Question about Seagate U6 (ST340810A) 40 GB Hard Drive
What is conductor cable? - Seagate U6 (ST340810A) 40 GB Hard Drive
    Scholar:
  • 77 Answers
Thank you for your question.
The conductor cable is the "flat ribbon cable" that connects the Hard Drive to the Motherboard on IDE devices.
Kind regards
Posted on May 31, 2010
Why my honda 2000 generator will not work with surge guard with transfer switch. model 40250
Are you using a 4 conductor cable from your generator to your transfer switch? Or is it a 3 conductor cable? If it is a 3 conductor cable then try jumping the neutral to ground in the plug of the cord.
Good luck,
Marty
Jul 15, 2014 | Honda Electrical Supplies
I need a wiring diagram for a Cooper 6482 dual control
Hi John,
I'm an electrician and can help you with this question.
The *best* way to plan for this fixture is to install a "3-wire" cable (romex, bx, etc.) designated as "14-3" where "14" is the size of the conductors and "3" is the number of insulated conductors. A "three wire" cable consists of 3 insulated conductors (white, black & red) and an uninsulated or bare conductor. Sometimes, you may find that the cable has 4 insulated conductors and instead of a bare conductor it will be covered with green or green with a yellow stripe insulation. This 4th wire is the ground wire (insulated or not). Either type of cable is acceptable for use.
By installing a 3 wire cable, you will not be required to use a "special switch" or an "RF switch" which are often much more expensive to purchase and more involved to install. You can use two independent switches, consisting of a variable dimmer for the light and a speed controller for the fan, simple "snap" or "toggle" switches or any combination of both if you install into a "2 ganged box". If you opt to install a single gang box, your switches will be needed to be on a single strap (often called duplex switches) and your choces for control will become limited - and likely more expensive, too.
If you run a 3 wire cable, you can install your choice of switches, if you install only a 2 wire cable, you will be forced to use special switches or a standard switch and a pull chain on the fixture (this option is only available to you if there is a constant power source at the fixture). It will cost a little more for the 3 wire cable, but it will provide the most flexibility when selecting fans / switches.
I hope this was helpful & good luck!
Feb 26, 2013 | Electrical Supplies
I have an HP 2510 printer. I cannot use it to fax because once I plug the phone jack into the printer I get a busy signal. If I plug the jack into a phone, it works fine. How do I get the printer to...
Hi irwinbadin,
HP fax products are designed so that other telephone equipment can be connected on the same line as the fax. The unit must be connected first using a two-conductor fax/phone cable like the one that shipped with the HP product. Using a four-conductor telephone cable may cause problems receiving faxes or calls.
There are two different types of phone cables. There are two-conductor phone cables like what originally shipped with the HP fax product and there are four-conductor cables. HP fax products are designed to work with a two-conductor phone cable. Look at the end of the cable and verify that it has only two copper leads or wires. Replace any four-conductor cables with a two-conductor cable. Only two-conductor phone cables should be used to connect the all-in-one to the phone line.
Figure 1: The difference between a two-conductor phone cable and a four-conductor phone cable
Step one: Connect the phone line to the fax
The fax will have two or three sockets (or jacks) for phone lines. Some of these may have a removable plastic plug in them. These sockets will be labeled with text, To Wall Jack , or with a graphic of the wall jack. See Figure 1 below.
Plug the two-conductor telephone cable that came with the HP product into the telephone wall jack. Then, plug it into this socket as shown below.
In areas with above ground telephone lines and electrical storms (lightning), it is a good idea to purchase a telephone line surge suppressor and connect it between the telephone wall jack and the fax. This will help prevent damage to the fax from a lightning-caused power surge on the phone line.
Step two: Add other phone-line devices
To connect other telephone devices, use the other socket (or sockets) on the fax. These are identified by text or with a graphic of a telephone and/or computer.
Connect a caller ID unit between the fax and the telephone.
Use the information below that matches the devices you need to connect.
Fax and telephone
Connect a single-line telephone to one of the added sockets on the fax. The telephone will share the same phone line as the fax. See the illustration below.
Fax, answering machine, and telephone
When a telephone answering machine and telephone are connected, connect the answering machine to the fax and then connect the telephone to the answering machine as shown below.
Fax and computer modem
To use a fax and a computer modem on the same phone line, connect the fax to the computer modem. The modem socket on the computer may be labeled Line or Wall jack .
