Technika 26'' lcd tv long time to warm up
My technika 26'' lcd tv takes ages to warm up, it takes longer than an old valve set,
20 minutes, but once on its a lovely picture and no problems until it is switched off and then switched back on again then have to wait another twenty or so minutes,
whats wrong with it,i cant see any dry joints or loose wires,
its about two years old now,
thanks for any help given
    Scholar:
  • 75 Answers
The reason maybe a bad capacitor that is taking time to charge up to the nominal voltage. check for capacitors (electrolytic) in the power section (probably smps). it may appear bulgy than the others.
Posted on May 31, 2010
Testimonial: "thanks for reply, have checked capacitors but cannot find any that are bulging or leaking, but will check futher. many thanks, rick."
Technika troubleshooting how can I go about fixing pink lines on my technka television, The lines are constant and then the full picture begins to go light pink and becomes impossible to use?
I doubt you will be able to fix that problem yourself since its a modulation out of sync in a device which I'm familiar with, but I forgot the technical name. Usually all TV's will sooner or later have that problem with age. It's good money down the drain, because once a TV has picture problem of such it inherently causes other problems. The device is made of many adjustable rheostats which takes time tuning (color mixtures).
You'll never get it back to factory specs. Best to forget about it and buy a new TV, a word from someone who's gone through the hassle more than once. Besides if your TV is more than 10 years old, the part will no longer be stocked or available.
May 10, 2014 | Televison & Video
Technika 26" tv - lcd26-229
you should be able to do a code search for the universal remote.. once that is done the two should be linked.. if not you need to use the buttons on the tv itself..
Jan 21, 2014 | Televison & Video
Can a 20 year old date a 14 or 15 year old
5 - 6 years difference is ok, once both parties are about 26 and 21. But a 20 year old dating a 14 year old is not to cool. Ether way, older boy or girl, there is a since that the older one can't communicate on their own level. If the younger of the two is far more mature for their age they will miss things that happen when dating a person of their own age. The mom and dad of the younger of the couple will loose some control; being the older one will feel as they can handle things on an adult level. It will be hard to set boundaries that the older one will stick with, but the younger should live by. Such as in by a set time, homework, projects for school. The older of the couple will push for their time "alone" which will take from the younger of the two tending to their duties. Sorry, put your foot down and save a lot of drama in your future, just say "NO, NO, NO".
Aug 30, 2011 | Tatung CLT-L50 15" Flat Panel LCD Monitor
42" LCD TV leaves marks on screen following using
This is a defective LCD display panel. It will cost as much as a new set unless your still within the 1 year warranty. As far as cleaning the screen, you can use an old t-shirt by spraying a little windex on the shirt and wiping gently up and down or left to right but never in a circular pattern. I found it best to do this after the set has been on for 15 minutes to warm up the surface then shut the set off and give a clean.
Nov 27, 2010 | Televison & Video
The remote control for our Technika lcd 26-207 doesn't work.
Sounds like maybe the remote receiver on the tv itself has gone faulty if a replacement remote doesn't work.
email me on markiexxxx (at) gmail (dot) com
for more info...
Sep 29, 2009 | Televison & Video
Blurred picture, after some warm-up it back to clear picture
If the problem doesn't return after the picture becomes normal, then it could just be due to the electron gun taking longer to fire up. I don't know how old your TV is, but TVs older than ten years typically take longer to warm up than more modern sets.
Jun 02, 2009 | Sharp LC-19SB25U 19 in. LCD HDTV
Extremely long warm up time 25 minutes. ok once it comes on.
Just a shot in the dark- I think your main projection lamp is going bad- If the set is more than a year or 2 old it can happen. Unfortunately they are a little expensive.
How is the brightness level after it warms up??
May 30, 2009 | Audiovox FPE2706 27 in. LCD Television
Dell 17" LCD TV takes a long time to come on 15 minutes or more
popping noise is an indicatior of a bd board. if the unit power light still lights amber, it probably the main board else the power board a circuit or two may have been fried. both boards need to be examined. questions, email me
Feb 05, 2009 | Dell W1700 17 in. HD-Ready LCD Television
Need code for technika tv
i have bought a one for all tv controller and it doesn't have the code for a technika tv
Jun 21, 2008 | One For All URC 7740 Remote Control
Televison & Video Logo
590 people viewed this question
Top Televison & Video Experts
Electro Med Services...
