Question about Grilling
I need to replace my patio gas bottle...
I need to replace my 13kg patio gas bottle, but I cannot remove the gas regulator off the old bottle. What is the correct procedure from removing this. ?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 91 Answers
Always remember the threads are reverse on a gas cylinder and you are likely tightening this joint if your going the wrong way. some also have a quick disconnect and are like an air chuck and should be removed this way.
Posted on May 31, 2010
Can I use Patio Gas on my F150 Superser provided I fit the appropriate regulator.
You have to look at the size of the tank and the pull of the tank from the burners . You have to see what the BTU'S are . As the pull would be too much for the tank and the bottle will freeze as it cannot go from liquid to gas if the bottle is the wrong size for the draw off .
Oct 19, 2017 | Heating & Cooling
Gwt501a won't light
This can sometimes happen if the propane tank runs empty or the unit has been setting for some time.
It is typically the regulator is stuck and will not allow gas to pass through the regulator.
You may need to clean your regulator with some WD-40 or sometimes just tapping on the regulator several time with allow the diaphragm to start working again.
Here is a link to the manual;
http://www.bestbuypoolsupply.com/media/GWT501A-manual.pdf
Oct 21, 2011 | Uniflame GWT501A Open Flame Patio Heater
Need to purchase replacement regulator/valve (one piece) for patio caddie grill??
If what you're looking for is the Regulator/Tank Hose Assembly, you can purchase that for any home center or hardware store that sells gas grills. They are pretty much a universal fii, but be sure to take your old one with you for comparison purposes of the hose length. A little longer is ok, but shorter is not.
If that's not what you're looking for, you can purchase replacement parts directly form Char-Broil.
http://www.charbroil.com/Store/ReplacementParts.aspx
Happy Grilling!!
Mar 30, 2011 | Char-Broil Patio Caddie 4654870 (LP) Grill
No gas flow
Ensure that your hose, regulator, and control assembly are all clear of debris and that the orifice is not plugged.
May 21, 2010 | Char-Broil Patio Caddie Grill
I have a Gasmate patio heater ph 900 that won't ignite
Before you take it apart, try replacing the hose and regulator, easy to do and inexpensive. If that does not work, you will need to take the heater apart to get to the pilot orifice. The orifice is very small and easy to get clogged up. If the igniter sparks, then it is most likely a gas flow problem.
Apr 30, 2010 | Heating & Cooling
Coleman 5040 Patio Heater w/ Light - Light works, Heater does not
BE VERY CAREFUL sticking matches in any propane appliance! With the gas OFF see if you can physically see the spark when you push the ignitor, if yes, the problem may be the regulator or bottle pressure the only test i am aware of for the regulator is replacement.
Jul 13, 2009 | Coleman (5040B750) Patio Heater
Unit will not light
you probably have a clogged pilot assembly or pilot tubing this is usually an aluminum tube that runs to the sparker try to pullit apart and clean it
Jul 05, 2009 | Uniflame 233000 Open Flame Patio Heater
Charmglow gas patio heater
My charmglow heater is a yeAr old and the pilot will ignite and stay lit for ever,but when you let up on it it goes out! What cam I do?
Mar 16, 2008 | Coleman (5040B750) Patio Heater
Patio heater
There must be a blockage in the hose and regulator or your large tank may be checking and not allowing the unit to stay lit. Remove the large bottle. Let the gas line equalize for about 30 seconds and then reattach the bottle. Very slowly, open the knob on the large tank and I mean very slowly. Did I say open it slowly. The new OPD propane tanks often have a very touchie excess control valve that won't allow enough gas through if opened too rapidly. Now tray and light the heater. If you still experience the same, get a technician involved so they can inspect the gas pressure.
Oct 23, 2007 | Heating & Cooling
Grilling Logo
74 people viewed this question
Top Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Are you a Grilling Expert? Answer questions, earn points and help others
