How do you tune in the freeview channels do you need a freeview box?
    Brigadier General:
  • 4,090 Answers
If you are using a standard television and not connected to FOX or cable then you are already receiving FREEVIEW channels There is no Freeview Box as such. Tivo allows freeview and digital reception maybe that is where you are confused
Please rate my help++++Thanks for using FIXYA
Posted on May 31, 2010
My Logik freeview box has will not tune some channels - most are fine. What can be done to fix this?
Usually that is caused by poor signal strength or a faulty tuner inside the receiver. Replacement boxes are only £18 upwards.
Nov 23, 2014 | Televison & Video
I can not set up my freeview on my samsung 52 inch LCD can u help me step by step as I hav no instructions thanks
Plug your aerial into the freeview box. Connect a scart lead from the freeview box to your TV and switch on.
The freeview box, if new, will search for channels itself and as your TV will recognise that it is plugged in, will auto switch to the freeview box.
If it is not new, select menu on the freeview box and follow the instructions for tuning.
There is nothing to tune on your TV as you are using a scart lead.
Hope that helps.
Nov 14, 2010 | Televison & Video
I have just purchased the sony video player SLV SF900 for my mum. I have used a scart socket to connect through the freeview box and to the back of the video. I have also added the aerial sockets. The...
Not all SCART connectors and cables carry the IN and OUT connections - make sure that the one from the freeview box has OUT connections, that the cable can carry them and that the one from the recorder has IN connections. Then , to record what you want, all you have to do is to tune the freeview box on that channel and set the recorder to use that SCART connector as source.
Sep 03, 2010 | Televison & Video
Slanted screen on freeview connection to Beko 28426DNS,
your television has a defect.the best remedy for this is to resolder the jungle ic. the technician can do this job.
Jun 19, 2010 | Televison & Video
How to tune freeview for digihome PVR80 it wont record bbc how to fine tune it .when we had to re-tune for channel 5 it worked perfect so please tell me how to do that again
On your remote control, press 'menu'.
Then select 'set up' on the screen.
Then select 'Installation' on the screen.
Then select 'Automatic channel scan' on the screen.
The box should then scan for all channels, and with luck BBC will be included. If not, please repost. Some older Digihome PVR80s can't cope with the new multiplexing standard employed by digital freeview.
May 07, 2010 | Televison & Video
No user manual for CE28DN9-B. Bought TVonics
HELLO
Follow these instructions:
Select a spare channel on your TV say 6 on your remote.
Press MENU.
Scroll down and select PRESET.
Using RIGHT button of F/OK/ENTER press it and this will go to TUNING.
Press RIGHT button again which will let you go to SEMI or AUTO tuning (for your purpose select "SEMI").
Scroll DOWN to highlight the actual UHF channel number or CH:C21 as it may appear on the screen.
Press the RIGHT button again yourself manually and you will see the channel number change anywhere from 21 to 69 until you come to your freeview box's RF channel output.
When you have done that scroll down to Memory and you'll see a box beside it. Press the RIGHT button and a tick will appear in the box.
You have stored your Freeview box RF channel on your TV.
Press MENU button THREE time to come out of the MENU setting.
Use this procedure again if you wish to change the RF channel on your TVONICS box.
GOOD LUCK (:-)
Oct 03, 2009 | Televison & Video
Same problem
At lunch time today all freeview boxes have to re-tuned so you will get channel 5 and ready for HDTV.
Some old boxes according to sources are packing up altogether so you have to keep this in mind.
You can re-tune your freeview box using your OSD (on-screen display) and locate re-tune.
If you are unsure how to re-tune the box which many people are having problems with please visit this website for a guide for your model box >>>>
http://www.tvretune.co.uk/
http://www.tvretune.co.uk/productmanuals/
Regards.
Sep 30, 2009 | Philips Televison & Video
TV, freeview, DVD and video set up.
Hi.
Modern day freeview boxes rarely have A modulator in them so you can not tune it to a channel on your tv it must be connected using scart lead.
Most freeview boxes have 2 scart sockets one for VCR & one for TV plug your scart leads in to the scart sockets of freeview they will be labled TV & VCR.
The scart labled TV goes to scart socket on the TV labled AV1 or 1
The scart labled VCR goes to scart socket on VCR labled AV or IN
Now the aerial leads From wall socket to ANT in on freeview.
Then from RF out on freeview to ANT in on VCR.
Then RF out on VCR to ANT in on TV doing this will enable you to put TV on 9 to watch tapes.
The final scart will be from DVD to TV socket marked AV2
You will need to put TV on AV channel to view freeview.
To record freeview you must put VCR to EITHER line.av,aux. it will be one of those different manufacturers call them by varying names.
I have done this banking on your tv having 2 scart sockets if it only has 1 let me know & I will tell you how to wire it differently.
Please state make & model of TV set & VCR & what connections are available EG scart, Phono, Svhs etc.
http://dysonmanuals.llc.nu/
Chris..
Jan 20, 2008 | Televison & Video
Can't re patch tv with set top box to watch tv
Hi.
Ok here goes.
1) Take airial lead from the wall socket in to antenna in on freeview box.
2) connect short usually black airial type lead in to antenna out socket on freeview. plug the other end of this lead in to aerial in on vcr.
3) connect the other end of this aerial type lead to airial plug on the back of tv.
4) now if you have 2 or more scart sockets on the back of tv set plug in the scarts in this order.
Freeview box scart with tv on it connect to scart 1 on tv set.
Freeview box vcr scart connect to vcr in scart socket on vcr.
Vcr scart marked tv plug scart from here to scart 2 on tv
If you have 3 scart sockets on tv you can connect dvd using scart to scart socket 3 on tv.
If Tv has only 1 scart the aerial leads will stay the same as I have stated,
Freeview must go to scart socket on tv set.
leave second scart from freeview to vcr plugged in so you can record freeview by putting vcr to line 1 or AV 1.
you will need to put tv on channel (0) & tune this channel to the video play a tape that you recognise then go to tv tuning & tune tv untill you see video playing then store this on channel (0).
DO NOT USE AUTO TUNING IT WILL PUT CHANNELS IN THE WRONG ORDER JUST USE MANUAL TUNING.
Now to view Dvd you will either need to purchase A scart switch box. Or have keep unpluging freeview scart from tv so you can plug in dvd .
If your tv has red yellow white phono sockets you can plug dvd in to these, you may need to purchase phono leads.
Hope this helps.
Chris..
Jan 08, 2008 | Televison & Video
Can't tune stations from freeview box to DVDR3380/5
You can only record freeview channels through your box.
Assuming the digi-box has two scart sockets, connect as follows:
  • Scart 1 or TV scart of the digi-box to the TV.
  • Scart 2 or VCR/DVD scart of the digi-box to scart 1 of the DVDR3380.
The TV aerial should already be connected through the digi-box and DVDR3380 to the TV
To record from the digi-box, select AV1 / E1 / EXT1 on the DVDR3380
If you are doing timer recordings, you will also need to leave the freeview box on the channel you wish to record, or set the freeview box timer.
Dec 15, 2007 | Philips DVDR3380/05 DVD Recorder
Televison & Video Logo
149 people viewed this question
Top Televison & Video Experts
