Question about Seagate U6 (ST340810A) 40 GB Hard Drive
How to create slave IDE hard drive? - Seagate U6 (ST340810A) 40 GB Hard Drive
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 135 Answers
Http://www.wdc.com/en/library/eide/2579-001037.pdf
Check the link ....!!!!
Vote for me...!!!
Posted on May 31, 2010
What settings in the bios with maxtor as slve and quantom fireball as master
There are no settings in the BIOS for setting up master ans slave drives.
The hard drives have jumpers for configuring master and Slave drives.
If your hard drives are IDE/PATA hard drives and you intend to install these drives on the same IDE cable then you can set the jumper on Quantum drive as Master and the Maxtor on Slave.
I suggest that you install the Quantum as master on the 1st IDE cable and the Maxtor as Master on the 2nd IDE cable for maximum data transfer rate between the two hard drived.
Any other devices that are connected to these IDE cables will need to be jumpered as Slave devices.
Mar 28, 2012 | Gateway Computers & Internet
Jumper settings for master drive
if its a SATA hard driveyou dont need to set master slave the biggest capacity hard drive will set as master
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to IDE-1 means Pri slave escape then press f10 to save to cmos to restart
you will have to have master with slave set up
you can find the jumper location next to the power on a hard drive and the settings for plastic jumper location is usually printed on the top of a hard drive
IDE-0 means Pri master
IDE-2 means Sec master
IDE-3 means Sec slave
single or master :::::
master with slave ::'::
slave :::':
black line between dots is plastic jumper
note the plastic jumper is ' located at the rear of the hard drive between the EIDE and electrical lead/s
Oct 03, 2011 | Dell Computers & Internet
Installation of the drive and setting of jumpper to make it either as a master or slave
slave :::':
note the plastic jumper is ' located at the rear of the hard drive next to the IDE/SATA lead/s
Sep 27, 2011 | Seagate Barracuda 7200.7 ST380011A 80 GB...
How to set hd fujitsu MHZ2250BJ as slave ?
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
hope this helps
Aug 14, 2011 | Fujitsu MHZ2250BJ - 250 GB, 2.5", 7200 RPM...
HOW DO YOU SLAVE WD WD800JD HARD DRIVE?
Hope this helps
Jun 20, 2011 | Western Digital wd200jd-20pk 200 GB Hard...
How do you connect the cables or jumpers?
the leads from your ((motherboard to your hard drive)) they might have a 40 pin on the hard drive or a sata they just push on to make a connection make sure they have a secure connection
The BIOS is AMI. Under ADVANCED SETUP:
The options listed for 1st,2nd ,3rd Boot device include:
? single or master :::::
???????????????? slave? :::':
hope this helps
?don't forget to vote
Feb 08, 2011 | Western Digital Caviar SE WD3200JS...
Is there a slave or master switch on the hard drive want to hook up a external hard drive enclosure
hope this helps
Jan 29, 2011 | Hitachi Deskstar 7K500 500 GB Hard Drive
Need jumper settings for slave drive WD1600JS
slave :::':
hope this helps
Dec 10, 2010 | Western Digital Caviar SE WD1600JS...
Slave drive
If you are referring to creating a slave HDD, then it is not necessary - as this model utilizes SATA hard drives, there is no master / slave concept; it is in the order in which you connect the drives to the connectors on the motherboard. If your reference is to the Optical drives with IDE, then connect the slave drive to the middle connector in the IDE (flat ribbon) cable & ensure the jumpers on both the drives are set to Cable select (CS) - this would be at the rear end of the drive. Connect the IDE cable to the motherboard & the BIOS will automatically assign the drive connected to the end as master & the middle as slave.
Mar 16, 2010 | Dell OptiPlex 210L N (210LNDCELMIN) PC...
945GCT-M/1333 recognize Primary IDE Master as IDE 3 Master
Hello. Some motherboards set SATA1 as IDE primary master, for compatibility. Try connect the DVD RW to SATA2 or SATA3 Port.
Feb 26, 2009 | Computers & Internet
Seagate U6 (ST340810A) 40 GB Hard Drive Logo
110 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
Computer Links
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
