Question about Parks Optical 13.5hp Briggs And Stratton Intek Lawn Mower Engine
Lawnmower was overfilled with oil.It has not run that good since,but I could still mow my lawn with it. Then later on it started to die out. and it won't keep running. I had it looked at, and it still don,t work right. It starts on one pull,mows about 5 minutes,then it start to die out till it stops. It sounds just like it was running out of gas. But the tank is full. Don't want to put anymore money into it. Seems no one is able to fix it. What would be the problem.
  • 637 Answers
Losing compression in your cylinder
Posted on Sep 12, 2014
  • 402 Answers
It may have damaged the piston ring lands (grooves) by slapping the piston with oil. If you have the compression tested it will tell you a lot, the mower should be around 100 - 120 psi, anything less and the engine is likely not worth repairing, if you like the mower buy a short block.
Posted on Jun 01, 2010
Suddenly cut out whilst mowing the lawn. now wont start, pull cord stiff to pull
Something just like this happened earlier this year with my pressure washer. This is what I did to fix it and now it runs great. Check the oil. If it's black or feels the least bit tacky, drain a pint or two of the oil out and re-add that amount of Marvel Mystery Oil. Now, attempt to pull the cord all the way out, but slowly at first. It should get easier to pull after about 5 pulls. If the mower restarts, let it run for 10 minutes until the Mystery Oil is hot and has cycled around inside the engine. Then drain that oil and refill it with a quality brand of oil. To top it off, either clean or replace the air filter, and put a shotglass of Lucas gas & injector cleaner into the mower's full gas tank. I also do this to my lawnmower and weedeater. It works wonders. BTW...If you're unable to turn the engine over by pulling the cord, remove the spark plug and tilt the mower up, so you can turn the blade easily by hand (use gloves). BUT FIRST MAKE SURE THAT SPARK PLUG IS REMOVED. REMEMBER... SAFETY FIRST! Let us know if this helped you any.
Jun 29, 2014 | Garden
My lawnmower stopped
Check the oil. I bet you seized the engine.
May 18, 2014 | Honda HRC216HXA Commercial Lawnmower
Self propelled lawnmower starts and then stops after two minutes mowing lawn
clean the carburetor jets out thoroughly with carburetor cleaner and a strand of wire through all openings. this is a common problem with the engine dies a minute or so after it starts up
Jul 03, 2011 | Craftsman Garden
What is wrong with a Toro GTS5 that starts well but dies 5-10 seconds later. I have changed the spark plug, air filter and oil. New gas too. Any suggestions? Thanks.
I had a similar problem. I'll bet I took off the carb. 5 - 6 times and cleaned it with no success. Very fustrating! One time while checking the fuel level I accidently left off the gas cap, I started it and while running I put the gas cap back on and started to mow and about 10 seconds it died. I thought could'nt be! So I loosened the cap, restarted and it kept running. Any way the small vent hole was plugged. Thats my story!. Good luck.
Aug 20, 2010 | Toro Lawn Mower With Toro Power Tools
Have a Toro GPS5 600 lawnmower. Starts with Choke on, but dies if you move off choke. Also, runs fast and slow when blade engaged. I heard carb for this unit are no longer available. Help
May 16, 2010 | Toro Lawn Mower With Toro Power Tools
Smoke from engine of lawnmower
usually large clouds of smoke are from having too much oil in the crankcase, or tipping the mower so that oil runs into the cylinder. Check the level of oil, and make sure it's not overfilled.
Mar 26, 2010 | Pool & Spa
Lawn mower died while mowing and won't restart
check the carb and air filter... also make sure its not gas from last season and make sure the oil is good.
Aug 16, 2009 | Garden
Billows of white smoke when Toro lawn mower runs
You overfilled the oil. If the mower runs, just go ahead and mow grass until it runs the oil out of the gas tank. Or you can empty the gas tank and fill with new gas. White smoke is not a serious problem. Only a hassle.
Jun 19, 2009 | Toro Lawn Mower With Toro Power Tools
Lawnmower will start but will not stay on
I had the same problem, what you need to do is adjust your throttle. To do that you there is a switch right in front of the filter. If you are looking right at it pull it all the way to left. If this dosen't work then check the springs that are connected to that switch they have a bad habit of coming loose. I had to replace all of my springs. Hope that helps.
Apr 15, 2009 | THQ The Lawnmower Man
Parks Optical 13.5hp Briggs And Stratton Intek Lawn Mower Engine Logo
517 people viewed this question
Top Parks Optical Garden Experts
Roland W VanLue
Roland W VanLue
Renee Knafel-Bullock
Mike Squire
Are you a Parks Optical Garden Expert? Answer questions, earn points and help others
