Samsung b1445s washing machine
Please help.I can't get a new belt put on this machine as the back doesn't come off the machine. I can only access from the top by taking the lid off and although I could get the belt on this way, the belt is too tight. I need to get into it to loosen any bolts or anything.Any advice would be a big help
thanks
Alidea
HELLO
HAD THE SAME PROBLEM LAST WEEKEND! THE BELT HAS TO BE SO TIGHT TO GET THE WORK DONE
PUT THE BELT ON THE BUTTOM SMALL WHEEL OF THE MOTOR THEN YOU VERY SLOWLY PUT IT ON THE BIG WHEEL BY TURNING SIMOULTANISLY THE BIG WHEEL CLOCKWISE, IT SHOULD I YOU ARE CAREFULL POP_UP AFTER A SEMI TURN,THAN SLOWLY TURN WITH YOUR HANDS THE WEEL 2 OR 3 TIMES AROUND SO THE BELT CAN FIND ITS PLACE;
hOPE YOU GET IT DONE
GREETS FROM bELGIUM
MY MAIL [email protected]
Posted on Jan 05, 2009
SOURCE:
Whcandy washing machine grand go f 662 stops mid cycle and the cold wash light flashes and the softener isnt usedat's your problem?
Hello.
Washing machines, like any other mechanical device, occasionally needs servicing. A common problem with an older washing machine is that the spinner, or agitator, drain,or stops rotating during wash cycles. Fortunately, most washing machine problems are easy to troubleshoot. Any do-it-your self offer can fix it; here's how.
TOOLS NEEDED TO SOLVE PROBLEM ARE BELOW.
Bucket and rags,Screwdriver,
New drive belt (if necessary),
New drive motor (if necessary).
1 Unplug the washing machine, and turn off the water supply to the machine. If necessary, remove the water hoses from the back of the washing machine because they may be in the way of the access panel.
2 Check that the agitator is seated correctly by opening the lid of the washing machine. If it's loose, pop off the top of the agitator--if there is one--and tighten the bolt that holds the agitator in place. Or, in some models, simply pull straight up and then reseat the agitator.
3 Remove the access panel located in the back of the washing machine by unscrewing the screws holding it in place. This allows access to the drive motor.
4 Press on the drive belt that works the agitator. If the belt moves more than 3/4 inch, tighten the belt to fix the spinner problem. If the belt is worn or cracked, replace the belt.
5 Replace the drive motor, if tightening or replacing the drive belt doesn't fix the agitator. Purchase a new drive motor at a wholesale retailer. Disconnect wiring, remove screws holding motor in place and insert new motor. Screw into place, and connect wiring.
6 Check for any black substance leaking under the washing machine. This might indicate a clutch problem, if the washing machine spinner is not working. Contact a professional repairman to replace the clutch.
Thanks.
Nov 08, 2011 | Washing Machines
Candy washing machine grand go f 662 stops mid cycle and the cold wash light flashes and the softener isnt used
Hello.
Washing machines, like any other mechanical device, occasionally needs servicing. A common problem with an older washing machine is that the spinner, or agitator, drain,or stops rotating during wash cycles. Fortunately, most washing machine problems are easy to troubleshoot. Any do-it-your selfer can fix it; here's how.
TOOLS NEEDE TO SOLVE PROBLEM ARE BELOW.
2 Check that the agitator is seated correctly by opening the lid of the washing machine. If it's loose, pop off the top of the agitator--if there is one--and tighten the bolt that holds the agitator in place. Or, in some models, simply pull straight up and then reset the agitator.
Thanks.
Bottom rotor is not working
Hello.
Washing machines, like any other mechanical device, occasionally needs servicing. A common problem with an older washing machine is that the spinner, or agitator, stops rotating during wash cycles. Fortunately, most washing machine problems are easy to troubleshoot. Any do-it-yourselfer can fix it; here's how.
Bucket and rags,Screwdriver,New drive belt (if necessary),New drive motor (if necessary)
Thanks.
Drain line clogged on Whirlpool model ET1CHMXKB09. How do I access the drain line?
Hello.
Washing machines, like any other mechanical device, occasionally needs servicing. A common problem with most old washing machine is that the spinner, or agitator, drain,or stops rotating during wash cycles. Fortunately, most washing machine problems are easy to troubleshoot. Any do-it-your self offer can fix it; here's how.
Thanks.
Oct 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a brand new front loader and the drum is not turning during the cycle....it turns freely if I do it by hand
If you hear the motor running and the console doesn't put out an error code during the cycle, it sounds like your drive belt may have come off the motor / drum pulley. You should be able to access it by removing the back panel. Be careful- and unplug the machine first.
Good luck.
May 14, 2011 | Bosch Washing Machines
I was trying to clean the washer and i took out the Augger and can't figure how to put it back together.
by auger do you mean the agitator here is a schematic of your machine of how the agiator installs into the machine if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in the future with similar situations
here is your schematic http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fM0606007-00007.png
Thanks Rick
Feb 03, 2011 | Maytag PAV2300 Top Load Washer
Need to change driving belt?
Disconnect the Washing machine power cord from the wall.
lay over the washing machine carefully towards the washing machine door and prop up securely or put up on blocks so you can get adequate access to replace belt, there is no access from the back, you will have to get access from underneath. be carefull.
There is a bolt that needs slacking off so you can get the new belt on (adjustment - Tensioned) this is usually on the electric motor, do not completely remove, only slacken to give adequate room to put new belt on. once you have the new belt on, take up the slack and tighten the bolt. do not over tighten the belt, allow the belt when on to move sideways about one finger width.
Nov 03, 2010 | Whirlpool Washing Machines
How to replace the belt on a Samsung J845 front loader washing machine
Its on the back of machine and after you remove the back cover plate youll see that its very easy to install the new one.You shouldnt have to use any tools to put on the new belt.Just loop it around the motor pulley and around the large tub pulley that you see right in front of you.It may even appear to be too tight while your winding it on the pulleys but its not .
May 20, 2008 | Washing Machines
How to get back off to put belt on samsung b1445s washing machine
See if the motor has adjustment , ie a slotted fixing hole, slacken the fixing bolts slightly and motor may move up and down to give adjustment, put the belt on and then put some tension on the belt once fitted by moving the motor down and tightening the motor bolts at the same time.
Or if no adjustment put the belt on the motor spindle first and then the drum by turning the drum as the belt is eased onto it.
Apr 08, 2008 | Washing Machines
Washing Machines Logo
199 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
