The cooling of my new window unit of samsung Ac was poor. The Model No is AW098KB
  • 43,501 Answers
Here is a tip about trouble shooting your air conditioner...
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on May 31, 2010
Frigidaire AC window unit, model fam185r2a (18,500 BTU) only cools for a few minutes before it cycles off and just fan blows. Then a few min later cool air cycles back on. Is this a thermostat issue?
The window units normally have a sensor thats attached to the front of the indoor coil. This controls the thermostat. I usually pull this sensor away from the coil because it stops cooling before the room is cool. It is attached to the cold coil so it senses the coil temp, not the room temp. You can normally see it when you remove the air filter. Don't break it! It may be a wire or small copper tube
Jun 10, 2015 | Frigidaire Heating & Cooling
Previous tenant left ac window unit Haier HWF05XC5, but took the remote. Can I manually turn on this ac unit? when turning the power button, only the fan turns on, I'm unable to switch to AC
According to the Model Number you listed, it's a Mechanically or Manually Controlled AC unit. There is no remote control for it.Please be certain the Model Number you listed is correct and get back to me.
If it's the correct model number and it's manually controlled. You should have 2 rocker switches. One is to turn the power ON & Off. The other is to set the Fan Speed either on Low or High. Then there is a dial, numbered 1 to 10 to set the cooling level. 1 is min cool and 10 is Max Cool.
If the controls on your unit match what I described above, it's a manually controlled unit. No remote.
I hope this helped you. Please advise. Thanks.
Jul 11, 2011 | Heating & Cooling
I have purchased one Samsung Split 1.5 ton AC from Vijay Sales ? Baner Road branch on 19th Sept 2010 by paying cash payment. The same ac was delivered to me on 21st Sept 2010. The Samsung Authorised...
You have a LEAK from installation that must be found & repaired before any more GAS is added to the system.Then it will normaly need a little gas every 3 years.
Sep 29, 2010 | Samsung Heating & Cooling
My LWHD1200FR AC Unit is not cooling during the
The unit may not be big enough. From the model number I am thinking you a/c is a 12000 btu. Which is usally enough for a large room. However if you have an open floor plan or a really large room you may need a bigger or second unit.
Jul 05, 2009 | LG LWHD1200FR Wall/Window Air Conditioner
I have a LG window AC Model LWHD8008R. Won't power up?
Replace reset switch or bypass it to make sure it is the problem. Check for low voltage while the unit is on. Shoud stay above 105 vac
Jun 28, 2009 | LG Heat cool Window Air Conditioner
Cooling problem with my ac.
The start capacitor may be the problem. Is your AC a central unit or window unit? Whats the model and make? If a window unit it could also be the thermostat is defective or too close to evaporator fins. Dirt on the condenser outside can cause the motor to heat up to the point it shuts down to cool the internal overload. Let me Know, Sea Breeze
May 18, 2009 | Carrier Heating & Cooling
Hello, I have a Kenmore 580.75124500 ac/heater
It is probably the compressor. You will need to check if the compressor is being called to come on. Do you hear the compressor running? If you do, I would remove the unit from the wall or window, and wash it down real good with a hose being careful not to get the electronics wet. If not and the unit sound different than it did before, it's probably time to buy a new one.
Mar 31, 2009 | Frigidaire FAC125P1A Window Air...
Ac compressor not working
This unit is a 220 volt ac unit. 12-2 wiring is usually for 120 violt circuits?
  • Amps: 22.2 / 20.0
  • Watts (Heat): 4900 / 4000
  • Watts (Cool): 1650 / 1625
  • Amps (Cool): 7.7 / 8.3
  • Voltage Rating: 230V / 208V 60Hz
  • Power Cord Length: 5' (6')
  • Horsepower (Cool): 2.49
  • Plug Type: LCDI 6-30P
  • http://www.frigidaire.com/Home-Comfort/Air-Conditioning/Window-Mounted-AC/FFRH1822R2
    hope this helps?
    Jun 05, 2017 | Frigidaire Heating & Cooling
    Samsung window air conditioner model aw05ncm7 icing up not cooling
    After I opened the front of the unit and discovered it full of ice, I left the unit off until it defrosted, so to speak, after the ice had melted, I turned the unit back on to see what happened. It is working fine now, I'm not sure why it iced up, if this is normal or not, but after it melted the problem was solved.
    Jul 22, 2008 | Heating & Cooling
    Heating & Cooling Logo
    Top Heating & Cooling Experts
    Paul Carew
    Dan Webster
    Dan Webster
    Tim Whalen
