Question about Hotpoint WMA30 Front Load Washer
Hotpoint wma30. Drum not draining water. Have
Hotpoint wma30. Drum not draining water. Have been able to drain drum when outlet pipe lower then drum only. tried again but no drain & all lights on display
  • Hotpoint Master
  • 43,501 Answers
If you are having a problem with your top load washer then check out this tip...
Washing Machinehotpoint wma30.  Drum not draining water.   Have - 2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on May 31, 2010
I recently replaced the pump and my wma30. It has worked again since for over six weeks. Now it gets to the drain/spin cycle and it can be heard to start but fails. the spin does not start and the drum...
hi im not an expert but recently had the same problem. i had a blockage in the drainage pipe its fairly straight farward to fix and you tube show you how. hope this helps.
Sep 09, 2011 | Hotpoint WMA30 Front Load Washer
I have a hotpoint first edition wma11 which is not draining and water is still left in the drum when the cycle has finished. Any ideas as to what the cause of the problem is and how this can be...
first check outlet hose at sink end grease can build up on connection at trap under sink,if this is clear first dcoop out as much water from drum and lay outlet pipe flat into low basin to syphon water out ,when drained make sure the machine is isolated,take off lower back panel if you look in you will see black sump hose attached from bottom off drum to pump remove sump hose from drum by undoing clamp and insde is plastic float ball check to see if anything is blocked if clear re attach and remove pump take off pump housing (three screws) check if anything is in pump if clear change pump
Sep 08, 2011 | Washing Machines
Hotpoint WMA76 - been on a normal wash cycle but wont spin to drain water - cycle finished, drum full of water and cant empty. How do we empty it to open machine?
Remove drain outlet hose from point where it discharges into waste pipe, and lay the hose down into a bucket or bowl, this should let the water syphon out, enabling you to open the door.
Dec 29, 2010 | Hotpoint WMA76 Front Load Washer
My machine has stopped working..I need to drain the water out...where will the drain pipe be on WT741 Hotpoint please...Thank you
The drain outlet hose is located at the bottom rear left of washer.
Once you have got the water out, I suggest you check the pump filter.
Remove the lower rear panel of washer.
Remove large black hose from bottom of drum at right side.
Clean filter inside the hose.
Remove black hose onto pump, and check for blockage or obstruction here as well.
Please rate my solution.
Thankyou.
Jan 14, 2010 | Washing Machines
Machine does not empty new pump fitted
Check the drain outlet hose for a possible blockage, also check the filter located inside the large black hose fitted to bottom of drum.
Thanks.
Nov 05, 2009 | Hotpoint WMA30 Front Load Washer
Hotpoint wma30 can hear water going into drawer but it's going out into waste and not staying the drum,the machine has been on it's side
This is most likely due to having the height of the drain hose too low in the drain pipe so the water siphons out as the machine tries to fill up. This will eventually lead to an error displaying saying that the machine was not able to fill with enough water in the 6 minutes allowed by the on board controller in the Whirlpool.
The solution is to measure the height of the top of the arch of the drain hose or direct connecting point to a drain and make sure that his is at least 32 inches and no mort than 36 inches from the floor.
Oct 11, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
Ashing machine not emptying
check the drain pipe is not blocked, to empty the machine manualy get a bowl on the floor and lower the drain pipe into it and fill to stop water flow lift pipe up in air and lower to start draining again when empty if pipe not blocked i would suggest a new pump located under the drum and easy to fit
Feb 05, 2009 | Hotpoint WMA46 Front Load Washer
Hotpoint aquarius ultima 1000, when wash cycle is comple the rinse cycle wont start and displays message check outlet pipe which i have done but it seems to be clear as i can syphon water from the machine...
It sounds as though the pump is not draining the water out.
If you have checked outlet pipe and it is clear, then you need to check the filter, if there is no filter at front of m/c, then remove the rear panel, and unfasten the large black hose that goes to bottom of drum, remove filter and clean, check pump at same time.
Watch out for water from the drum.
Refit filter and hose and test.
Plz rate my suggested solution, and feel free to leave a comment.
Thankyou.
Jan 21, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint ultima wma75
sounds like the filter is blocked you can take the filter out and clean it and check the hole for lint a sock or a coin etc. if this helps please rate me joe
Aug 06, 2008 | Hotpoint First Edition WMA12 Front Load...
Hotpoint wf860 - H2O Error Code - Machine is asking for water but draining it straight out
Check that your outlet pipe rises above the stated height on the back of the machine (about 3/4 of the way up). If it is too low, it will siphon the water out of the drum. If you're not sure what height it should be at, raise the top of the pipe (ie where it bends back into the outflow pipe) above the top of the machine (if you have room) or as high as you can. It must be above the height of the drum.
Good Luck
Jan 06, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WMA30 Front Load Washer Logo
265 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
