Question about Whirlpool Duet GHW9150P Front Load Washer
Torn seal on Duet
Can you please send me the pdf service manual on how to replace the main seal inside the duet washer. Ours was inadvertently torn. thanks
my email address is goombaman@rogers.com
  • 3 more comments
  • goombaman Apr 08, 2008
    Thanks for your fast response.
    I did have the boot replaced once already ( yes =, another torn boot), but I dont recall the technician pulling the machine out and removing the torx screws from the back to gain access. I could swear that he somehow just accessed the boot from the front if the machine. Is this possible? The reason I ask is my machines are installed under a counter and never have they been pulled out for repairs. Always repaired from the front.
    excellent, thanks for your advice.
  • Anonymous Sep 15, 2008
    I have a torn door seal (bellow). I have already received the part. It did not come with instructions. Can you email to me please??
    My name is Mike Derby. Email fivecaps3@yahoo.com
    Thanks.
  • Anonymous Dec 23, 2008
    Thanks it worked very well. Finished with test 100%
  • Anonymous Dec 26, 2008
    need instruction to replace seal/ bellow duet washer
  • 5,911 Answers
If you are talking about the door boot, follow these instructions:
This advice is for the Kenmore Elite and Whirlpool Duet FRONT LOADER style washing machines. A lot of concerns have been raised about door bellows molding, mildewing, and/or ripping and needing replaced. A replacement bellow isn’t cheap (prices vary, but are around $75-80), so hopefully these helpful steps will eliminate the need to call a repair service and pay the additional labor charges. This is a repair of MODERATE difficulty. Just follow these steps:
1. Unplug the washer.
2. Remove the washer top panel by removing the three torx-type screws (or 7mm) where it attaches in the rear of the washer. The panel should slide back, and then lift off.
3. Remove the operator console by removing the dispenser and the scew(s) behind it. Take a putty knife and insert it under the console seam right above the door. If you push in slightly while pulling outwards the panel pops off. Use care not to pull or damage any of the wiring. You can leave the wires attached and simply lay the console across the top of the washer out of the way.
4. Locate the wire hoop retainer around the rubber door boot. It is located behind the rubber seam where it attaches to the door frame. Follow this hoop around to the bottom of the door opening and locate the wire tension spring. Gently pry this spring apart and pull the wire hoop from the groove. Pull the rubber boot from the frame and push it inside towards the wash tub. You will also have to remove the door boot from the fill tube on the left hand side of the door opening. There is a small wire clamp holding it in place.
5. Remove the three screws that hold the door latch assembly in place. This is on the right hand side of the door opening. You can leave the latch in place as long as you remove the screws and push it inside slightly to remove it from the front casing of the washer.
6. Remove the door by removing the screws holding the hinges in place. Use care to support the door hinges when loosening. They can bend. Set the door aside in a location where it will not get stepped on or broken.
7. Remove the lower kick panel under the door. There are 3 screws under the bottom edge holding it in place. Sometimes the panel can stick. A slight tap on either side will knock it free.
8. Remove the front washer casing by removing the four remaining screws that are holding it in place. There should be two at the top and two at the bottom. Set the front casing aside.
9. Remove the old door boot by locating the large clamp that attaches it to the wash tub. Loosen the 7mm nut and the boot will detach from the tub. Also remove the boot from the fill tube coming from the dispenser.
10. Install new door boot on the wash tub and install clamp. There should be instructions that come with the door boot with guide marks to ensure you align it correctly. Once you have the boot in place, tighten the clamp enough to where it is snug. DO NOT over-tighten or you may damage the tub and or clamp. In most cases the clamp will break.
11. Once you have the boot in place, re-install everything in the reverse order of how I explained to disassemble. Make sure you connect the door latch assembly BEFORE you re-install the outer portion of the door boot. Also, make sure you install the boot completely over the fill tube. There should be a ridge on the tube where to stop. Sometimes the tube is not inserted all way into the boot and water will leak behind it. The clamp is always difficult to get back in place. If you cannot get the clamp to go back over the tube, you can live without it. Some newer models do not have them installed. Just make sure it is a snug fit where the rubber boot fits ALL the way back to the plastic ridge on the tube.
