggestions please?
Hi dear,
As I know it's a indication on inlet valves going to fail. I hope that helps. Thanks.
Jan 21, 2016 | Miele Washing Machines
Miele Novotronic w963 motor does not turn after water filling
Hello, my question is, I have washing machine MIELE NOVOTRONIC W 963, is broken, Which Miele model HAVE SIMILAR MOTOR ,thank you . William
Jan 03, 2013 | Miele Novotronic W1918A Front Load Washer
Washing Machine on the blink mainly due to no spin/drain cycle wo
check your drain filter, get a wet vac and vacuum the water out, then open the drain plug at bottom and try to vacuum the drain to clear out debris......then turn on and test washer if it fills and drains if it fills with water and doesn't drain then your drain pump is defective........get your model number and source for a pump motor.................................
if it doesn't fill with water then your water fill switch is defective...............source for parts..............
if this helps out anyone a feed back would be good..........
Apr 16, 2010 | Miele Novotronic W1918A Front Load Washer
My Miele Novotronic W 844 Washing Machine will not completely spin dry my clothes. They are soggy at the end of the wash cycle. Help please! (My machine's settings are in German.)
Hi there are 3 possible causes.
1. Out of balance load (drum is divide into 3 sections if weight i one section is greater then 1.25kg than another section will not spin)
2.Carbon brushes ( Normally good for at least 10 years)
3. Vent from drain pump blocked.(Vent left front side of soap drawer. Visible when drawer removed)
Mar 19, 2010 | Miele Novotronic W1918A Front Load Washer
Hi, i have a miele novotronic w 916 and it's not spinning
I mean this is not a filter error and i think the power main board inside on front bottom EL110 has an defekt and must change.
Or you can post the problem on my board www.avpc.de with photos for solving together and find another cheap used power board for it ...
Aug 21, 2009 | Miele Novotronic Premier 500 Front Load...
Miele (T1339CI) Logo
258 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
