Question about Philips SA3125\02 MP3 Player
CAN'T OPEN MY I-POD
When i switch on mii i-pod it only gives the ligts& switch of itself so what can i do
  • 35 Answers
http://www.nikeexpert.com/
Posted on May 31, 2010
Cracking & popping radio
The volume control pod needs to be flushed with electronic control cleaner, unplug and remove back, attach supplied straw and give the pod two or three good blasts in the tiny hole and rotate volume back and forth rapidly to reach desired results.
May 20, 2012 | Vintage 1930's Replica Cathedral Radio and...
2005 dodge caravan ac runs cold then after run a mile it turns slightly cool
Most car compartments that house the A/C coil, & Heater core, are in the same air movement container. Does it get cool the same time that your Water tempature guage starts to indicate the motor is warming up like it would for the heater???? If so, there will be a "dash pod" switching valve on the incomming heater core supply hose. The vacuum supply tube to it is broken, or the pod itself is "frozen" open. When your A/C kicks in, your dash control directs vacuum to that pod, to close off the hot antifreeze running thru that container.
Sep 01, 2011 | Dodge Caravan Cars & Trucks
I run a pod HD 500 into the amp and It breaks up, like there is a blown speaker sometimes.
The Marshall is a super clean acoustic amp.
The POD is overloading the amp.
Try the electric guitar input and keep the gain on the amp down, keep the EQ level and use the POD and the end volume to adjust the final volume.
The normal inputs is for a low output acoustic pickup - the POD is a high output electronic source.
Start with the Marshall gains low and get the clean sound good, then work on the gritty sound.
The amp is voiced for a sweet clean sound - if you want grit'n'ball change to a 50w Marshall valve head and a 4 X 12 cabinet.
Horses for courses
Mar 07, 2011 | Marshall Amplification Marshall AS100D 2x8...
When i switch my pod on the rebuild db screen appears n th pod gets frozen pls help :( i ve to reset my pod everytime but this too doesnt help me :(
Hello!
My names are humphrey franklin. 4rm nigeria, pls, i need solution to my iriver pod. I tried to add mre musics, in my pod, it will enter, but, it'll never play. Pls, what do i do about it? My e-mail, humphrey franklin@yahoo.com
Mar 03, 2011 | iRiver E30 MP3 Player
Will not turn on. Power cord has green light when not plugged into pod, blinks lightly when plugged in.
The blinking is indicative of a failure within the pod itself. Take the pod to your local PC shop and have the techs there transfer the drive into a new enclosure, if it works there you're in luck, buy the new enclosure and you're up and running again. If not the drive itself may be the issue, if this is the case, respond with your location(Country, State and City) and I will be happy to connect you with a pro in your region to assist you with retrieving your data.
Hope this helps FixYa,
Chris
Sep 29, 2009 | Acomdata 250GB Ext Rocket Pod HDD USB Hard...
Cruise control will not engage
You will see 2 cables going to the carburetor. One will be the throttle cable and the other is the cruise. Follow the cruise cable back to the vacuum pod and you should see the vacuum lines feeding the pod. You can remove the line at the pod and place another line in that sprout and **** on the hose. If the pod contracts its good, if you **** air the pod has a hole and it is defective.
If the pod is not defective remove the vacuum line feeding the pod and check for holes.
Aug 23, 2009 | 1999 Mercury Villager
Cahnge language for apple i pod nano 8GB
turn on your ipod, go to 设定, and then go to 语言, and then click 英语. and if that does not work... if you know how to get to setup go there and click all the languages.
May 27, 2009 | Apple iPod nano
Regarding the single shot pod and filter
the machine might or might not have had the pod filter based on manufacturing date. If you did not have one it can be purchased on Breville USA web site for $10.
Jan 22, 2009 | Breville Die Cast 800ESXL Espresso Machine
Volume varies by itself on the Yamaha htr5840 Receiver
The pod that controls the volume knob is either very dirty or needs replaced! (If you remove knob you will see the shaft of the volume pod go into the pod itself) You may try cleaning with a can of high pressure air by spraying short bursts of air in and around the pod area! If that doesent work you will have to replace the volume pod!...Please rate my response! Thank You!
Jan 11, 2009 | Yamaha HTR-5840 Receiver
I pod nano
open I tunes, plug the i pod into the computer, when the i pod shows up on the left hand side of the screen, right click it and you should get an option to rename it
Sep 19, 2008 | Apple Mini IPod
Philips SA3125\02 MP3 Player Logo
57 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
