SOURCE: anyone got new codes for starview 3 on ntl as from 17 12 08 at 5
New codes are 00 = 9C 0E 3C 8D D6 73 80 28
SOURCE: starview 4 displaying channels
HAVE U PUT NEW SOFTWEAR ON WITH USB PEN IF NOT GOOGLE IT PUT NEW SOFTWEARON PEN STICK IT IN THE BACK PRESS HDD LOAD SOFTWEAR AND THEN WILL WORK
SOURCE: just got a new starview the box super usb not
sky sports and sky movies have moved to nagra 3 so there probably won`t be a fix soon/ ever for those!! have you used the V1.12 file yet? you must d-load it to a usb stick and then flash the box with it(insert at the back of the box,but make sure the box is switched off from the back).hope this link helps
http://dooby2oons.googoolz.com/the-box-usb-starview-4-f11/starview-the-box-usb-update-guide-t253.htm#1382
SOURCE: cant access hidden menu on starview boxes even
Type the code 1570 when you access the set up menu. Then click ok on nagravision you will then be able to access the codes for you current supplier.
Hope this helps.
SOURCE: cant get the sports channels on new starview 5 box
Press menu,while on installation press 1570,changes to nagravision,press ok,changes to the provider i.d.,scroll right to telewest 5a01.change codes using handset.
telewest codes 5a01 updated 12/10/09
00 CF 53 0C 33 79 61 71 85
01 52 5E 8D 45 FC 75 F6 4A
