Question about Toshiba 37HL67 37 in. LCD HDTV
WILL NOT TURN ON
I JUST BOUGHT THIS TV YESTERDAY AND FOLLOWED INSTRUCTIONS. REMOTE IS NOT WORKING AND THE YELLOW LIGHT IS BLINKING. I READ THAT ONCE THE YELLOW LIGHT FINISHES BLINKING THAT THE REMOTE WILL BE ACTIVE. IS THIS TRUE OR WOULD I HAVE TO DO SOMETHING ELSE TO IT?
  • 81 Answers
You might have to reset the code on the remote or do a code search
Posted on Apr 08, 2008
6ya staff
SOURCE:
I have a sanyo hdtv with integrated tuner and the
(Some universal remotes do not work with newer televisions, so the following instructions may not work)
Turn on the television.
Hold the 'CODE SEARCH' button for 3 seconds until the LED light is solid red.
Press the 'TV' button; the LED will blink once and remain solid red.
Point the remote at the TV and slowly and repeatedly press the 'ON/OFF' button until the TV turns off. (The LED will blink once each time you press the 'ON/OFF' button.
Once the TV turns off, press the 'ENTER' button; the code will be stored in the remote and the LED will turn off.
The remote should now work with the TV; test it out to see how it works.
(The remote may be too old for your TV; if the above instructions don't work you may need to get a newer remote.)
Sep 03, 2014 | Televison & Video
I cannot find a solution to getting our remote to work. TV model is Flatron. The remote is Zoom Universal.
WIth out knowing which Zoom remote you have I have condensed the instructions. You should be able to program your remote in one of two ways.
First try entering the codes one at a time below. Those are the code numbers for LG television for Zoom remotes. Just follow the step by step instructions and one of those codes should work your tv. If by chance none of the codes work, I have also included instructions on how to do a code search to search for your televisions code..
At the bottom is the link to Zoom where I found this information.. Good luck!!!
ZOOM LG CODES 004 005 006 012 019 056 057 058 082 155 156 171 172
Instructions for programing remote by entering codes
1. Manually turn on the TV.
2. Press and Hold the CODE SEARCH button until the
INDICATOR LIGHT lights, then
release the CODE SEARCH Button.
3. Press and release the TV button.
(The INDICATOR LIGHT will
blink, then remain lit.)
4. Enter the code using the
Number Buttons. After your
code is entered, the INDICATOR
LIGHT will turn off.
5. Aim the remote at your TV and
press the OFF·ON button. Your
TV should turn off.
Note: If your TV does not
respond, try all the codes for
your brand.
If your TV does not respond after you have
tried all the codes for your brand try
searching for your code by following the steps below.
Code Search Option for Programing your Remote
1. Turn on the device you wish
to program.
2. Press and hold CODE SEARCH
until the INDICATOR LIGHT
illuminates, then release CODE
SEARCH.
3. Press and release the device
button for the device you are
programming (TV, VCR or
DBS·CABLE). The INDICATOR
LIGHT will blink once, then
remain lit.
4. Press and release OFF·ON until
your device turns off.
Important: You may have to press
OFF·ON up to 200 times.
5. When your device turns off,
press the ENTER button, and the
INDICATOR LIGHT will turn off.
link to website http://axistronix.com/suppor.html
Dec 04, 2010 | LG Televison & Video
I cant control my AIWA TV WITH A jumbo universal control.THE CONTROL NUMBER DOES NOT WORK that is given with the instructions
Have you tried the auto-code search?
Unfortunately, you can't teach this remote new codes, so if none of the AIWA codes from the manual work, and you run through this auto-program sequence and it doesn't work, there is no other solution for your TV.
To have the remote try each TV code it knows one at a time, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Press the ON/OFF button slowly and repeatedly until the TV turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the TV turns off, press the ENTER button to store the code and the LED will turn off.
I hope that helps.
Nov 19, 2009 | Innovage Jumbo Remote Control
I have a living solutions jumbo remote and im trying to program it but it does not have a code search button like every manual i seem to find on the internet says to hold what do i do?
Here are the code search instructions for the Innovage Jumbo Remote that you are looking for.
