Question about NEC MultiSync MT1050 Multimedia Projector
How to adjust color on nec projector - NEC MultiSync MT1050 Multimedia Projector
3 Suggested Answers
vortash
  • 431 Answers
SOURCE: Pink cast in images from NEC VT540/440 projector
Sounds like one of those problems only cureable with expert knowledge of for example Chroma feed , Lcd function , lamp luminence, not to be a killjoy but it sounds like this is one for the engineers an estimate should be free and even if you dont have it fixed you'll know whats wrong if you want to do it yourself providing you have adequate training of course .... Regards vortash
Posted on May 10, 2009
sam_ajayi
  • 74 Answers
SOURCE: Need Help! Have a NEC VT660 projector that is
check the cable connetor
Posted on Nov 18, 2009
Red color seperating
If you mean the red light is displaying offset from the blue and green then the red LCD panel inside the projector needs to be physically adjusted. If you take the projector apart you'll notice that the light source is split into red, green and blue light by passing through an optical splitter. Each color then passes through it's own LCD panel. Next, each color is joined back together by another light splitter to be projected to your screen. The red LCD panel is misaligned.
Jun 03, 2012 | NEC MultiSync MT1050 Multimedia Projector
My NEC projector MT1065 display colors okie, but with black (or dark) image, the screen display a greenish wash in the center of screen. This happen just the same with new lamp. It appears as if the...
It sounds like the polarizer filters are starting to ware due to heat build up, if you remove the lid and the main booard, there is a white plastic mesh cover over the lcd panels, you can remove this and adjust the polarizers for the red, green and blue lcds to adjust the black level, there are 3 hex bolts holding a plastic frames which in turn hold the pre polarizer filters, buy slightly loosening the bolt you can slide the plastic frames left or right to adjust the levels, buy you should mark the position before you start. this may not solve the problem but may help to improve it, unfortunately these projectors require special software to make electrical adjustments which is hard to get hold of.
Aug 17, 2011 | NEC MultiSync MT1065 Multimedia Projector
The whole projection is yellow in colour and we need someone to have a look at it. Can you suggest anyone in the Brisbane metro area?
I can possibly save you from having to call someone in.
2 things that you should check before you have someone called in to look at your projector.
1. Color correct in the system menus, you can individually adjust the color levels in this menu. Increasing and decreasing the values can help relieve the yellowness presented.
2. If at all possible, buy a replacement bulb for your projector and if it doesn't work, simply return it.
May 31, 2011 | NEC VT670 Multimedia Projector
The projector is an NEC model VT590 and is connected to my computer for use with a SMARTBoard. In the bottom left hand corner a pink colour is starting to grow inwards. In the upper left hand corner, there...
It is not the smartboard, lamp or the computer as well know, it's the projector itself. This may not work but you at least need to try press the auto adjust button on the projector and then adjust the clock/phase in the menu. If not you will need to send in to NEC it could by the color wheel. Usually they have a warranty for a couple of years.
Jun 05, 2010 | NEC MultiSync VT590 LCD Projector
May 08, 2009 | NEC Office Equipment & Supplies
Pink shade more in NEC WT-610 PROJECTOR
Using the on screen menu, check the hue or wall color settings. [Hue]
Varies the color level from +/- green to +/-blue. The red level is used as reference. This adjustment is only valid for
Video, Component and TV standard inputs (not valid for RGB and DVI digital).
Using the Wall Color Correction [Wall Color]
This function allows for quick adaptive color correction in applications where the screen material is not white.
The following nine options are available.
• OFF • Blackboard
• Blackboard (Gray) • Light yellow
• Light green • Light blue
• Sky blue • Light rose
• Pink
Dec 30, 2008 | NEC WT610 DLP Projector
NEC MultiSync MT1050 Multimedia Projector Logo
175 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
