Question about Microsoft LifeCam VX-1000 Personal Web Camera
Had a problem with the cam, so deleted the program and went to down load the software again from the disc but says this version is too old for Vista. Was fine before on this system
  • Microsoft Master
  • 2,724 Answers
Download from the Microsoft support website
after filling in the details take time to look at the "readme" links for any known issues and any additional support software needed
http://www.microsoft.com/hardware/download/download.aspx?category=ICE
Posted on May 31, 2010
I have a acer laptop ASPIRE5520G .My dvd drive does not appear in my computer folder so that i can't use it. Please give me some advise. Thanks.
Below is the steps to resolve the issue:
CAUSE: Software that is not Windows Vista capable (such as printer software, CD burning software, and games) may have modified the registry to cause the optical drive to not function.
RESOLUTION: Method 1: Remove the program that caused the issue: If you know which program might be the cause of the issue or the last program you installed, remove the program.
  1. From the Start menu, click Control Panel.
  2. In Control Panel, click Uninstall a Program.
  3. In the Programs and Features window, click to select the program to remove, and then click Uninstall/Change.
  4. In the User Account Control dialog box, click Continue.
  5. Follow all onscreen instructions to complete the removal.
  6. Shut down and restart the computer after removal is complete.
Note: Determine whether the computer is working properly. If the issue is resolved, do not load this software again because it will cause the optical drive not to function again. Instead, contact the software manufacturer for a Windows Vista™ capable version.
If removing the program did not resolve the issue, use System Restore. Method 2: Use System Restore to restore to a date before you installed the third party software.
  1. Close any open programs.
  2. From the Windows Vista™ default Start menu, click All Programs, Accessories, System Tools, and then click System Restore. Note: System Restore can also be opened by typing Start Search keyword: rstrui.
  3. In the User Account Control dialog box, click Continue.
  4. In the System Restore dialog box, click Recommended restore, and then click Next.
    View Picture Note: If a different restore point is needed, select Choose a different restore point, and then click Next. Select a day and time from the list when the computer was working properly, and then click Next.
    View Picture
  5. In the Confirm your restore point dialog box, click Finish.
    View Picture
  6. In the System Restore dialog box, click Yes. The computer restarts and make the appropriate changes.
    View Picture
  7. After the computer returns to Windows, in the System Restore dialog box, click Close.
    View Picture
Note: Determine whether the computer is working properly. If the issue is resolved, do not load this software again because it will cause the optical drive not to function again. Instead, contact the software manufacturer for a Windows Vista™ capable version. Method 3: If System Restore did not resolve the issue, manually modify the registry.
  1. From the Windows Vista default Start menu, point to All Programs, Accessories, and then click Run.
  2. In the Run dialog box, type: Regedit. Click OK.
  4. In the Registry Editor window, locate and then click to select the following registry subkey: HKEY_LOCAL_MACHINE/System/CurrentControlSet/Control/Class/{4d36e965-e325-11ce-bfc1-08002be10318}
  5. From the File menu, click Export.
  6. In the File name dialog box, type: Savedkey, and then click Save.
  7. Click the REG_MULTI_SZ data type UpperFilters file, and then from the Edit menu, click Delete. When you are prompted to confirm the deletion, click Yes.
  8. Click the REG_MULTI_SZ data type LowerFilters file, and then from the Edit menu, click Delete. When you are prompted to confirm the deletion, click Yes.
  9. In the Registry Editor window, from the File menu, click Exit.
  10. Shut down Windows® and restart the computer.
Thanks and regards,
Anil.B.R
Nov 06, 2010 | Computers & Internet
Problem loading photo explosion delux version 3 disc 1
You can right-click on the program's setup.exe, select properties, then compatibility and set it to windows XP
then try to install it again
Dec 15, 2007 | Nova Development Photo Explosion Deluxe...
Trying to download yahoo messenger but I get an error that says something like this: applications has failed to start because the application configuration is not correct. Anyone have an idea why its doing...
Check it out with down loading installation path and as well previous versions of YM on your system along with other Messengers with out error
Dec 12, 2009 | Yahoo Messenger
When I down load the software it says there is another version already running.I don't know what to do
The program won't install if the version your using is the most current one.  If you really want to load your software, then uninstall whatever you got now, restart your computer, and then load your disc and try installing again.
Oct 25, 2009 | Office Equipment & Supplies
Windows vista will not open autocad 2004 after being loaded
All you need do is got to autocad website and download the autocad lockeds1. its a patch it works for pirated autocad as well.
Mar 02, 2009 | Autodesk AutoCAD 2004 for PC
Reinstalling Vista and Acer Tech
The restore disk should be available from Acer Suppport here https://secure.tx.acer.com/RCDB/Main.aspx?brand=acer if they no longer support it then you should be able to get it from restoredisks.com
Feb 08, 2009 | Acer Aspire 5610-4648 Notebook
CAM
Its probably a false error message.What version of Windows are you running?I fits XP than ignore the message.
May 11, 2008 | Video Cameras
Windows Vista installation of drivers.
i jus plugged mah concord eyeQ duo 2000 digital camera into mah usb port and it downloaded the drivers for me without usin mah disc on mah vista...
Feb 08, 2008 | Concord Camera Eye-Q Duo 2000 Digital...
Software loading problem
whats ur operating system. i think it is vista. that may be the compatiblity problem with ur software. try it on windows XP . it will solve.. if u want to work it on vista, then u have to download a vista supporting version of that particular software...thats all
Dec 07, 2007 | HP Pavilion dv4000 Notebook
Microsoft LifeCam VX-1000 Personal Web Camera Logo
27 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
