Question about Victor 1297 Calculator
Machine will NOT work
When cut on, the letter "E" comes up on the far left side, with a "0" on the far right, but you can press any key and nothing happens, no paper feeds, nothing? what to do?
If the print carriage is stuck on the far left, gently try to turn the gears a few turn and if you are lucky enough the print carriage will go back to the right.
This is what I did and it is working fine now.
One thing importan, be "gentle" it is easy to break.
Posted on Aug 23, 2008
SOURCE:
I have fujitsu laptop runing win 7, when i type some letter be wrong for examle when i type m come 0 ,
Hello there,
Did you check the keypad for alternate keys.
For example net books, the number keys on the right side has an alter key on the some letters like the image below. when you accidentally press the [Fn] key, Numbers are written instead of letters..
Hopefully this helps. Thank you for posting..
Jul 12, 2011 | Computers & Internet
SHIFT KEYS NOT WORKING PROPERLY
Please try to deactivate the Fn (function) key. That will help you get rid of your problem. Press Fn key + Numlock key once and try again. You can also try pressing the Fn key once and type letters in any word processor program with the key combination everytime you press the Fn key once. E.g. open the notepad, press Fn once and after that press ) with Shift.
If you have problem, let me know.
Good luck.
Thanks for using FixYa.
Jul 27, 2010 | Acer TravelMate 2480 Notebook
I have a number 4 and a letter H flashing
To reset the H3 or H4 condition on just about any Xerox XC or XD series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
If done correctly the display should go blank.
Now key in 14 as if you were going to make 14 copies.
Now press the print button.
The machine should reset and the code should be gone.
9 times out of 10 this is a false code that pops up due to power surges or noise.
If the code comes back this means you have a heater lamp or thermal fuse (more common) failure in the fusing area and will need service.
This procedure will work on all Xerox XD and XC models
Good Luck and Thank You for using Fixya
Jul 16, 2010 | Xerox WorkCentre XD100 All-In-One Laser...
I turn my xc1044 copier on and get a H3 code and machine will do nothing
You can try resetting the code. If it comes back then the machine will need service. The H3 code is a fuser code which is the part that gets hot right before the paper exits the machine.
Press the C key then the far left key then the C key then the far left key. So C,far left,C,far left
These 4 keys must be pressed within 4 seconds. If done correctly your display will go blank.
If so then key in 14 as if your were going to run 14 copies then press the print button.
This will reset the code, at least temporarily. The H codes sometimes pop up when there is no issue with the copier.
If it comes back you will need a repair person.
Good Luck and Thank You for using Fixya.
Mar 11, 2010 | Office Equipment & Supplies
I have a Sharp AL 1631 it won't print. It shows an H-4 in the menu screen
Press "Clear" then "Exposure Mode" then "Clear" then "Exposure Mode" quickly like within 4 seconds. The exposure mode key is the far left key.
If you do this correctly the display will go blank.
Key in 14 as if making 14 copies
Press the print button.
Short version: C, far left, C, far left, 14, print
The machine should reset and run fine. This is a common "false" code on these machines.
If it comes back after a couple of tries the you have a thermal fuse or heater lamp failure.
Nov 18, 2009 | Sharp AL 1631 Copier
After putting on the copier the scan lamp carriage is vibrating for about 3 to 4 minuet then after the code e7 came.
You need to clear the code, press the following buttons in the order below.
  • Clear Key (far right key)
  • Exposure Key (far left key)
once you do this correctly the screen should go blank. Type in the following
  • 14 (using the copy quantity keys)
  • Press your copy key
  • 1 (using the copy quantity keys)
  • C (until the machine restarts)
If the code comes back then you are having a reference error and will need to call a local Sharp Authorized Dealer to service your machine.
Oct 09, 2009 | Sharp AL-1000 Copier
I dont know how to program frequiences on the scanner
1. Press Menu (Bottom left hand side of the scanner) You should see "Program System"
Press E You should see "Select System"
2. Turn VFO knob (Top outside right knob on the scanner as it faces you.) until "New System is displayed.
3. Press E
4. Using the VFO knob, select "Conventional then press E three times
5. Press the decimal key until all the letters under "Edit Name’ disappears
6. Now you’re ready to name your system. Turn the VFO to the to select a letter or number. Once the letter or number is selected, hold the Function key (Top left hand side of the scanner) while turning the VFO knob to the right to add another letter or number. When you finish, press E
7. Turn VFO to Edit Group then press E
8. Use VFO to select New Group then press E twice
9. Press the decimal key until all the letters under "Edit Name’ disappears
10. Now you’re ready to name your group. Turn the VFO to the to select a letter or number. Once the letter or number is selected, hold the Function key (Top left hand side of the scanner) while turning the VFO knob to the right to add another letter or number. When you finish, press E
11. Turn the VFO to Edit Channel then press E. (You should now see "New Channel")
12. Press E then enter a frequency
13. Press E twice
14. Press the decimal key until all the letters under "Edit Name’ disappears
15. Now you’re ready to name your "Subgroup" i.e. " Dispatch" Turn the VFO to the to select a letter or number. Once the letter or number is selected, hold the Function key (Top left hand side of the scanner) while turning the VFO knob to the right to add another letter or number. When you finish, press E then menu
16. Use VFO to select New Channel
17. Repeat steps 12 through 16
Mar 27, 2009 | Uniden BC246T Handheld Scanner
Eurovox codes
GOTO MENU PRESS OK ON CHANNEL SETTINGS THEN KEY 1968 TWICE
THEN ENTER YOUR RIGHT KEY TILL YOU GET NAGRAVISION
CHOOSE YOUR PROVIDER PRESS OK
GO DOWN TO YOUR 00 KEY
USE YOUR RIGHT LEFT KEY TO ENTER THE RIGHT ONE
THEN PRESS OK TO GOTO THE NEX ONE
SAVE ON EACH KEY (00 AND 01)
OR
PRESS MENU - THEN PRESS THE YELLOW TEXT BUTTON (BOTTOM RIGHT).
PLEASE TAKE NOTE OF THE BELOW:
TO ENTER LETTER A = PRESS TV
TO ENTER LETTER B = PRESS RADIO
TO ENTER LETTER C = PRESS P-
TO ENTER LETTER D = PRESS P+
TO ENTER LETTER E = PRESS INFO
TO ENTER LETTER F = PRESS RECALL
TO ENTER 1, 2, 3, 4, 5, 6, 7, 8, 9, 0 = PRESS THE NUMBER BUTTONS ON THE REMOTE CONTROL.
ENTER THE PROVIDER & KEYS FOR YOUR AREA & PRESS THE OK BUTTON ( press 4 secs ) TO SAVE. THIS WILL BRING THE CHANNELS BACK TEMPORARILY WHILST A NEW SOFTWARE IS BEING RELEASED.
Hope this is helpful
Jan 26, 2009 | StarTech.com StarView SV211K 2-port KVM...
Victor 1297 Calculator Logo
184 people viewed this question
Top Victor Office Equipment & Supplies Experts
Steve Allison
Steve Allison
k24674
D. E. Hev
Are you a Victor Office Equipment and Supply Expert? Answer questions, earn points and help others
