Question about Welding Tools
I just got a second hand cebora stag 196 and it not working right. First I took out the PCB and changed relay after testing it. So I then put it back and turned it on but it only clicks when handle press but wire won't feed through can sum one help I like to get it working thanks
2 Suggested Answers
duane_wong
  • 6826 Answers
SOURCE: Can I convert my Cebora Stag 196 welder from gas
Most gas welders double as gasless welders. Just buy the flux core wire and use it without the gas on.
Posted on Jul 07, 2010
How do I fix the horn on 2006 Impala
System Description
The horn PCB relay is non replaceable ,soldered to the underhood fuse / relay box. . You would have to take the box a part to get at it . Is the air bag light lit on the instrument cluster ? Could have an open wire in the Clock spring , do you know what a clock spring is ? It is inside the upper part of the steering column , It allows the steering wheel to be turned full right to full left keeping the horn an all the buttons an air bag connected electrically. When the horn button is pressed, ground is applied through the horn switch contacts and the horn relay control circuit to the coil side of the relay. The horn relay coil is then energized, causing the relay switch contacts to close applying voltage through the horn control circuit to the horns. For theft deterrent functions, the body control module (BCM) also controls the horn relay by applying ground to the relay control circuit to the relay.
Circuit/System Testing
With a test lamp connected to ground, probe each of the test points on the HORN fuse while activating the horns. The test lamp should illuminate at one or both of the fuse test points.
If the test lamp does not illuminate at either test point, refer to the Horn Switch Test.
If the test lamp illuminates, refer to the Horn Test.
Ignition OFF, disconnect the inline harness connector C275. Ignition ON, test for B+ between the horn relay control circuit terminal B and ground.
If less than B+, test the control circuit for an open/high resistance. If the circuit tests normal, replace the underhood fuse block.
Momentarily connect a 3-A fused jumper wire between the control circuit terminal B and ground. The horns should work.
If the horns do not work, replace the underhood fuse block.
If all circuits test normal, test or replace the horn switch
The PCB relay horn system consists of the following components:
Horn switch
Horn PCB relay
Horn assembly
Body control module (BCM)
HORN fuse 15 A
How cars clock spring works
May 17, 2016 | 2006 Chevrolet Impala
How do for error E 196 -404 C
Serial number information mismatch
A mismatch has been detected between the
serial number information stored in the
EEPROM on the main PCB and that stored
in the EEPROM on the MTC relay PCB at
startup.
for more information email: rezaravandi@gmail.com
Sep 30, 2014 | Canon imagePROGRAF IPF600 - large-format...
My Google is displaying in Turkish. I found a page that I might use to change it back to English but I am not sure what to check!
Hi Next to the blank field on the right hand side, you would see 2 options. One of them is Dil Araçlar?± . Click on it and a new page will apear that will contain a set of global languages. Find ?°ngilizce and click on it. Your google will start talking in English. All the Best !! :-)
Nov 10, 2010 | Computers & Internet
Lost instructions for building 6 man white stag tent how do poles go up
I have a second hand white stag tent whith the tent # 28242 white stag six man tent. I need set up instructions and my be missing some pole for set up
Sep 01, 2010 | Rock & Ice Climbing
How to install zanussi dx6452 heating element
disconnect from electric and water supply. remove drain screen from inside dw , mopp up residual water. remove front feet and plinth cover, and right hand side panel. with machine on its back remove rear foot adjustment shaft.and base cover. disconnect wiring to tube enclosed heater. remove hoses very long nosed pliers help to get clips off/on. extract to righthand side. not much space to work here assemble in reverse. good luck
Jul 21, 2010 | Zanussi Dishwashers
Can I convert my Cebora Stag 196 welder from gas to gasless
Jul 07, 2010 | Welding Tools
Have a 1997 chrysler intrepid ...there isno power to fuel pump
you might check the fuse for the fuel pump and the fel pump relay...either could be blown
Feb 01, 2009 | 1995 Dodge Intrepid
Wife's hen party = camera disaster
okay...YOU DROPPED IN THE TOILET! WATER+ELECTRONICS=NOT GOOD!! duh! *smart one.
Apr 07, 2007 | Nikon COOLPIX L3 Digital Camera
Welding Tools Logo
118 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
