Thanks potex18! Sorry, may i verify on few things with your advise below? (dear experts, appreciate your advise as well) a) upon booting the Cd, it prompts to install OS,and will delete all my files in C: drive. If i proceed, will it delete all my files in c?or i just simply ignore it? sorry, i'm a bit concern to keep my data and a bit confused on why they put that kind of notifications in the first place, if its not deleting the files...pls advise? b) to copy Mup.sys, but it takes a while for the new pc to detect my hddisk..will try it once it appear. Hi guys, Apprecite for ur expert advise pls? I boot my laptop (Acer Travelmate 4050 series) but it was halted during the booting process (no response after i key-in my windows password). I plugged out the power cord to reboot. (normally on 2nd attempt it will run/reboot smoothly). Unfortunately, it shows one error screen, and give selection to choose to run in safe mode or as per normal.(along with several other options). Selecting any of these selections, the system halted again when executing Mup.Sys . I tried with 2 method : a) chg boot sequence to cdrom -> use bootable cd (provided when purchase the laptop) -> it prompts "this will install windows in ur primary disk,Note:all data in primary disk will be destroyed " q : some poeple said this will not delete the files in my primary disk, is it true? b) i took out the harddisk and put it in external case.but when tried to acess the data, was prompted with message "e:\ is not acessible, error performing inpage operations " pls help to advise, should there is still hope to retrieve my data? Solution #1 posted on May 31, 2010 potek18 Rank: Wiz Expert Rating: 82.62% , 42 votes Hi. In order to resolve this issue. Boot in to your CDROM drive while the operating system disk is in there then run the recovery console. This will put the Mup.sys file back to your computer. Possible cause of this is corrupted mup.sys file which is essential in booting the harddrive. Another troubleshooting is, since you took out the harddrive and put it in your enclosure look for computer with the same operating system and copy its mup.sys file into your harddrive. This file is located at C:\Windows\System32\drivers. That will do the trick. May 31, 2010
  • jen_nashadi May 31, 2010
    it does resolve the issue~!! (^^) big fan of fixya now~!!
    Brigadier General:
  • 3,917 Answers
Yes it will delete all your files in C. You can skip this step to allow windows install on top of the previous installation so that all the files are present. If you select the option then every file on c drive will get deleted and you will loose your data.
Let us know if you have something more to know else please accept the suggestion.
Thank You.
Posted on May 31, 2010
    Hi e-guru,
    previously the options were only to accept the installation or exit.
    -installations > leads to deleting all my data & install new OS
    - exit > leads to ejecting my boot cd and back to square one..
    i was unable to get mup.sys for version of Xp home,so i tried to repair it using chkdsk commnd
    (hdisk attached to external enclosure, and perfrom using another pc)
    open completion, i still unable to view my files attcahed on my desktop (view through new pc).
    thus, without the new mup.sys, i put the bootable cd in my problematic laptop,attach back the hdisk, and reboot. Only then, it can reach to the OS. and this time no more recovery console..
    Thanks for your advise e-guru ( and potex18 too ~) . hope this helps the rest who hit the same issue like me. Good day,guys~
I have 2002 Durango with 360CID engine. #8 cylinder does not fire.
Had a similar problem years ago. Since everything is electronic very hard to do self diagnostic. Make sure the boot is completely into the "Rotor" cap. Are these original wires? Not sure if some still use graphite or all copper these days. Worst case is carbon build up on # 8 piston. compression test is 1st thing. Was plug anode clean or pitted? May not be a whole bunch of help but ck these things out 1st. Best advise is think simple before you freak out.
Mar 02, 2014 | 2002 Dodge Durango
I have a Ropper Referigerator model # RT18bkxkoo. I am facing following issues: 1. The freezer section is working but I have noticed some ice developed at the back wall. 2. The referigerator section...
were
werw
Sorry to hear about your problem. Sounds like you have a defrost issue. Hence your unit is not defrosting. All of this apply's if your freezer side has ice on it. If not. you have other issues
Here is a list of some things that can go wrong.
1. Defective heat coil
2. Defective defrost timer
3. Defective defrost sensor
4. Defective Fan
5. Defective compartment inlet damper (on some models)
You should call a service company to resolve your issue.
Since I tried to help you, Please help me and Rate/Vote on the response. Thanks
dfg
Dec 27, 2010 | Roper Refrigerators
Hi When I start up my Acer Aspire L100 mini desktop, it makea clicking noise, which emits from with the computer and then the computer freezes with the screen below. Also, sometime I have to power off on,...
You can solve this problem by:
-- cleaning system junk
-- optimizing computer services
-- repairing registry
-- defraging registry
-- clearing browsers junk
do these things with some secure tool such as Intel Software Partner Reginout.
Also remember to uninstall and reinstall updated drivers for your devices. Thanks
Nov 10, 2010 | Acer Aspire L100 PC Desktop
1993 Isuzu NRR Commercial Truck stops really hard.
Sounds like the rear brake shoes have come loose. Check all springs are intact and secure. Could be a few other reason's this is the first check it they are I can advise further.
Sep 01, 2009 | 1993 Isuzu Pickup
Aspire 5315-2326 enter Current password problem
i think is a factory fault most systems comes with factory passwords like that.
now u must find out if its a hard drive password which i dont think is thru.if its a bios password then u will need to erase the bios chips which is a risky thing to do if u r not an expert.
my advise,
hard drive password can not be recovered all u do is change a hard drive.
bios password can be erased if u meet an expert.
i suggest u give them d 100 dollrs n get it fixed.
hope this helps
Dec 27, 2008 | Computers & Internet
System Boot Up Display changed from English to another language
Go into Control Panel> Regional and Language Option,Double Click
*Click on the Languages tab
* Click on the Details button
Under Default language, select English : If English is not a choice, you can click Add, and add it.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 12, 2008 | Computers & Internet
Yahoo e-mail service
Links aren't going to get you to customer care, however, this number, talk to a human:
Customer Care
http://help.yahoo.com/
1-866-562-7219
anaanymous
Sep 25, 2008 | Yahoo Mail
LG L342i
Hi Guys,
Thanks for all the advice from your experts,we realised their was no such software available for the L342i, we always suspected as your last expert advised that we had to email photos to ourself, an expensive excercise, 144 times 25 cents, i should of used my camera instead of a phone. My advise to everyone is make sure software comes with your phone before making a purchase.
Thanks
Bob Beale
Aug 28, 2008 | Cell Phones
Philips webcam
i would contact the manufacturer asap and let them know your situation.. if you check their website, they may have a new firmware update for compatability issues with vista.. unfortunately, there have been many things not vista compatible and you just have to buy new things and be sure to verify before you buy it that it's compatible with your os.. sorry.. hope this helps
Feb 22, 2008 | Computers & Internet
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
