Question about Epson Stylus CX6600 All-In-One InkJet Printer
Epson C62 It claims parts now need replacing and has stopped working!
  • Gerry Millward
    Gerry Millward May 11, 2010
    It's a long time now without any help forthcoming on this problem. Can
    you post a new comment updating the situation, so that I can try and
    help you fix it, or close it as solved!
  • 353 Answers
This is probably that the waste ink pads need replacing. If you still have this problem and need help with it, please post a new comment to this effect.
Posted on Feb 28, 2009
SOURCE:
Plastic part that holds down black inkjet Epson Stylus C62
yes it is possible however cheaper to replace the whole printer
Oct 30, 2009 | Epson Stylus C62 InkJet Printer
Epson c62 Parts inside your printer are at the end of their service life. Contact your dealer for replacement.
Use this link, covers what software and tricks
http://tricks-collections.com/reset-epson-stylus-color-printers/
goodluck
Oct 09, 2009 | Epson Stylus C62 InkJet Printer
Refuses to print with red light constantly flashing.
well sir this kind of indication TENDS to pertain on the ink pad that needs to be replaced. for you to extensively use the product, download an ink pad reset utility on the epson website. it should give you all of the information you need. www.epson.com/ipr is the site.
Sep 23, 2009 | Epson Stylus C62 InkJet Printer
Epson c62 printer say's parts need replacing, service required
These symptoms usually mean the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. You can restore your printer to a working condition immediately by using the SSC utility - download from:
http://www.ssclg.com/epsone.shtml
Install it, and double click the ssc printer icon in the bottom right corner (System Tray). Choose Configuration and set your printer type (C62), then close the ssc window. Now right click the ssc icon in the sytem tray and choose Protection Counter. Check the current count value - if it is greater than the limit shown it will confirm this is your problem. Then choose reset to set it to zero. You will need to fib about having changed the waste ink pads! Turn the printer off then back on again. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help. It is a pretty simple job once someone explains how to get the case apart!
If this solution helps you, please rate it; if it doesn't, please provide further information by posting a new comment.
Feb 15, 2009 | Epson Stylus C62 InkJet Printer
Epson c62 color ink cartridge says it is empty when i just refill
I use cheap replacement cartridges about 20$ for 3 color/5 black....the printer usually doesnt recognize the cartridges ink level but it still prints......do you use actual epson replacements? If you use cheaper replacements you might have gotten some with dud chips...prob the cartridges fault, not your printer
Jan 01, 2009 | Epson Stylus C62 InkJet Printer
Epson Stylus C62 Error Red light wont go off
Hi victorarcas
If both lights are flashing, it means the Waste Ink Pads in your printer are saturated with ink and the waste ink ("protection") counter has exceeded its limit. The Waste Ink Pads should be replaced (see later). You can overcome this problem temporarily by using the SSC utility - download from
and reset the Protection Counter. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer. A copy of the service manual is available from a number of sellers - just Google "Epson C62 Service Manual". You will often find them for sale very cheaply on E-Bay.
Please rate this solution if it has helped you
Dec 22, 2008 | Epson Stylus C62 InkJet Printer
Printer instilation
you have to download the drivers from the epson website then you can install
Apr 05, 2008 | Epson Stylus C62 InkJet Printer
Epson Stylus Photo R220 InkJet Problem
This is probably due to the waste ink pads needing replacement. If you still have this problem and would like help solving it, please post a new comment to this effect.
Mar 19, 2008 | Epson Stylus C62 InkJet Printer
Epson C62
when u go to --> control panel --> print preferences and maintenance
does it say low ink ? or cartridge unfilled?
Feb 27, 2008 | Epson Stylus C46 InkJet Printer
Epson Stylus CX6600 All-In-One InkJet Printer Logo
93 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
