Question about Acer Aspire 3000 Notebook
Where the cmos located - Acer Aspire 3000 Notebook
  • 2,973 Answers
It is always on the motherboard.
Posted on May 31, 2010
  • 1,675 Answers
Hi the CMOS is really called the BIOS, which are the same things the bios holds all the information on how the machine boots and what the system has to load before it reads the hdd, the BOIS/CMOS are not removable this is a small chip that is soldered to the motherboard if you are having problems with it , it might be the on board battery at fault and not the BIOS/CMOS , but if you have tried to upgrade the BIOS/CMOS and has failed then there could be a possibility that your laptop is now u/s, sometimes you can get it back by taking off the on board battery for a few minuets but like i said if it was a upgrade to the BIOS/CMOS and has failed then there isn't much use....hope this helps
Looking on the motherboard of ACER Aspire E5-471-37TL but I cant find the CMOS location.
See link below of its for another similar model but location should be the same
Jan 02, 2015 | Acer Aspire Computers & Internet
Location of cmos battery
These are the most basic signs your CMOS battery is going dead and will be your ultimate test of the battery
http://www.bing.com/images/search?q=cmos+battery+images&qpvt=cmos+battery+images&FORM=IGRE Bios setting are saved in cmos batteries
make cmos battery has charge and is not loose
cmos battery images
How to replace the CMOS battery in your laptop http://www.youtube.com/watch?v=MTg8qhWKNpA
Feb 19, 2013 | Computers & Internet
Would like to reset CMOS on inspiron 6000 - will not boot up to BIOS How do I reset CMOS
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS
scroll to load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart this will reset your cmos after you make any changes in BIOS press Esc then press the F10 button save to cmos to restart
cmos is located in BIOS or
you will need to remove the cmos battery for 15-30 mns this will reset your cmos
im not sure where its located on this motherboard or whether its soldered in
hope this helps
Aug 08, 2011 | Dell Inspiron 6000 Motherboard - W9259
Where is blinking amber light located on dell
Replace CMOS Battery.
1. Locate your CMOS battery
2. Obtain battery information
3. Removing the battery
4. Removing the battery
5. Enter CMOS values
This link will guide you. CMOS
Thank you for posting..
Jun 30, 2011 | Dell OptiPlex GX520 PC Desktop
Reset power on password jumper
Motherboard Jumpers:
Some, but not all, motherboard manufacturers provide a set of three jumpers on their motherboards that provide you with the ability to clear the Bios/CMOS settings, thereby allowing them to be reset. For the most part this is used when the Bios/CMOS data becomes scrambled and you need to clear the Bios/CMOS in order to return the computer to a functional state. This same procedure, however, can be used to clear passwords from the Bios/CMOS setup. Typically a jumper will be found across pins #1 and #2 as the default position, and by shutting the computer down, unplugging the power cord and then moving the jumper so that it is across pins #2 and #3 will clear the Bios/CMOS settings.
Here's an example of a Supermicro PIIISEA motherboard.
piiisea_jump.jpgAs you can see from the picture, we have added two small red arrows. The arrow to the left denotes the location of the "Clear CMOS" jumpers, while the red arrow to the right denotes the location of the CMOS battery.
Here are the procedures if the jumpers are present on the motherboard:
  • Locate, if possible, the instruction booklet for your motherboard. If you cannot locate the booklet, then user the motherboard references on this site to locate the manufacturer and see if a manual is available there. You may also want to closely examine the motherboard itself.
  • Shut down your computer and disconnect the power plug.
  • Now identify where the jumpers are located, then check the present pin location and the location of the jumper on those pins to determine their default location. As an example, the default location on the above motherboard is to have the jumper across pins #1 and #2. Write it down!
  • Next, move the jumpers from the their default location (Example: from across pins #1 and #2 as above) and then place the jumper across pins #2 and #3.
  • Leave the jumper in place for 20 to 30 seconds and then return it to its default location.
  • Now plug the power cord back in and restart the computer.
  • When the computer begins it's startup (boot) process, tap the DEL, F10 or F1 key, (whichever is appropriate for your computer) to get into the Bios/CMOS setup. If you need more detailed information as to how to get to the Bios/CMOS setup, follow this link. Bios Basics
  • Once into the Bios/CMOS setup, look for a section or area to set the Bios/CMOS to its default settings. This will return the motherboard to either its basic or optimum settings depending upon the motherboard manufacturers settings. You will then need to verify certain settings, such a CPU and memory as well as hard drive type and size recognition. If you need more information regarding these settings, follow either of these links: For an AMI Bios or for an Award Bios.
  • After making any final adjustments, save your settings and restart the computer. The Bios password should be gone and the Bios set to its optimum settings.
If the "Clear CMOS" jumpers are not present or not available:
The procedures for clearing a Bios/CMOS without jumpers is essentially the same as those given above when they are present, it just takes a little more effort.
  • Shut down the computer and disconnect the power plug.
  • Locate, if possible, the instruction booklet for your motherboard. If you cannot locate the booklet, then use the motherboard references on this site to locate the manufacturer and see if a manual is available there. You may also want to closely examine the motherboard itself.
  • Now identify where the battery is located on the motherboard. It will be approximately 1/2 inch in diameter.
  • Normally these batteries are held into place with one or more small clips over the face of the battery. Carefully lift the battery out of its socket and set it aside. Note: Some batteries are actually soldered to the motherboard, so take that into consideration and be careful.
  • Leave the battery our of the computer for about 20 to 30 minutes and then return it to its socket.
May 28, 2010 | HP Compaq dc5100 Small Form Factor PC...
CMOS Battery Location in IGO5581
Opem back side cover of laptop.
You find 1 motherbord chipset there.
On motherbord you find cmos cell .
Aug 29, 2009 | Computers & Internet
Cmos battery location
open the top key board then under this key board you located the cmos battery and jumper settings..good luck
Jun 26, 2009 | Acer TravelMate 2300 Notebook
Reset bios password
You need to locate the Cmos battery, not the jumpers, this is not a desktop.
Locate the Cmos battery, disconnect the battery for ten seconds, and Bios will reset to factory default.
Jan 03, 2009 | HP Compaq nx6110 PC Laptop
CMOS
The cmos on the Pavilion is going to be in one of three places, and will be one of two styles of battery. The cmos style will be either a large watch type battery about the size of a nickle located in a slot on the mother board, or in a yellow or greenish pouch with two wires leading to a connector, located under a cover on the bottom of the machine, or under the keyboard.
Aug 28, 2008 | Computers & Internet
Acer Aspire 3000 Notebook Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