12. When you get the point where you are ready to install the door boot back over the frame of the door opening ensure you fit it snugly all the way around the door. Beginning at the top of the door, start inserting the wire hoop back into the groove. Make sure to wire spring points towards the bottom. As you work your way around the door to the 4 and 8 o'clock positions, you will need to maintain some constant downward pressure while pulling the spring apart in order to snap it back into place. It would be advisable to use a second set of hands to hold the wire hoop in place while doing this as it has the tendency to want to come out of the groove.
13. Once the door boot is back in place, re-install the operator console and washer top.
14. At the operator console, select DRAIN SPIN, NO SPIN and press any button under OPTIONS 4 times (has to be the same button, though). This will place the washer in diagnostics mode. You should hear the door latch lock and "C00" will be displayed on the console. The washer will run through a series of tests filling the tub, tumbling, draining, and then a final spin. If you do not wish to wait for the test to complete you can press CANCEL at any time. The test checks out everything and takes about 15 minutes. Look for any leaks.
I hope you find these instructions helpful and good luck to you. Let me know if you need further assistance.
Posted on Apr 08, 2008
  • Jeff Rockwell
    Jeff Rockwell Apr 08, 2008
    Yes, it IS possible to work through the door opening, but a bit more difficult, because the door opening provides less room. You can try removing the lower kick panel under the door and working from underneath as well as through the door opening, but again, it's often difficult to manipulate the seal to get it seated properly around the wash tub. It can also be difficult to get the inner clamp back in place and tightened properly. If you don't wish to move your washer due to its location I fully understand. This may be the only choice you have, but it may take you a little longer. The suggestion I provided makes it easier to access, but requires more disassembly. You can still use most of the procedures, though. Let me know if you need further guidance.
    PS It is recommended that you secure electrical power to the washer. If you can't reach the outlet due to it's current location, turn off at the breaker.
Front loading duet whirlpool washer (1.5 yes old) front seal is torn. Can you please send me instructions to replace it myself? Thanks.
http://adcxns1.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/eab852a13fbc842085256aa200643dd6/$FILE/Duet%20Job%20Aid.pdf
above is a link to a service manual that will help guide you thru this repair.This is a tedious repair that can be tough for the homeowner ,there is a lot of disassembley needed to get to where you can reinstall the new door boot correctly. removing the old part is easy but to install the new one will take patience dont try to cut corners or you will be doing it over again Hope this Helps Good Luck
Dec 29, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Can I get pictures/diagrams and instructions on removing the mcu board(duet ghwn150pw3) to check out f 06 error? Thanks
Please see the following Whirlpool Service Manual for the Duet Washer.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/eab852a13fbc842085256aa200643dd6/$FILE/Duet%20Job%20Aid.pdf
Oct 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Torn bellows on whirlpool Duet
We are not authorized direct contact with consumers, but I can offer you a link that provides step-by-step instructions on how to replace the door bellow:
http://www.fixya.com/support/r385211-replacing_door_bellow_whirlpool_duet
Please read through the link thoroughly before starting any repairs. If you have questions, or require further assistance, please let me know. NOTE: If the link isn't working, you can find it under my profile under my "Tips and Tricks". I hope this helps you.
Jun 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Duet bellows gasket manuel
I dont have a link but I have the full service manual in PDF format please post your email and I will send it to you
Apr 24, 2008 | Whirlpool Duet GHW9150P Front Load Washer
HELP WHIRLPOOL DUET
post me your email here and
I will send you a PDF of the service manual
Thanks Gary
Apr 04, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Service manual
Whirlpool GHW9150P front loader washer keeps stopping mid cycle witht he F06 code. I can get through an entire cycle if there are only two or three items in the washer. My thought is it needs a new motor drive. would you agree?
How to replace the door bellows seal ?
I need some one to tell me how to install the rubber seal on a bosch maxx Eurowasher front loader washing machine. Part of the seal ripped off so water leaks out. Its only 6 months old and its not covered by warranty.
Jan 24, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Duet washer leaks during use; rinse cycle?
could have a bad boot seal please post your email here and i will send you the service manual on how to change it
Jan 23, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
1,075 people viewed this question
Dan Webster
Dan Webster
Sal De
