Question about LaCie (300728U) 250 GB Hard Drive
Missing files after using the recover CD
I used my Gateway recover CD to reset my computer to the original setup and I found I couldn't see all files in my LaCie external drive even I could see the storage files size from the Hard Drive property.
    Problem Solver:
  • 13 Answers
In this case try some data recovery program to see if it can help rescue your data on your external.
Posted on Dec 20, 2010
What can i do to get to the recovery screen on my gateway desktop, its model is SX2110G-UW24?
I pulled this from the Gateway manual for your machine. It is a generic guide. If this doesn't work, you may not have a recovery partition on your hard drive and should have made recovery disks when originally getting the unit. Good Luck!
From the Gateway Manual......
Recovering from the hard drive during startup:
To reinstall Windows and all pre-installed software and drivers:
1. Turn on your computer, then press Alt+F10 during startup. Gateway
Recovery Management opens.
2. Click on Restore system from factory default.
Caution: Continuing the process will erase all files on your hard
drive.
3. Click on Next. Your hard drive's original, factory-loaded contents are
recovered. This process will take several minutes.
Jan 11, 2015 | Gateway Computers & Internet
Windows\systems32\config\system file is missing or corrupt
You can order a new set of disks from the manufacturer or pull out the had drive and plug it into another PC or buy an external hard drive dock . Newegg has them for around $20
Mar 09, 2014 | Insignia Computers & Internet
I can use my Dell OptiPlex GX280 PC Desktop says that windows could not start because drive 1 not found: serial ATA, SATA-2 and drive 3 not found: Parallel ATA, PATA1?
Use your system restore disks to repair your computer since the OS is FUBAR
Without those disks you are SOL. And if you never made them or lost them, now you have learned first hand why it is so important to have them.
Go to the dell site and see if they have your original OS in an iso file for installation. If so that will save your sorry b---.
Sep 09, 2017 | Dell OptiPlex GX280 PC Desktop
Netbook acer aspire one Windows could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM You can attempt to repair this file by starting windows setup using...
Put the original setup CD-ROM into your CD-drive.
Restart the computer.
Tell it to "boot" from the disk in the CD-drive.
Choose "repair an existing Windows installation",
and let it fix the problem.
Remove the CD-ROM disk.
Restart your (repaired) computer.
Oct 09, 2010 | Acer Aspire One Netbook 8.9" Notebook
Gateway laptop says '' Windows could not start because the following file is missing or corrupt: windowssystem32configsystem you can attempt to repair this file by starting windows setup using the original...
You need to have a working Windows CD Installer to resolve this corrupt issue.
When you have the CD, load it while your computer is starting up, and then it will start to run the Windows setup program. Follow the on-screen instructions.
When you pressed the "r" key in the keyboard as detailed in the error message above, you will be prompted to start from drive C: or other drive. Press "1" to choose drive C then enter. If there is a password, then the previous owner might have setup a password for the drive.
when you are in drive C, a prompt like this appears:
C:\Windows> or C:\>
just type in the command chkdsk \r to do the actual disk repair. It is "chkdsk \r" => there is a space between k and \.
Try your luck.
Mar 07, 2010 | Gateway Solo 1450 Notebook
For Windows won't start problem, I have met the same situation before. It was Windows Boot Genius to fix problem easily!
Jul 03, 2009 | Toshiba Satellite L25-S121 Notebook
Start up
what a pity! if you Windows is really just had a corrupt system file that caused it, try boot with this CD to recover bad sectors: "HDD Regenerator 1.51". This is also available in Hiren's BootCD.
By the way, what Antivirus you are using on the laptop? The cause of this may due to a Virus wrote a startup system file entry into the registry but your Antivirus picked up the file and removed it however not the action. That's why a file is "missing" upon reboot.
What you can do lastly is to take the harddrive out, put it into a external harddrive case, backup all your data from another PC, and reinstall Windows on the laptop.
Apr 12, 2009 | Toshiba Tecra A2 Notebook
No Operating System; Cannot Format User Partition - Gateway MX595
It seems that you have a corrupt user partition on your drive which is stopping you from doing a recovery.
What you will need to do is delete the partition(s) on your Gateway by using a system repair utility CD. ERD Commander 2005 or Bart are utilites that will allow you to boot from a CD and then delete the partitions.
You could also use a friend's Windows XP CD just to delete the partitions.
Once this is done, you should be able to re-install your OS (assuming there is no physical damage on the hard disk.
Hope this helps.
Mar 25, 2009 | Gateway MX6956 Notebook
Windows could not start because the following fio valiant 671dp
Contact the makers of your laptop and order the recover disk. They go around $40.00 to $50.00 dollars.
Dec 28, 2008 | KDS Valiant 671DP Notebook
LaCie (300728U) 250 GB Hard Drive Logo
101 people viewed this question
Top LaCie Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
