Question about Zanussi FJD1266W Front Load Washer
Rubber drive band snapped and took out a earth and grey wire, can it be repaired? approx. how much?
    Brigadier General:
  • 4,090 Answers
Any electrician should be able to repair this if you have the machine's cover off;
In fact you could do it yourself with a soldering iroin to replace the spade bit on the wire and some shrink rubber tubing which will allow you to join in any extra wire.
Cost to fix about $10 DIY and $50 by Mr Fixit type
Please rate my help++++Thanks for using FIXYA
Posted on May 31, 2010
Dvd player repair where does rubber band go
Personally I would replace the drive completely - They are very cheap and easy to install. http://www.youtube.com/watch?v=VVjQ7p2_KT0
Jan 07, 2014 | Dell for Optiplex GX620 CD-RW/DVD-ROM...
Where to buy Sony MHC-RG40 rubber band
You just need to measure the diameter of the belt (approx) in MM. Then put "XX MM diameter Drive Belt" into Google. Get the one nearest your measurment.
Dec 17, 2012 | Sony MHC-RG40 CD Shelf System
Vertical Band has appeared on my TH-42PX60B
HI
Before getting a new tv set I would try all cables and contacts, as well as looking in the troubleshooting section in the manual.
hope you succeed
Kolbrun
Feb 20, 2012 | Panasonic VIERA Televison & Video
21400 craftsman band saw, the rubber band snap
do a search for sears service center and find a local "service and repair" center. they will be able to either figure out the part you need over the phone or ask you to bring the tool in, but i don't believe sears/craftsman makes their parts manuals readily available.
Dec 01, 2009 | Craftsman Saws
Need to install my clarion vrx755vd, but have no wiring diagram
yellow 12v battery
red 12v accessory
black earth
blue/white amp rem
blue power antenna
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
green rear left +
green/black rear left -
purple rear right +
purple/black rear right -
orange/white illumination
brown phone interrupt
grass green connect to earth if u want to watch dvd's whilst you drive
rate pls
Nov 17, 2009 | Clarion VRX755VD Car DVD Player
Grey Band and Ghosts on monitor
check the playback and other chips inside.. or try to change the setting menu the setting in your remote or manuall change
Jun 25, 2009 | Samsung SyncMaster 203B LCD Monitor
Kodak easyshare c875 flash not working
I have the C875 - and had the same problem. It was out of warranty so I took it apart and found that the flex print wiring between the flash electronics and the flash unit was bad. It has 4 wire runs and at least one of them was broken. I cut the flex out and soldered in 4 fine insulated wires in its place. The flash works fine now. The hardest chore is taking the camera apart.
Warning: Wear rubber gloves since high voltage is stored in the flash capacitor even with the batteries out. I got zapped several times.
1) Remove all screws on the left side, right side, and bottom (including 2 inside the SD card door). Remove any SD card.
2) Remove the lanyard attachment fitting and then front and back covers.
3) Remove screws holding the metal center band in place. I recall there's a hidden one that's a long reach inside to remove.
4) Bend the band down to clear the tripod mounting hole and slide it off toward the front. Watch out for the fine speaker wires which will tether the band to the camera. I broke one and had to resolder it during reassembly.
5) You will see the orange colored flex leading to the flash. Snap out the flash.
6) At this point you could check the continuity of each wire to confirm the problem.
7) Cut/strip 4 wires to match the lengths of the runs. Use very fine insulated wires - 30AWG or so. Thicker wire might not fit.
8) Note the wire routing. Cut out and desolder the old flex print.
9) Solder in the new wires
10) Snap the flash back in place and dress the wires like the old flex print.
11 Reassemble. You can test it once you put the metal band back in place.
Ther C875 is a great pocket camera. One very much worth fixing.
Jul 14, 2008 | Cameras
Philco suitcase turntable / cd belt drive
Place the rubber band around the turntable and put a paper clip, bent up behind the rubber band. Start the turntable on it's spindle and you will be able to view that drive spindle on the right side, slowly pull the rubber band with the paperclip and drop over the drive spindle. remove paperclip and push turntable down seating it and replace the lock snap.
Jan 27, 2008 | Philco (R) Suitcase CD Shelf System
Zanussi FJD1266W Front Load Washer Logo
29 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