  1. Turn on your TV.
To program the remote for your VCR, repeat this process starting with turning the VCR on, then follow the steps substituting the VCR button for the TV button.
I hope that helps.
Nov 06, 2009 | Innovage Jumbo Remote Control
I need the codes to install on a new tv
To search for the control codes that will work on your new TV, follow these steps:
  1. Turn on your TV.
  2. Press and hold down the CODE SEARCH button for 3 seconds until the red LED lights up solid red.
  3. Press the TV button on the remote. The LED will blink once and then remain solid red.
  4. Press the ON/OFF button on the remote slowly and repeatedly until the TV turns off. The LED will blink once each time you press ON/OFF.
  5. Once the TV turns off, press the ENTER button to store the code. The LED light will turn off, and your remote is programmed for your new TV.
Hope that helps.
Oct 07, 2009 | Innovage Jumbo Remote Control
I bought a universal jumbo remote and i followed instructions i to program it to my Jvc tv but it does not work can u help?
Make sure you try every code in the list for your JVC TV.
The codes for your Jumbo Universal Remote to control a JVC television are 013, 054, 055, 060, 065, 067, and 089.
To program your remote by entering a code, follow these steps:
  1. Turn on your TV.
  4. Enter the first set of 3-digit codes from the list. The LED will blink once every keypress. After the 3rd digit, the red LED will turn off indicating that the code was recognized for the device. If the code was not compatible, the LED will flash several times and you need to return to step 2 to try that code again or to try the next code in the list.
  5. After the LED has turned off, aim the remote at the TV and press ON/OFF. If the device turns off, you have used the correct code and the remote was successfully programed. If the device does not power off, return to step 2 and try again with the next code in the list.
  1. Turn on your TV.
I hope that helps.
Sep 24, 2009 | Innovage Jumbo Remote Control
I have a innovage jumbo universal remote and I have lot the instruction to code it to another tv. Can you help me Please
To find the code that works with your TV, use the auto-search function.
  1. Turn on your TV.
I hope that helps.
Jul 16, 2009 | Innovage Jumbo Remote Control
Disney DTD 363-Car 13" tv/dvd
I have xfinity Comcast cable connected to my Disney's CARS TV/DVD combo. I did not have a remote for it because I bought it at yard sale without it. I used Comcast's remote control. I followed their "Searching For Your Code" instructions. #1-turn on your TV. #2-hold SET till red lite blinks twice. #3- enter 9-9-1. The red lite blinks twice. #4-press nd release the CH+ key until TV turns off. #5-once it turns off press SET key nd red lite will blink twice. #6-Now u have locked in ur code. Press power and TV should turn on. Then CH+,CH-,VOL+, and VOL- should work for ur TV.
Apr 16, 2009 | Disney DTD1363-CAR 13" TV/DVD
Need codes for a AKARI 14" color TV IC-1494RAK
1. Turn TV on
2. Press TV key on remote.
3, Press and Hold magic button until red light blinks twice, it will blink once and then twice.
4. enter 991 red light will blink twice
5. Hit the power button
6. Aim the remote at the TV and press the channel plus button until the TV turns off.
7. Hit the magic button as soon as the TV turns off to store the code.
Hope this works for you!
Jan 03, 2009 | One For All URC 7740 Remote Control
Kidz Remote
RE: Programming a Kidz Remote by Kissel By helpmedave (Guest Post) 1x1.gifthe procedure to program the remote is as follows.
Find the setup button recessed between tv and cable buttons. Use a toothpick to press the setup button until the led blinks once, keep holding it until it blinks twice then release. press tv or cable button then enter the 3 digit code for the device you want to try. the light will blink twice if the code is valid. ( yeah i know you don't have the codes ) (me neither ) if you successsfully program it to control a device, you can then program each button as follows. hold setup button until light blinks twice.press tv or cable as needed. press 995 the led will blink twice . press the button to program. enter channel number you want (may have to enter 2 or 3 digits 08 008 etc)press setup light will blink once.m select another button and repeat to program all buttons you wish to program.to lock in settings, press setup until led blinks twice. good luck.Posted on 08/09/2007
Jul 16, 2008 | Televison & Video
Toshiba 37HL67 37 in. LCD HDTV Logo
251 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
