Question about Microwave Ovens
I lost the instructions for my Carlton C17MSS09 Microwave
I lost my copy of the instructions for my Carlton C17MSS09 microwave prior to setting up the microwave, and can figure out how to use the oven and set the time but can't figure out how to get the microwave to defrost. Grateful for any advice?
MicrowaveSvc
  • 9047 Answers
SOURCE: Setting clock on Westinghouse WST3501 microwave oven
Normally you would press Clock, enter the desired numbers, then hit Clock or Start. Try it with door open and with door closed.
Otherwise, contact Westinghouse Small Kitchen Appliances at 800-947-3745 or see http://www.saltoninc.com/contact/contact.html
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 13, 2007
SOURCE: 1985 GE Microwave Spacesaver Uninstall
I CAN'T FIND THE SCREWS TO ATTACH THE TOP OF THE SPACE SAVER TO THYE BOTTOM OF THE UPPER CABIONET, WHAT SIZE OF SCREW IS THIS. WHY DOESN'T IT HAVE A NORMAL SCREW, I ALREADY WENT THROUGH ALL THE SCREWS THAT LOWES HAS.
Posted on Aug 25, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: KitchenAid Superba Microwave/Oven, Microway Door message
This is usually caused by either a bad door switch, a loose door switch mount (which are pretty simple problems to fix) or occasionally a problem on the control panel.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you only need a switch, you can order one from us for $5 postpaid.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
Posted on Sep 27, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: Galanz Microwave Oven - Unable to disable child lock
Galanz's website seems to be useless. I tried finding information but kept being told "no data available." So while I can't tell you where to find the manual, here's something to try. Most microwaves get put into lock by pressing and holding one of the buttons for longer than normal, or by pressing one of the buttons several times in a row. Some ovens use the TIMER button. It won't be one of the number keys, but one of the function buttons. So start with a button, press and hold it for at least 5 seconds before you let go. If nothing happens then try another button. If that doesn't solve the problem, then try pressing each function key several times before moving on to the next one. If that still doesn't get it going, maybe a store in your area that sells Galanz will take a look at the book for you. The process should be the same for any similar model.
Posted on Nov 11, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Instruction manual for Belling Combi oven BEL-CJSS25
Did you try this?
Lines are open Monday to Friday 8am - 6pm and Sunday 10am - 2pm.
Belling Customer Care: 0871 22 22 503
Or maybe this?
Belling Product Helpline
0871 22 22 635
Product Helpline Open Times
Monday to Thursday
9am - 5pm
Friday
9am - 4.30pm
Spare Parts
0871 22 22 506
Posted on Nov 25, 2008
Manual for Carlton C179SS09
Go to manufacturer web site for download.
Sep 19, 2015 | Carlton Microwave Ovens
Instruction manual for carlton microwave C21CS09
Currys PC WorldHi Simon,
Thank you for getting in touch.
It's great to hear that you're satisfied with your microwave! My apologies - after searching (and believe me I searched everywhere) I have been unable to locate a manual for the Carlton C21CS09.
You have my apologies for the inconvenience caused.
Kind regards,
Matt
Apr 01, 2012 | Carlton Microwave Ovens
I lost the instructions for my Samsung combi microwave oven Model C105. How can I get another copy
Go to Samsung.com. Then go to products and then to your microwave. they have all the instructions for every thing they make. If still cant find it, go to contact page and 1-800 number and ask them how to get a new instruction book they should be able to direct you.
Mar 12, 2011 | Samsung 80092 Microwave Oven
I have a second hand Carlton microwave model no C25MW09 without an instruction manual. Can you help?
Most major manufacturers supply manuals online so if you were to log on to the manufacturer's web site, you may be pleasantly surprised as usually, if available, one is able to download, by model number, Customer Instruction Manuals, Dealer Network for spare part supplies and as required.
The information is normally free of charge.
Mar 01, 2011 | Microwave Ovens
Need a manual for a Carlton Microwave / Oven / Grill combination, model number C21CS09
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers for spare part supplies as required.
I hope this helps.
Jan 13, 2011 | Microwave Ovens
Where can I go to get a user manual for Carlton C17GSS09 microwave
Is thisa the 39 Pound special?
Try Curries in the UK they are cheap units made for sales as specials.
Beware tho if they break down tjhey are considered throw away.
Capacity - 17 litres, Microwave wattage - 700W, Grill wattage - 1000W, External dimensions WDH(mm) - 440x318x252, Stainless steel door with silver casing, Power levels - 5, Auto programmes - Defrost/cook, 8 auto cook programmes
The cheapest price Currys for CARLTON C17GSS09 is £39.00. For more information on CARLTON C17GSS09 please visit their online store.
CARLTON C17GSS09 is available from as little as £39.00.
Please rate my help++++Thanks for using FIXYA
May 19, 2010 | Microwave Ovens
Lost my instructions for my sharps microwave oven
just check the internet - there are many manuals websites, and sometimes even the manufacturer posts copies of their manuals
Get the model number for your microwave, then use on of the two sites below. hint: #2 Here are two sites: 1) http://www.usersmanualguide.com/sharp/microwave they will have your manual, but they'll charge you a few bucks for it 2) http://www.sharpusa.com/CustomerSupport/ProductDownloads.aspx These guys won't charge you a dime!!! Best wishes, Greg
Nov 28, 2009 | Sharp R-1470 Microwave Oven
I NEED THE INSTRUCTIONS ON HOW TO SET THE CLOCK ON MY MICROWAVE
To set the time just press CLOCK, then press CANCEL, then enter new time setting and press CLOCK again.
Apr 07, 2009 | Microwave Ovens
Need owners manual
I have a copy for you. What's your email?
Sincerely,
Dana
(dana@rbtd.com)
Jan 26, 2009 | Danby DMW1153 Microwave Oven
Instruction Book
Call 1-800-252-1698 and give them your entire model #.
Oct 02, 2007 | Westinghouse WST3501 Microwave Oven
Microwave Ovens Logo
131 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
