Question about LG WFT1071TP Top Load Washer
Machine cames on for 3 seconds and cut of with two littel stripes
IT GIVES ME TWO LITTEL STRIPES ON THE PANEL THE SAME USE TO HAPPEN WHEN THE LID WAS NOT CLOSED.
WHERE IS THE SWITCH SITUATED FOR THE LID
THANK YOU
PAUL
  • 159 Answers
Hi paul.The lid switch is normally located inside the control box.the lid has an arm witch activates a lever when the lid is closed.Sometimes the the lever on the lid switch doesn't quite make electrical contact.you can open the control box,you may have to remove the lid first.Unplugged of course.when the lid & control box are removed you can examine inside the control box area,there you should find the lever attached to the lid switch.it should lift up & down & make 2 copper coloured metal contacts touch together.sometimes they need a little bending together to make them touch when the lid is closed.Hope that helps.
Posted on May 31, 2010
Focus 2004 oil change procedure
Step 1:
reales tap at the bottom of the olie tank (the only tap vissabel on the bottom of the car)
Step 2:
the oil wil now flow out wait to its only a littel stream
Step 3:
take off filter (littel ruond from the motor block)
Step 4:
out in new filter and fill ind new oil
Step 5:
remove air filter and put in new one
finish
Jan 24, 2013 | 2000 Ford Focus
Need to remove lid on cystern
Hi im Rossouw
It depends on the kind of cystern u have. here is a few i know how to remove
1.The 2 button setting on top of cestern needs to be turned left untill it loosens up
2.The 2 screws at back of cystern lid needs to be unscrewd
3.also a 2 button cystern. has metel cabel under lid. can lift lid a littel. thast pull hard on cabel were it enters the 2 flush button meganisem
If not 1 of the above plz let me know and i will help u therder, dose are the most commen problem 1ns
plz vote 4 my advice thx
Jul 17, 2010 | Villeroy & Boch 98M2 S1 01 Bellevue Toilet...
I have 3 black stripes on my Zenith 42
Turn off the TV then unplug it. Disconnect the cable connection and clean the terminals. If the stripes still exist, you have a bad TCP (tape carrier package). It is responsible in transmitting color information to the display panel from the X-Drive (A-Bus) Board. This is not an easy repair. Service of an experienced or a qualified technician is recommended.
Nov 27, 2009 | Zenith P42W34P 42 in. EDTV-Ready Plasma...
Switch on. Picture OK for 3-4 seconds then vertical stripes only
IT NEEDS SERVICING, THROUGH THE CERTAIN HEAT ON THE VERTICAL IC, THERE HAS BEEN DRY JOINTS ..RESOLDER IT, FOR BEST RESULTS TRY TO RESOLDER THE OTHER HEATED PARTS..IT WILL WORK
Oct 13, 2009 | Televison & Video
Jaguar xj6 1996 engin is not working good
I'm not quite sure what you're describing.....A good tune-up wouldn't hurt'
May 21, 2009 | 1995 Jaguar XJ6
LG WFT1071TP Top Load Washer Logo
99 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
