Question about Texas Instruments TI-83 Plus Calculator
For all graphs from the y = screen i get invalid
For all graphs from the y = screen i get an error saying invalid dim
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
You're probably trying to graph a function that does not involve stat plot features. You can correct this by turning off the stat plot features. Press "2ND" "STAT PLOT" and then select 4:PlotsOff.
If this doesn't do it, add a comment here and we'll go on from there.
Posted on Jun 01, 2010
When I try to graph it says-ERR:INVALID DIM 1:QUIT
Nov 01, 2013 | Texas Instruments TI-83 Plus Calculator
So on my graphing calculator i put my equation x^3-x^2-10x-8. then i hit graph and it says err:invalid DIM.
INVALID DIM error message may occur if you are trying to graph a function that does not involve the stat plot features. The error can be corrected by turning off the stat plots. To turn the stat plots off, press 2nd then stat plot, and then select 4:PlotsOff. By the way it is easy to graphing function y=x^3-x^2-10x-8.
See captured images: full graph and detail of the left side max
As you can see this function have zero values in the points -2, -1 and 4
Mar 04, 2012 | Texas Instruments TI-84 Plus Silver...
Error message invalid dimensions
y , and then select 4:PlotsOff.
Jan 19, 2012 | Texas Instruments TI-84 Plus Silver...
Every time I try to graph on TI 84 it says ERR: INVALID DIM 1:QUIT I have enterered something simple y= x+2 and window is set for -10<x<10 and -10<y<10 the curser in y=...
Go to http://education.ti.com/downloads/guidebooks/graphing/84p/TI84Plus_guidebook_EN.pdf to download the manual. On page 401, you will find the following:
INVALID DIM • The ERR:INVALID DIM error message may occur if you are trying to graph a function that does not involve the stat plot features. The error can be corrected by turning off the stat plots. To turn the stat plots off, press y , and then select 4:PlotsOff. • You specified a list dimension as something other than an integer between 1 and 999. • You specified a matrix dimension as something other than an integer between 1 and 99. • You attempted to invert a matrix that is not square.
Nov 11, 2010 | Texas Instruments TI-84 Plus Calculator
Everytime i try to graph i get an error saying invalid dim on my TI-84 plus calculator
May 19, 2010 | Texas Instruments TI-84 Plus Calculator
Graphing Feature error message
This usually happens after the statistical graphs have been used. You should deactivate them. Press [2nd][Y=] (STAT PLOT). Select [4:PlotsOff] [ENTER]. Calculator echoes Done on main screen.
Restart your graphs.
Dec 28, 2009 | Texas Instruments TI-83 Plus Calculator
Error invalid dim
Reset memory to default, the error will disappear.
[2nd][MEM][7][2][2] Defaults set.
Hope it helps
Sep 06, 2009 | Texas Instruments TI-83 Plus Calculator
Graph and trace buttons don't work
This is probably because you have the stat plot on. You would need to go to y= and then go to the top where it says stat plot 1 and un highlight it if it is highligted. That should fix your problem.
Sep 16, 2008 | Texas Instruments TI-84 Plus Silver...
When trying to use the graph functions get error:Invalid dim
Look at the Y= screen. If If Plot 1, or more, is On (dark) along the top, you have to turn it off. Select STAT PLOT, (2nd Y=), then 4, (Plots Off), then Enter. Your screen should say Plots Off Done. Graph should now work.
Jun 28, 2008 | Texas Instruments TI-83 Plus Calculator
Invalid DIM
Just passing by, make sure you aren't zoomed in or panned away from the axis when you look. Check to see if there is some way you could be referencing a matrix. I can pull up a similar error by trying to pull a value out of a non-existant slot. I got my first TI 2 days ago, so I probably don't know as much as you.
Aug 20, 2007 | Texas Instruments TI-84 Plus Calculator
Texas Instruments TI-83 Plus Calculator Logo
125 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
