Question about Seagate U6 (ST340810A) 40 GB Hard Drive
How to install operating system?
How to install operating system in hard drive with no operating system? because it displays boot disk failure
  • 60 Answers
If you have pata hdd try set it's jumper to second no.
Posted on Jun 04, 2010
After installing a new hard drive in my desktop computer, it still does not work. It says no boot device available. Sata's 0 & 1 installed but 2 & 3 uninstalled
No boot device available means the boot device hard drive on your system has no bootable operating system installed on it, or it is faulty. In the BIOS setup program, does the computer recognize the hard drive you installed, and is it included in the boot device list? If you installed a new hard drive because of a failure of the C: drive, the new hard disk does not come with an operating system. You have to install that on the new hard drive from the manufacturer's system restore disks. SATA channels 1 and 2 are just the connections on the motherboard for devices, and usually have a hard drive on one connection and a cd rom drive on the other. Giving the model and manufacturer of your computer might provide more clues.
Feb 04, 2017 | Hard Computers & Internet
Disk boot failure on compaq presario S7300CL
Hi friend,
The message, "Disk boot failure" often means that the OS is corrupt and needs to be re installed. Try restarting the computer twice or thrice and check whether you can log in to the system. If the same error displays again then you have to re install the OS. But re installing the OS leads to data loss from the hard disk. So at such kind of situations you need a data recovery software to recover your data back. Yodot Hard Drive Recovery is a wonderful data recovery software which performs recovery after disk boot failure.
Jan 12, 2012 | Computers & Internet
When I switch on my pc,it tells me disk boot failure insert system disk and press enter. I have XP proffessional sp3 but only have a xp home disk.
If your computer has just been formatted, your computer might require you to insert the boot CD
to be able to run it. You might hence get the error message Disk Boot Failure- Insert disk and
press enter displayed on the screen every time you will try to run it. This might be linked
to:
* 1. The boot options not correctly set in BIOS
* 2. A non bootable CD is found in your CD drive
* 3. You do not possess any bootable device
* 4. You have installed a new hard disk
* 5. The hard disk is not properly plugged
* 6. Your system files have been infected
Get more help and information for Disk Boot Failure. Hope this helps you....
Jan 29, 2011 | Microsoft Computers & Internet
Hard disk is detected in BIOS setup, but after boot it shows "DISK BOOT FAILURE, INSERT DISK" So what can i do now
it means insert your copy of windows operating system to finish the installation if you already have a operating system on your hard drive and if you dont wish to remove it when in bios scroll down Adavanced bios features and change settings on first boot device
Aug 27, 2010 | Computers & Internet
About disk boot failure
Hi!
Disk boot failure means that your BIOS can't find the master boot record of your computer which resides in the hard disk or a floppy disk.
This indication means that your hard disk drive is not detected by your BIOS or their is no operating system installed with it.
Have a nice day!
Jun 02, 2010 | Foxconn WinFast K7S741MG Motherboard for...
No windows on a hard disk and cannot boot or display desktop
If there is no Operating System on the hard drive, the computer has nothing to boot.
You must install an OS(operating system), such as Windows or Ubuntu.
Let me know if I misunderstood your question.
Mar 18, 2009 | Computers & Internet
2 hard disks
Because you have a dual boot system, you have two 'C' drives, which in fact is a good idea if you get a system failure on the drive you are using, you can select the other and still view any files on the other drive through my computer.
f using XP, right click my computer, then properties, then click advanced tab, then startup and recovery listing click settings, at the top system startup, select the default operating system, then click EDIT button, then delete the value that points to the other hard drive more than likely listed as disc1, disk 0 will be the one you have connected as master boot hard drive
Aug 29, 2008 | Microsoft Windows XP Professional With...
Istalling windows
Start up problem
This generally indicates a hard drive failure. You can try to do an operating system repair with the recovery or operating system disc, but most likely you will need to replace the hard drive.
When you see the IBM screen you need to enter the boot menu. On this screen it tells you what to press to get to the boot menu. Place the recovery or operating system disc in the drive, and select the CD drive from the boot menu, then follow the directions. If the repair doesn't work, then reformat the hard drive and install a new operating system. If you have any issues during or after the format or install, then the hard drive has failed and will need replaced. You want to do a full NTFS format, not the quick format, if the hard drive is bad, it won't format.
Aug 08, 2008 | IBM ThinkPad T30 2366 Notebook
Regarding boot failure
If you can boot with a Windows 98 floppy boot disk, then do so, you need to run scandisk. It is also possible that your hard drive has failed, you can go into the bios and see if it is being recognized.
Jul 20, 2008 | Microsoft Windows 98 for PC
Seagate U6 (ST340810A) 40 GB Hard Drive Logo
137 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
terminalcon
John Anderson
John Anderson
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
