Question about Zapco Reference 650 Car Audio Amplifier
...storing noise detected from my
  • 632 Answers
Storing as in Distortion? If that's the case lower the output gain from your amp until it is suitable to you ears. It might be all the way open, besides this should be adjusted system to system.
Posted on May 31, 2010
  • Ed Paje May 31, 2010
    Storing as in Distortion? If that's the case, lower your output gain using a flat head screw driver, it could be all the way open. Use a larger gauge ground wire to the body (chassis) and keep it short in length.
Install my amp
Go to this link and see page 47
http://www.zapco.com/files/Download/DCRef.pdf
Jan 18, 2013 | Zapco Reference 650 Car Audio Amplifier
Noise
Hi
Use a low pass line filter to reduce spark interference .
Mar 04, 2008 | Alpine MRP-M450 Car Audio Amplifier
How many rms does my amp have.....??????
4-channel, 4 ohms: 4 x 50 Watts
4-channel, 2 ohms: 4 x 90Watts
Stereo, 4 ohms: 2 x 180 Watts
T.H.D. : Frequency Response: 10 - 25KHz
S/N Ratio: >90dB
Channel Separation: >50dB
Dimensions: 13"L x 9.9"W x 2.25"H
Zapco I450 Zapco I 450 iForce Series 4 Ch. 360 Watt Amplifier
May 22, 2011 | Zapco I-450 IFORCE SERIES 4 CHANNEL CAR...
I need a manual for a zapco PEQ 9 band (old school) equalizer. can you help me?
i got a wiring paper that comes with the peq plug,its not a manual but it shows how to wire up a zapco peq
Nov 07, 2010 | Zapco Car Audio & Video
I have a zapco refrence 750.2 has no sound output when bridged but works fine when i run a speaker to each channel. any ideas on whats wrong?
check your settings on your stereo and the amp make sure you have changed to 1 ohm on the amlifier for a briged connection to a subwoofer and change from lpf to hpf on the amp there should be a switch.
Jun 07, 2010 | Zapco Reference 750 Car Audio Amplifier
High Tempature
Sometimes the gas regulators get dirty and the best thing to do is to replace the regulator and hose. Most hardware stores carry replacements.
May 24, 2010 | Weber Genesis Silver B Grill
During scheduled recording for 1 1/2 hours, chanell changes
I called panasonic and they sent me @ no charge a cd update that fixed my problem. I talked to
John @ 1-800-211-7262 ext 5070. He seemed very knowledgeable and spoke ENGLISH!
This cd may fix other problems for this model.
Dec 26, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Top left side screen shows video 5
Get the original Sony remote. Select TV or the Video input you want to use. Then press the Display button to make the text dissapear.
Jerry G.
Nov 13, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Gurgling noise
gurgling noises are not unusual - after all there is a gas/liquid mixture being circulated
Sep 04, 2008 | Sub-Zero 650 / O Bottom Freezer...
ZAPCO 9.0
Go here first http://www.zapco.com/ Good Luck
Aug 06, 2006 | Zapco C2K-9.0XD Car Audio Amplifier
Open Questions:
Zapco AG650 Amp clicks on and off and doesn't want to "turn-on" I need your help. I have a Zapco AG650 Amp that I am looking to replace a DEI 1200.5 Amp in my current car audio system. The DEI 1200.5 currently works, but the AG650 does not. The following is the equipment that is installed: Alpine 7815 Deck MB Quart Separates in the front and back 2 - Digital Design 10" 4 Ohm Subwoofers 4 Gauge Power and Ground No Stiffening Capacitor in the system Monster Cable interconnects 125 Circuit Breaker 8" away from the Optima Yellow Top Battery Installed in a 98 Honda Accord The question I have is that upon installation of the Zapco Amp, all it does is keep "clicking on and clicking off" once it was hooked up to the power, ground and remote wire and the deck was turned on. The 3 fuses on the exterior of the amp are not blown after pulling each one and visually inspecting them. The amplifer was then connected to an external 120v A/C to 12-15 V DC power source to see if it would turn on after the amp didn't work. But no change to the amp, it still continued to "click on and click off." A suggestion was to move the ground wire. However, after testing it with an external power supply and the original amp continues to work after it was re-installed, I have my doubts...but I'll give it a shot...is there any other suggestions that may have been overlooked? Or is the amps power supply not working? Any help to solve this problem would be greatly appreciated. Thank you for your help.
Jan 12, 2009 | Zapco Reference 650 Car Audio Amplifier
Zapco Reference 650 Car Audio Amplifier Logo
63 people viewed this question
Top Zapco Car Audio & Video Experts
xxxxxx xxx
Are you a Zapco Car Audio and Video Expert? Answer questions, earn points and help others
