Question about EliteGroup 661FX-M7 (661FXM7V11) Motherboard
Hi the system is powering up and not booting into post screen, drives and cd power up and just have a black screen?
  • slewis87 May 31, 2010
    Thanks I should have said also that the graphics is on board.
    President:
  • 261 Answers
Hi
check your assemble graphic card is fixed into mainboard
2 replace your graphic card
if it does not work ask again
vote as you like
Posted on May 31, 2010
  • SH EM Jun 08, 2010
    hi
    disconnect all cable (cdrom, hard, ...) just power and case panel key,
    connected
    then try again
    if it does not work
    replace ram
    change ram
    change your power
Hi, I did this with Proliant ML350 G5: 1. shut it down normally 2. installed some more memory 3. started it up with BIOS update CD in the CD-Drive 4. updated BIOS successfuly (according the flas...
step one after checking DC supply voltage to spec
is does the BIOS key works
BIOS must work or the system is dead.
or video out port dead.
is this your first PC failure? experience
see if this dead screen page helps.
your post is not clear at all
start at the power switch and then go into BIOS
can you do that, if not find out why, bad screen>?
bad VGA port? lost DC power, try 2nd known screen
we can see you work and what all you see or saw.
lacking more clear results, and tests.
http://jeepdied.com/look/puters/dead-screen.html
Mar 26, 2017 | HP Compaq ProLiant ML350 G5 Server
Hi no battery in just mains power just a clicking noise for one or two seconds and screen flickers then laptop shuts down.the laptop is an asus x58l 2ghz with 1gig ram .note it does try to post but just...
clicking noise is most likey your hard drive failing. if you remove the hard drive ibet the computer will boot to a black screen with some writing but wont shut off. quick way to tell if its the hard drive. which is what is sounds like
Mar 19, 2011 | Computers & Internet
I have Dell Optiplex 740. When I press the power button the PC goes thru POST OK but, once it looks for the OS the screen goes black and never displays anything. If I power reset again, it does the same...
Boot with your recovery CD and select REPAIR and boot into the recovery console
from the command line type
fixboot c:
If that doesn't fix your problem reboot into the recovery console and at the command line try
fixmbr
Jan 23, 2011 | Dell OptiPlex 740 PC Desktop
Dvd r/rw on Dell E1705 laptop computer quit playing cds and dvds. Makes grinding start up noise but does not play
Your system comes with on-board diagnostics. Run the diagnostics to check if the problem is with the drive or windows.
To run the diagnostics follow the steps below
1. Shutdown the system
2. Press the Fn+Power button together
3. The screen will display color screens
4. Follow the prompts until it takes you to advanced diagnostics
5. Do a custom test on the optical drive.
If you are unable to run the diagnostics
1. Find the dell resource cd that came with the system
2. Insert the cd in and restart the computer
3. At the Dell logo screen press the f12 slowly 5 times
4. Select boot from cd/dvd drive
5. Press any key to boot from cd .... message appears press enter
6. If the system starts from the cd .. this would mean the drive is ok
pOst back what were the diagnosis
Thanks
proton
Apr 11, 2009 | Dell Inspiron E1705 Notebook
My eurocom wont boot pass bio screens
Hi
few possible problems:
The hard drive is not detected or not working
Or the operating system is corrupt or missing
Or the computer is not set to boot from the hard drive.
if not then the computer is not set to start up from a cd, you can either enter the setup / bios to change that setting OR right when you power up the computer look at the screen it will say what button to press in order to enter bios thats one way to solve the problem but look for Boot menu, it will very likely be button F12 or similiar, it should say on the screen when you power on.
if it doesnt, then you need to go into the bios and change the boot order so that the computer starts from the CD first.
after that you should be able to start from the cd and install the OS (Operating system, eg.Windows)
heres some info on how to work the bios: http://www.whitecanyon.com/how-to-change-boot-order.php
Change the boot order so its CD ROM, optionally FLoppy drive here if your laptop has one of those, then Hard drive.
save and exit the bios, use the above link to get info on how to work the bios.
Test and see if the computer starts up normally, if not then you need to use the windows installation cd to install windows into the computer again.
if you get any errors or problems on installing windows let me know.
Mar 16, 2009 | Eurocom 888es Notebook
Power cable
If the system is posting and you can access the BIOS, then the ac adapter is probably giving the system enough power. Remove the HDD, see if the Clicking goes away and see if the system will boot to a WIndows XP CD with the HDD removed. (Most clicking issues in a portable are drive related.
If the system will post and boot to a CD with the HDD removed, then most likely the HDD is bad and will need to be replaced.
If the noise and boot problem do not change, then I'd see if the system runs normally with a Dell power adapter next.
Feb 28, 2009 | Dell Latitude D600 Notebook
Acer Aspire 5050 won't boot at all
Hi there
Try taking the battery out and power it on AC only, post back with the results.
Good luck
Feb 13, 2009 | Dell Latitude D600 Notebook
EliteGroup 661FX-M7 (661FXM7V11) Motherboard Logo
157 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
