Technical Support The Copier when turned on says: Call for service. Code: H3-00
  • leebill17 Nov 29, 2008
    call for sevrice
    H3-00
    so what is the problem & how does ti cost & which component is felt.
    thanks
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 30 Answers
The h3 code means the fuser isn't heating up. You can try and clear the code by pressing in order clear then interrupt then zero key, then interrupt again. The display should go balnk. Enter 14 and hit start. Then hit CA. This should reset the code and allow the machine to try and warm up again. If the code comes back you will need parts replaced.
Posted on Feb 25, 2009
I have the same problem model is toshiba e-studio 162... do you have a solution?
Posted on Sep 13, 2008
    President:
  • 2,072 Answers
What is the make and model number please.
Posted on Apr 08, 2008
2 Suggested Answers
007tech
  • 95 Answers
SOURCE: Sharp Copier AR -407 Error code H3-00
H3-00 means there was a problem in the fuser unit of the copier - a temperature problem. The correct temperature is not reached within a certain time.
It could be a thermostat or thermistor problem - both monitor temperature. you could remove the fuser unit and make sure these items are clean - no build up on them. there should be a center and side thermistor.
You can reset the error code in SIM mode by pressing the following keys one after the other "P" "interupt" "C" "interupt" then 14 and start/copy key. confirm if required. make sure the copier is restarted afterwards.
If the error persists then you may need new thermistors.
Hope this helps.
Posted on Apr 12, 2009
Canon2202ir E0000-000 This error code deals with the fuser unit. It is saying that the fuser is not warming up. It needs to be reset in service mode.
How can I enter service mode on canon ir 2202? - Fixya
www.fixya.com/.../t25374950-any_one_help_me_enter_service_mode_...
Jan 19, 2015 - In standby mode, press the "Settings/Registration" key. 2. Press the "Reset" key. 3. Press the "Back" key. 4. Press the "Settings / Registration" ...
Error Code ir 2202n - CopyTechNet.com
www.copytechnet.com > ... > Copier Technical Discussion > Canon
Nov 22, 2014 - 3 posts - ‎2 authors
... pls help me ....i know how to enter service mode but ......pls help. ... Copier Technical Discussion · Canon. [Error Code] ir 2202n ... ir 2202n. how to print jam history in ir 2202.......i dont know pls help ... mm its a new machine , i need to know how to enter the service mode if u please ... Press the "Reset" key. Error Code canon image ronner 2202N
Aug 21, 2014
Canon IR 2200 error E000001-002
Jun 18, 2009
More results from www.copytechnet.com
Dec 21, 2015 | Office Equipment & Supplies
H5-01 copier service code
you can not reset
need to take technical service
Sep 24, 2013 | Office Equipment & Supplies
Service Code - Fucntion Problem within the copier - Code SC541 Serial # of Mach J0122404128
this is a fuser code
try this:
1. Press the clear mode key (yellow key)
2. Use the keypad to enter "107"
3. Old down clear/stop for at least 3 secunds. (red key)
4. Enter the service mode.
5. Exit all the way and turn off.
6. Turn ON.
if that fails, contact technical support. It will be necessary to replace the fuser roll and the thermistor
Jan 24, 2011 | Gestetner 2212 Digital Imaging System...
Error code E000013-0001
getfile.asp?rid=1258 February 2, 2005 getfile.asp?rid=3215 Product : imageRUNNER C5800 / C6800 Title : E013 code and Waste Toner Full message Question :
The copier shows an E013-0001 and "Waste Toner Full" message. The Waste Toner Bottle has been emptied and SW1 is operating properly but the code and the message are still appearing on the display.
Answer :
The counter for the Waste Toner Bottle needs to be reset back to zero in Service Mode.
Enter Service Mode level 1 by pressing * 2 8 *, select Copier > Counters > MISC, then highlight WST-TNR, press Clear - the counter will zero out.
Power off the copier, turn the copier back on, the Waste Toner Full message on the display should clear out.
Canon USA, Inc. Systems & Technical Support Division 1-800-528-2830
Dec 22, 2010 | Canon imageRUNNER C6800 Copier
Error sc 452 shown on my aficio 452 color copier how to rectified
sc 452 is a thermistor error code for the fusing unit of the copier. Try pressing these buttons in sequence. (yellow key) (1).(0).(7) (red Clear/stop key) and hold the red key down for 5 seconds. When the 3 or 4 boxs appear, turn your copier on and off with the main power switch. If the error code comes back then contact the seller of your copier and ask for technical service.
Oct 12, 2009 | Ricoh Aficio Colour 3006 Color Copier
My b/w copier suddenly stop working when an error code sc545 appears on the screen and since then it has refuse to work. The moment you turn it on the functional problem error code sc545 appears on the...
You need to check 3 cause for that error:
- hot roller thermistor out of position
- fusing lamp broken (can you see the lamp going on at startup?)
- thermostat broken
If you are just a user, without any technical knowledge, i advise you to call a Ricoh Support Service.
Aug 03, 2009 | Ricoh Aficio AP410N Laser Printer
Minolta EP5420 not operating
Hello sir; The error code you display "Cd" it means the duplex unit have problem, check with duplex unit , see wherre got paper jam , need roller to replace.
Jul 31, 2009 | Minolta Office Equipment & Supplies
Photocopy of demende we contacted technical support
OK, what is the error code under the "Copier needs Service Tech"?
Jul 04, 2009 | Toshiba e-STUDIO 282 Black and White...
Service code C0B52
1. Turn off copier 2.Disconect finisher cable 3.Turn on the copier . If it works properly turn it off &reconnect finisher cable then turn it on .
Apr 06, 2009 | Minolta EP4000/5000 CS/PRO Copier
A-400 CODE AND IT DON'T RUN COPYSTAR CS-1510
Hello sir; the A400 code at this model copier, means laer motor problem, bad laser unit or power supply board. you better find a local service provider in you area to take care of you.
Jan 03, 2009 | Copystar CS-1510 Copier
229 people viewed this question
jasbo
jasbo
