Question about Kodak EasyShare C360 Digital Camera
I was using the camera when the lens became stuck out even with new batteries, it has now managed to go back in but the lens wobbles a lot and the lens doesnt close at the front, i think i need to take it in to be fixed but im worried it will cost more than a new camera
    Brigadier General:
  • 11,967 Answers
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on May 31, 2010
I had my camera in my back pocket. I sat on it and cracked the LCD.
No way anyone can say what is defect. Not even sure the defect was induced while you cracked the screen and became worse during the "repair" or you did make an little error while putting things together. Even in my professional career as a repair engineer, Trying to find an error after a college could not get it fixed complete, were the most difficult jobs.
My best hint for this? start saving for a new camera. Will save you a lot of greef and a lot of time.
Apr 06, 2015 | Sony Cyber-Shot DSC-WX9 Digital Camera
How do you fix a stuck lens that will not retract when camera is turned off?
Hello, Remove batteries from camera, try pushing the lens back GENTLY with the palm of your hand, Notice I said "GENTLY" or you will cause more damage than good. If this won't work than take it for service / repair.
Best Regards, Russell
Jan 25, 2013 | GE X500 Digital Camera
Lens won't retract
You could try to gently pull the lens straight. If it's leaning to the right then pull the lens to the left. Don't use brute force but it's possible to realign the lens this way. If it works you'll hear a click and the lens will look straight. Switch on and see if it retracts. I'd only use this as a last resort because you can cause additional damage if it's overdone. It has sood success rate also
Sep 06, 2009 | Pentax Optio M20 7MP Digital Camera with...
Help! i can't turn on my camera!
If this is a new camera, take it back.
Sep 03, 2009 | Canon PowerShot A470 Digital Camera
L730 wont turn on, lens stuck half way
Hi, Lens is jammed, lens motor gearbox requires restting. If you in the U.K I can help you out.
p.m me at kiddo242@hotmail.com
Aug 09, 2009 | Samsung Digimax L730 Digital Camera
My camera will not come on. and also the lens is opened out and will not go back in, i have put several new batteries in it, and if i put batteries in it and close the battery door, and push on, the light...
my camera will not turn on or off lense stuck open put new batteries still nothing my daughter took picture with it everything went blank its the samsung s630 worked fine till today!!
Jun 08, 2008 | Samsung Digimax S630 Digital Camera
Lens cover only partially opens
This blog post outlines repair procedures for stuck lens covers. An A400 is used as an example. But it should be similar for the A430:
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
Mar 31, 2008 | Canon PowerShot A540 Digital Camera
Lens Wont Retract
mine does the same thing. i just bought it like 2 months ago too. what could it be? i don't want to have to ship it back, but it looks that way so far. i bought new batts. too and that did nothing. also i called sony, and spoke w/ tech support, and they had me take out the batteries, hold down the power button for 30 secs and then put the batts. back in. ??? i was like what will that do and she said reset it, but it still won't power on and the lens is out. it beeps like duhduh and then goes back off. it is making me mad. b/c also i have bought 2 sony PS2's and they both quit reading games. what is with sony? can someone help us w/ the camera problem? thanks!
Mar 24, 2008 | Sony Cyber-shot DSC-S700 Digital Camera
Optio 555
Is the lens totally stuck? Does it even move a little? Did you try to power cycle the camera?
Feb 27, 2008 | Pentax Optio 555 Digital Camera
Pentax Optio 555 - Fozen with the lens stuck-out
happened to me a couple times & after recharging battery, still stuck, so manually pushed it in when motor was running trying to close it.
Sep 23, 2007 | Pentax Optio 555 Digital Camera
Kodak EasyShare C360 Digital Camera Logo
76 people viewed this question
Top Kodak Cameras Experts
Tony
Jerry Greenberg
Jerry Greenberg
Are you a Kodak Camera Expert? Answer questions, earn points and help others
