Question about EliteGroup 661FX-M7 (661FXM7V11) Motherboard
I just received an Elitegroup motherboard from a friend and i would like to use it for a computer i want to build but i'm not really sure what model number it is or anything. So how do I tell what type of Ram it uses?
  • 670 Answers
I just did a complete new build of a computer using the Elitegroup ECS A885GM-A2 board. It powers on, shows an LED on the board, but does not beep and there is no display whatsoever. All the fans ar
usually this means that the board is powered on, but that the cpu hasn't been initialized. make sure your cpu pins are clean of thermal grease and that it is properly seated. make sure your board is compatible with the cpu and if you can get a spare (known good) cpu to boot the board with, see if it starts, and see if you can update the bios.
again, basically the issue is CPU related. at some point you may have to just RMA the processor since it is a possibility that it might be DOA. good luck!
Feb 17, 2012 | EliteGroup ECS A885GM-A2 (V1.1) AM3 AMD...
Ok, so my computer is a home build system with the EliteGroup ECS 945GCT-M/1333 Motherboard - v3.0. i was using windows xp for a long time and every thing worked correctly but i recantly upgraded to...
control panel admistrive tools,computer management,device manager scroll down sound and video controllers you should see a yellow question mark? right click to reinstall drivers you might find something there hope this helps
Sep 15, 2010 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
I have a Logitech web cam from a friend when I connect to my computer it says device driver installing but thats as far as it goes. What do I need or what can I do?
Locate the model of web cam, go to this site:
http://www.logitech.com/index.cfm/support_downloads/&cl=us,en
Input your model number and download and install the driver for the web cam. This is what your device manager is looking for.
Nov 05, 2009 | EliteGroup P4VMM2 Motherboard
Sistem build on ecs p4m800pro-m motherboard shut down every time
I had the same problem, make sure the connector is plugged in the right way, use USB0 as the manual shows, check the front PCB make sure it's not shorting out at all.
I had the connector backwards.
Mar 24, 2009 | EliteGroup P4M800PRO-M2 (V2.0) Motherboard
Display problem
GO into the BIOS setup routine and make sure that the "onboard video" if it has any ,is set to off. Malke sure that ou have the monitor attached to the video card and not the :onboard: one. Did you install the softweare and driver for the video card?
To receive further help, please  give us the make and model of the video card. Thanks
Jan 19, 2009 | EliteGroup K7AMA Motherboard
Dr. offoce in Anza CA, bought a desktop computer for his office and the O.S. is Vista, changing the system to XP Pro, need drivers for his emachine s/n 82300811290,T5274 for his, motherboard,modem,sound...
eMachines only released this model for Vista so the only drivers they have on their site is for Vista.
A little research revealed that they used the ECS (Elitegroup) 945GCT-M3 motherboard to build this system. Elitegroup has XP drivers for this board and you can download them here:
http://www.ecsusa.com/ECSWebSite/Products/ProductsDetail.aspx?detailid=719&CategoryID=1&DetailName=Driver&MenuID=44&LanID=9
Oct 11, 2008 | Computers & Internet
Motherboard
Well you really need to get a manual for that. Check the website and download the manual with that model, for sure there is one.
I guess you have connected all the connectors there incorrectly so better look for a manual.
Dec 09, 2007 | EliteGroup ECS 755-A2 Motherboard
No post beep, no video
had a similar problem with a box i built. Your power supply has two connectors. One long one and a 4 pin connector. Make sure that four pin connector is connected.
Oct 25, 2007 | EliteGroup (ECS 915PL-A2) Motherboard
EliteGroup 661FX-M7 (661FXM7V11) Motherboard Logo
98 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
