Question about Sewing Machines
When I sew I found the bottom side of the colth accumulation of thread from bobin .Please fix the problem and tell me the remedy.
  • 40 Answers
Top tension is too loose.
Posted on Jun 01, 2010
When I sew it only sews about 4 stitches the top thread breaks & sometimes the threads are all tangled in the bobin area. I found a small spring next to a larger spring loose. Where does the little...
You may want to take it to be looked at by a professional if there is a part loose.
I have constant problems with thread breaking and being tangled in the bobbin area with this machine. It can usually be remedied by adjusting your tension. Also, class 15 bobbins stink for this machine (yes, it says they're compatable, but they seem to be 1/8 of an inch too shallow and constaly become unthreaded from the bobbin casing). Try SA 156 metal ones.
Aug 16, 2010 | Brother LS-2125 Mechanical Sewing Machine
How can you fix the under threading of a sewing
Check the ovious things first make sure you needle isnt broken... then make sure there isnt any thread twisted inside your bobin housing. make sure bobin is inserted correctly if those things dont help it could be an issue of timing in your machine... I work as an embroidery operator in a factory setting and those things usually help..
Apr 08, 2010 | Singer 3116 Simple
How do I tighten the tension on the bobin thread I am quitiing with invisible thread on the top and dark blue on the bottom, the bobin thread shows. I don't want that
you can either increase the bottom tension or reduce the top tension .. you will notice a little screw on the bobin case ... that screw adjusts the force on a small flat spring which provides the bottom tension (the thread goes under the spring when properly threaded) .. .. tighten that screw a little to increase bottom tension .. you can pull thread thru the bobin case to get a feel for how much tension you have ... you dont have to turn the screw very far to make a significant difference .. try just 1/4 of a turn at a time .. remember where it was originally set so you can put it back when you are finished with your present project .. the greater the bottom tension the less bobin thread will show at the top ... if you get the tension too high then you might see some puckering as you sew ..
Jan 03, 2010 | Sewing Machines
The uper thread dose not catch the bottom thread
If there is a screw on the side of bobbin case try tightening it up.This usually worked on my old machine.
Sep 18, 2009 | Kenmore Drop-In Bobbin 505S-21BH...
Problem with the tension when embrod.
lower your top tension down, as it is tighter then your bobbin thread and also tighten your bobbin thread, this is done by the small screw on the bobbin holder, also you can try using the older metal bobbins these are the ones with the small holes around the top and bottom shank, but please make sure that they are the larger size bobbin, and only go very slow at first, try just in sewing mode first or just wind it over by hand.
Aug 12, 2009 | Janome Memory Craft 10000
Machine is not sewing properly
use larger needle, check bobin thread, bobin should go one way, if it bunches up switch dirrection the bobin turns
May 23, 2009 | Bernina Virtuosa 160
Thread bunches from the bottom while sewing.
Hello, sewing is a part of my income and I've encountered this problem before and managed to fix it on my own, by trying out these different things. I re-threaded the machine and checked to make sure that the tension is not too loose. Check the bobin and the sack the bobin fits into, sometimes it comes loose too, click it back into place and re-do the bobin. adjust the tightness of the stiitches, I usually put it on 2 .5 - 3. Hope this helps. Good luck to all. Nefishakh@hotmail.com
Nov 16, 2008 | Singer 5050 Mechanical Sewing Machine
I have model 8280 and the bobbin thread keeps bunching up on the bottom. I have tried to rethread it but it keeps happening.
i think your putting in your bobin backwards,
to check put your bobin in and hold bobin , and bobin case by thread if it unrolls its backwards,
hope this helps!!
Jul 26, 2008 | Singer 8280 Mechanical Sewing Machine
Singer tiny tailor TT700
www.Sewusa.com
click threading.
scroll to the SINGER brands.
Click of tiny tailor 700.
this should help you.
Sep 27, 2007 | Singer Tiny Tailor TT700
Sewing Machines Logo
54 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
