Burners on our Brivis Buffalo 52 Ducted heater aren't getting gas
We have a Brivis Buffalo 52 Ducted heating system. I can light the pilot light (manually) but when the controller tells it to flame up nothing happens - i.e the burners don't light - they don't seem to have any gas going to them.
    Top Expert:
  • 12,650 Answers
Test thermosat for proper operation ie-broken wire-power if good jump stat and check if unit goes on if it does than stat internal problem or wiring problem and needs replacement or repair --if stat good check fan safety/high limit sensor if good would need to check and test thermocouple thats the tube that the pilot flame burns on may be enough to keep pilot burning but not enough to open valve for heat demand
Posted on May 31, 2010
I have a brivis buffalo 85 ducted heating system, from last few days it doesn't come hot air only fan is running. pilot lamp also not with flame. ignation is working. I was turm blue color lid to pilot...
you need a new thermocouple. u can either get one from a plumbing store but the can be a bit fiddley to fit or u can get the proper Brivis one it just pulls out and u put the new one in. then u have to re light the pilot light. make sure u hold it down for at least 45 sec to make sure that it is getting hot enough when u release it it will stay alight then turn gas valve to the on position
May 26, 2014 | Heating & Cooling
I have a Brivis Buffalo 85, pilot light is on main burners will not ignite when turned on? It seems like gas isnt allowed to bar which turns on main burners
Usually a thermocouple or similar device is employed to allow fuel to flow once the unit sees that there is sufficient heat to ignite the fuel. Otherwise it can be a fuel valve that "sees" an unusual flow of gas which sets off the safety.
May 07, 2014 | Honeywell Programmable Thermostat Heater
Hi, I have a Brivis Buffalo. The heater will not run when the fan is set to auto even though the pilot light is on, and the wall controller shows heat on. When I set the fan to on, it just blows cold air....
My buffalo heater has just started doing the same thing about two hours ago, so will watch for any answers you get. My heater is over ten years old, maybe the heating element has "died"?
PLEASE can someone out there help us????????
Aug 02, 2010 | Heating & Cooling
Hi. Brivis Buffalo not igniting
Okay,
first and for most do not light burners manually, if that chamber is filling up with gas and you light that sucker you risk the chance of causing an explosion or a blow back that will burn you. What you need to address is
-are the burners clean
-is there proper gas entering the gas valve
-is there proper gas to the manifold
-is the flue product being exhausted properly
-is my exchanger sooted up
-is my gas valve working properly
pm me for walk through steps
May 27, 2017 | Heating & Cooling
Brivis Buffalo 85 ducted heating unit, fan is always on
On the unit outside there is a button that says "push man. pull auto" if it is set to push man then the fan will go constantly.
Sep 22, 2009 | Heating & Cooling
Brivis Buffalo 85 central heating unit - fan stays on problem
I have exactly the same problem. When I have the cover off there is a red light on, from what I can tell is the "Over Heat Fan" this seems to keep the fan on, and because it is in error prevents the system igniting. Haven't got a solution yet it only happened last night. Stu.
Jun 11, 2009 | Heating & Cooling
Brivis ducted heater making a banging noise every time it lights the burners
The heating system has a number of burners which must ignite as soon as the heater starts. When one or more burners does not fully or partially start properly, unburnt gas fed to that burner accumulates in a small pocket until is is eventually ignited causing a small explosion. This condition is caused by restricted/blocked burner jets. The gas jets are small and easily fouled by spider nests or other items sucked into the system. You will need to have the heater serviced by a qualified gas plumber.
Jun 05, 2009 | Heating & Cooling
Brivis central heating fan will not switch off runs continuous
brivis wombat 2P 20 ducted heater, gas fires up but fan not starting
Any suggestions...???
May 12, 2009 | Heating & Cooling
Heating & Cooling Logo
1,312 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