Fax, computer modem, and telephone
To use a computer modem and a telephone with the fax, connect the computer modem to the fax. Then, connect the telephone into the second phone line connector on the computer modem or the third fax socket (if it is available). The image below shows how to connect a computer and a telephone to a fax with two sockets.
Fax, modem, answering machine, and telephone
The image below shows how to connect a computer modem, answering machine, and telephone to a fax. Connect the computer modem to the fax, then connect the answering machine to the computer, and finally, connect the telephone to the answering machine.
If the fax has three phone line sockets instead of two, some of the devices can be connected to the other phone socket on the fax.
Hope it helps.
Thank you for using FixYa.
Jun 27, 2011 | Office Equipment & Supplies
What are the jumper settings on the drive for the following? Cable select Slave Master
For Slave/Master set up most hard drives have a little diagram on them showing you where to put your jumpers for master and where to put the other one for slave. All hard drives are different. But on your diagram it should say "MA" for master, "SL" for slave and "CS" for cable select.
For Cable select you have to set jumpers to cable selected which should be on the diagram on your hard drive. You will need an 80 conductor IDE/ATA cable. The master conductor is at the end of the cable and the slave conductor is in the middle.
Mar 25, 2011 | Computers & Internet
How to install 80 conductor cable? because when i turn on my computer it displays no 80 conductor cable installed
It means you're still using the 40 conductor cable from the MB IDE to the
hard drive. The 80 Conductor Cables are used to take advantage of the newer
Ultra/ATA-66 and up IDE drives. (They will still work with the 40
conductor cable, but slower.)
Jun 01, 2010 | Microsoft Computers & Internet
Can a combination microwave/convection/exhaust fan appliance which draws 1500 volts and has a 3 prong grounded plug be hard wired to panel and what size of copper wire to use
I assume that you mean 1500 Watts ?
which is 6.25 amps UK or 13.6 amps US
1.5mm UK 14 Gauge US
The National Electrical Code [NEC] requires their own cable sizing for premises wiring. Refer to the NEC rules to determine building wiring, as this page relates to electronic equipment wiring. For reference, the ampacity of copper wire at 300C for common wire sizes
14 AWG may carry a maximum of 20 Amps in free air, or 15 Amps as part of a 3 conductor cable.
12 AWG may carry a maximum of 25 Amps in free air, or 20 Amps as part of a 3 conductor cable.
10 AWG may carry a maximum of 40 Amps in free air, or 30 Amps as part of a 3 conductor cable.
8 AWG may carry a maximum of 70 Amps in free air, or 50 Amps as part of a 3 conductor cable.
Feb 18, 2010 | Microwave Ovens
How do you strip insulation form uf electrical wire
I use a sharp knife and slice off the outer covering on each side of the cable. With practice you can "feel" the outer insulation of the conductor and make the knife slide along it without damage. At that point I simply pull the two conductors out of the covering and use my wire stripper to expose the bare ground wire. When stripping the ground, I use a oversized hole on the wire stripper to keep from scoring the wire.
2 conductor is easier to strip than 3 conductor.
here's another
I've never tried tearing it apart. That sounds like it would be hard on the conductors to me.
steve
Dec 13, 2009 | Hardware & Accessories
Thermostat problem
Buy some more thermostat cable with the same number of conductors inside it that you need. Twist the wires in the wall to the conductors on the new cable you just bought. Wrap the connections with electrical tape and pull the new cable with the old cable, starting at the furnace. You will then have all brand new conductors to fit to your new thermostat.
Jan 12, 2009 | Honeywell Electronic Programmable...
Oven has 4 conductor power cable, moved to house with 3 conductor
Unless your cooker is totally different to the norm, then yes you can use 3 core cable. assuming you are in the u/k, then the following applys.Brown is live-Blue is neutral, andGreen/Yellow is earth.
Depending on the total wattage of the cooker, you will need to use a min of 6mm twin and earth cable, If in any doubt, consult an electrician
Please leave feeedback
Dec 03, 2008 | Whirlpool RBD305PD Electric Double Oven
MSI P4MAM2-V BIOS
Check your Ide data cable it seems 40 pin conductor cable .
Replace them with 80 pin conductor cable.your problen\m has gone.
Oct 13, 2007 | MSI P4MAM2-V Motherboard
Seagate U6 (ST340810A) 40 GB Hard Drive Logo
76 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
Steve
terminalcon
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
