Question about Microwave Ovens
The bottom of my microwave has gone rusty. Is it
The bottom of my microwave has gone rusty. Is it possible to repaint it please?
  • Microwave Ovens Master
  • 9,098 Answers
You need to clean it, sand it shiny, then clean it squeaky again.
Then you can get high temperature appliance paint in spray or brush-on form from local appliance part stores or places like Wal-Mart and Lowe's.
I would suggest you let it dry overnight with the door open before using the oven.
Posted on May 31, 2010
    Brigadier General:
  • 4,090 Answers
If youare referring to the inside of the oven NO This is baked enamel and if it has scuffed and gone rusty then do not use it as any paints applied will not withstand the activity of the magnatron. Special paint is used and baked in high temp oven to help withstand microwaves. Normal paint will burn off
Please rate my help++++Thanks for using FIXYA
Coating coming off inside bottom of microwave. Safe or not
not ideal but not unsafe to use unless it grows into a big hole and leaks radiation... if it's a public use microwave it'd be condemned... think about looking for a replacement, they're cheap enough now compared to what they used to cost.
leaving the door open for a few mins after cooking will disperse any residual moisture and prevent this from happening in your next microwave. (it'll also slow down the rot in your current oven)
don't forget to vote on your answers to keep the site free.
Good luck.
Sep 04, 2017 | Microwave Ovens
Oven began to spark and smell. The waveguide cover broke apart & scorched side now won't heat. Clock/light work so does the turntable but groans. Is it fixable or done?
It is possible the magnetron may have been destroyed. Arcing in the waveguide would likely cause a significant increase of cathode to plate current through it; possibly melting it internally. You could also have failure of the high voltage rectifier; caused also by high current. If that's the only problem, then it's possibly repairable for a reasonable cost. You would have to repair and repainted the waveguide. Some waveguides have a vertical bar in them to aid in dispersion of the microwaves. If this is loose and shorting, then you'd have to replace the entire frame/cavity. Not very practical.
Mar 29, 2016 | Sharp R-1214 Microwave Oven
MICROWAVE TAKES LONGER TO COOK EVEN ON HIGH AND OCCASIONALLY SPARKS FOR NO REASON
inside your micro... walls are made of metal but protected with paint, if this paint is gone and the metal shows thats what happend you have to repaint the unprotected areas again, and the reason your micro... is not working so good anymore is due to the magnetron
Jan 31, 2014 | Sharp R-930AK Convection/Microwave Oven
Paint is peeling inside the top of the microwave. Does this affect the safety or efficacy of the microwave. Can I repaint it? If so, with what?
Yes you can repaint it. Use an epoxy based paint and clean the metalwork with sand paper first.
The only health question is if you get the flaking paint in your food - yuk!
Jan 30, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Paint on ring under glass dish as gone rustey
That is caused by condensation. It can be cleaned and repainted. There is special non metalic paint available from Appliance stores or ebay etc that can be painted on the bare metal.
Jan 05, 2011 | Microwave Ovens
Rust on bottom of back panel can the be resolved?
Not very likely. I would suggest rubbing down and repainting the effected area.
Hope this helps
Jan 07, 2010 | Microwave Ovens
Bottom is rusty in the roller groove
If the cavity metal of the oven is chipped or charred, it will have to be sanded smooth and clean and dried thoroughly first.
Then you can apply some high-temperature appliance paint.
Oct 06, 2009 | Kenmore 62222 / 62229 1100 Watts Microwave...
I have a Spacesaver Microwave (manufactured 1988) that still seems to work ok, but I noticed on teh back wall under the glass tray the coating has rusted away. Should I continue to use this microwave?
As long as the oven's metal bottom is sound underneath the rust, there isn't a problem. The cooking chamber walls are so thick and highly conducting that they reflect the microwaves extremely well even when they have a little rust on them. However, if the metal is so rusted that it loses most of its conductivity in the rust sites, you'll get local heating across the rusty patches and eventually leakage of microwaves. If you're really concerned that there may be trouble, run the microwave oven empty for about 20 seconds and then (carefully!) touch the rusty spots. If they aren't hot, then the metal underneath is doing its job just fine.
Thanks.
Jun 17, 2009 | Microwave Ovens
Sanyo showerwave inner liner rusting
If it is a painted interior?Rub down rusty area,And repaint with enamel paint to match.
Oct 10, 2008 | Sanyo Microwave Ovens
Peeling paint
The only real danger is if it continues, it can deteriorate the metal, allowing sparking and possible leakage.
It's a good idea to clean, sand, clean again and repaint the area.
High temperature appliance paint is available form stores like Lowe's and Wal-Mart.
We're happy to help and we appreciate your thoughtful rating of our answer.
Feb 17, 2008 | Hotpoint RVM1635 Microwave Oven
Microwave Ovens Logo
433 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
