Question about Dryers
I have a SELV electric fan in my bathroom with a timer. I want to be able to disconnect the timer portion so that the fan will switch off as I turn off the light.
  • Rich Jun 01, 2010
    Hi .. Are you saying that the timer is part of the fan itself .. or is the timer a wall switch type item??
  • barrielegget Jun 02, 2010
    The and fan is operated by a cord pull. Between the cord pull and the fan there is 'box' containing the transformer and timer control. At the moment the fan operates when you pull the cord, and then when you switch off, (with the pull cord) the fan continues to operate for a few more minutes before it switches itself off. I want to be able to bypass the timer electrically so that the fan switches itself of when I pull the cord. I have had the 'box' off the wall and looked inside, and there is a circuit board with the timer on (currently set at the minimum time delay), and the transformer, as the fan works on 24 volts.
    Can you advise me what I need to do to bypass the timer please?
    Guru:
  • 351 Answers
OK .. the obvious connection would be to find the transformer. Then look at the imput and output of the transformer . you want to take the output , 24 volts, from the transformer and wire it directly to the lamp base. If this transformer is attached to the circuit board then it may be a difficult task to separate the leads. You will want to haqve the pull chain switch in the power line between the power source and the transformer , so the transformer is only working when the lamp is on.
Posted on Jun 02, 2010
Testimonial: "Thanks I'll try that out. "
Dimplex bathroom fan heater cord problem
take the cover off and clean the inside and were the cord is and use some wd 40 turn of the supply first and that should loosen it for you
Jan 06, 2014 | Dimplex Fx20ve 2kw Timer Wall Mounted...
I have moved into a property with a Sector extractor fan in the bathroom - when you turn the light on the extractor starts up -when you turn the light off the extractor continues to run for a long time -...
On some Bathroom extractor fans there is a setting for the amount of time you want the fan to stay on after you turn off the switch, the setting dial is normally at the back of the fan so you need to take the fan down from the ceiling making sure the fan is electrically isolated.
Mar 31, 2011 | Home
I nees 15 min. timer for my Newtone bathroom heater. I live zip code 94602 Oakland, Ca. Where to find. Thanks
You need "15 minute countdown timer" for a bath fan.
1) Following page shows selection of timer types and brands:
http://waterheatertimer.org/Countdown.html
There are push button electronic types and rotary dial types.
2) Easiest to wire is mechanical spring type countdown timer, FD series.
No electronics that can be affected by 'electric noise' on fan circuit.
Intermatic spring-wound last for years without problem.
http://www.electricsupplyonline.com/prod/intermatic-springwound_timers.php
http://www.electricsupplyonline.com/prod/intermatic-springwound_timers/fd15mc_w005485.php
3) Another reliable timer is GE 15088 sold at Home Depot.
Timer has preset for 20 minutes, not 15
http://www.homedepot.com/webapp/wcs/stores/
4) Amazon sells reliable 15 minute Intermatic electronic countdown:
http://www.1000bulbs.com/product/3293/ELEC-EI200LA.html?utm_source=SmartFeedAmazonProduct
5) Timex sells 15 minute spring wound countdown timer. Lower price is probably with reason since Timex are generally sold in drug store/dollar store rather than hardware/electric outlets.
http://www.amazon.com/Timex-Minute-Springwound-Countdown-Timer/dp/B00013K69Q
6) Spring wound timers connect easily to same wires that come off old fan switch.
Old switch has 2 insulated wires, connect them to either terminal on spring wound timer.
7) Electronic timers are wired differently:
Instructions for wiring electronic timers appears on following link:
http://waterheatertimer.org/GE-timers-and-manuals.html#15088
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jan 23, 2011 | Broan-NuTone Fan,Bathroom Exhaust Broan...
I'm trying to install this Woods 59008 automatic fan timer in the bathroom. My old on/off switch only has three wires....and I that a light switch next to that. The woods 59008 has a red, black, white...
Sure George.
These in-wall timers have extra wire to operate the electronics located inside timer.
You said your old switch has 3 wires.
The new timer can only replace on-off switch that has 2 brass screws and a green screw.
If old switch has 2 brass screws and a dark screw, that is a 3-way switch.
Typically a 3-way switch is found at both ends of hallway.
The Woods 95008 countdown timer is not made to replace 3-way:
http://waterheatertimer.org/Woods-timers-and-manuals.html#59000
Here's what to do:
1) Switch has 2 wires (plus bare ground wire). Take switch wires and connect them to timer-black-wire and timer-red-wire. Choose either one for now.
2) In back of electric box are white wires twisted together and covered with wire nut. Connect timer-white to these wires. This wire will power timer electronics.
3) If electric box does not have white wires described above, then connect timer-white to bare ground, along with timer-green wire.
4) Turn on electricity, and push override button located below the OFF button. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
Add a comment if your need more assistance.
Dec 22, 2010 | Woods Ind 59008 Digital Timer
I purchased the Legrand RT1 Time Switch to run a bathroom fan. It is installed and I see indicator lights. Every time I turn the fan on, it runs for a second and stops (hearing clicking in the switch);...
You connected red and white wires together.
No problem, nothing burned out, and it's simple to fix. Steps below.
RT1 is electronic countdown timer, and electronic timer clock inside needs separate circuit, just like your alarm clock needs to be plugged in. >> that's why timer has white wire. White wire completes circuit to timer clock.
Manual says:
Timer-black-wire to Hot; Timer-red-wire to Load (lights)
Timer-white-wire to Neutral.
Heres what to do
1) Timer-green-wire connects to bare ground wire.
2) Switch has 2 wires. Take switch wires and connect them to timer-black-wire and timer-red-wire. Choose either one for now.
3) In back of electric box are white wires twisted together and covered with wire nut. Connect timer-white to these wires.
4) If electric box does not have white wires described above, then connect timer-white to bare ground.
5) Turn on electricity, and push countdown button. If lights come on, timer is wired correctly. If lights do not come on, then reverse timer-red and timer-black wires.
Nov 27, 2010 | Pass & Seymour / Legrand RT1-W 10-20-30-60...
My house has a T1033A which controls the bathroom fans. There is no display and even when I turn the unit to the off position, I cannot switch the fans on. Is the unit shot? I can't determint which breaker...
Open following link to identify timer and download manual:
http://waterheatertimer.org/Aube-timers.html
The reset button is small round button and can be pushed with toothpick or paper clip.
If reset doesn't restore timer, then timer is probably shot.
Also check all breakers to make sure one isn't tripped.
To test which breaker controls timer, open up box so you can test wires, and then use electrical tester and process of elimination to identify correct timer.
Add a comment and say if this is new installation or if timer suddenly stopped functioning.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Jul 03, 2010 | Aube Technologies Aube 7-Day Programmable...
Nothing to attach a ground wire to.
ground wires are normally attached to the electrical conduit or box grounded means to earth in electrical terms so any ground terminal available can be used hope this helps
Apr 18, 2009 | Intermatic FD60MWH - Spring Wound Auto-Off...
Installing timer on existing electrical outlet
Are the wires different colors or is there too many of one and not enough of the other. Your bathroom switch should have black which is hot, white which is neutral, and green or bare which is ground. It should be the same on the timer, but may differ. The instructions should tell which wire or terminal is hot, neutral and ground.
Sep 10, 2008 | Hardware & Accessories
Dryers Logo
104 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
