Machine agitates and starts to spin, after about 30 seconds you can hear a tiny click and then it cuts out, there is a very mild burning smell. If you turn to refill the machine it does this okay. If you wait a while and turn the machine back on it spins again but then cuts out as before.
    Brigadier General:
  • 3,917 Answers
Thanks for contacting Fixya.com
It sounds like you may be having problems with the motor. It may be overheating or it could be as simple as a bad wire (judging from the burnt smell ).
Get a good look at the motor. Unscrew the screws on the console. They'll be on each end, either on the front or back depending on age. Rotated the console forward and up to lift it. Pop out the clips on each side of the top (under the console) with a screw driver. Disconnect the lid switch harness. Now you can tilt the cabinet forward and remove it.
Take a look at the wire harness on the motor to see if there are any bad wires.
Take the water pump off the front of the motor to see if anything is caught inside.
See if the motor turns freely.
Let us know if you have something more to know else please accept the suggestion.
Thank You.
Posted on May 31, 2010
  • 1 more comment
  • johnrmiller May 31, 2010
    Thank you for responding, our findings are:
    The magnets are hot on the motor.
    The motor spins freely.
    We are not sure what to do next; any other suggestions?
    Cheers, John
    Cheers, John
    We have done everything you have said; please see our earlier response. Are you able to give any more guidance as to what is happening please? John
Maytag legacy series washer
The drive motor which spins the drum is connected to the drum by a rubber belt. Sounds like the belt is burned through. Make sure you can spin the inside tub by hand to verify that the tub can turn freely before you replace the belt. The hum is from the drive motor just spinning freely.
Sep 02, 2016 | Maytag Legacy Series Top Load Washer
Washing machine has smell (burning) and doesnt spin or drain tub.
Sounds like the belt may need to be changed. it eh pulley are spinning but the belt is not, nothing will spin and the friction of the pulley against the belt will cause a burning rubber smell
Nov 27, 2013 | Washing Machines
Admiral washer model AW20N2V making a clicking sound...
call manufacturer. heard there was a recall... for dangers of fire.
Oct 02, 2012 | Admiral Washer Control Panel Frame 35-5733...
Maytag Performa PAV920AWW makes squeeling sound when agitating/spinning. Water does not drain completely during spin.
Sounds like brake is partially engaged. There is s kit that may fix that. Part # 12002213.
Sep 19, 2017 | Washing Machines
When washer gets to spin cycle it will spin for 3 second then cut off, A few minutes later I hear a click inside the washing machine and it will try again
If there is smell that keeps on increasing then you must shut down the washer and remove power. Check on the motor , the capacitor to the motor and the main control panel. Since smell was noticed there can be ccomponents and so take care not to burn you fingers when you touch any part. Once this is identified you can remove and repace. if the heat was noticed on the motor,check for free movement of the spindle or it can be due to possible heavy load. Also check for inlet and drain valve pump to be faulty and have burning off the coils.
Nov 05, 2011 | Amana DLW330RA Top Load Washer
Maytag Atlantis Model 8551AWW washing machine...fills up with water...then starts the agitation cycle and will agitate for about 1 minute...then shuts off...after about five minutes the agitation cycle...
Unplug the washing machine, and turn off the water supply to the machine. If necessary, remove the water hoses from the back of the washing machine because they may be in the way of the access panel.
Check that the agitator is seated correctly by opening the lid of the washing machine. If it's loose, pop off the top of the agitator--if there is one--and tighten the bolt that holds the agitator in place. Or, in some models, simply pull straight up and then reseat the agitator.
Remove the access panel located in the back of the washing machine by unscrewing the screws holding it in place. This allows access to the drive motor.
Press on the drive belt that works the agitator. If the belt moves more than 3/4 inch, tighten the belt to fix the spinner problem. If the belt is worn or cracked, replace the belt.
5
Replace the drive motor, if tightening or replacing the drive belt doesn't fix the agitator. Purchase a new drive motor at a wholesale retailer. Disconnect wiring, remove screws holding motor in place and insert new motor. Screw into place, and connect wiring.
6
Check for any black substance leaking under the washing machine. This might indicate a clutch problem, if the washing machine spinner is not working. Contact a professional repairman to replace the clutch.
Read more: How to Fix Washing Machine Spinner ' eHow.com http://www.ehow.com/how_2092465_fix-washing-machine-spinner.html#ixzz2JXhQRhyW
Feb 03, 2011 | Maytag Atlantis MAV8551 Top Load Washer
I have a maytag hav3460aww and it has a strong electrical smell
Seized or faulty motor or perhaps a a control board/timer problem.
Sep 25, 2017 | Maytag Washing Machines
1 yr machine. Won't spin but has burning smell
The reason to this problem can be due to the
brake rotor.It need's to be replaced.
Sep 01, 2009 | Maytag Centennial MVWC500V Washer
GE Wizard Top-Load Washer - Burning Smell
sounds like an over heated motor. motors tend to do that before finially hitting a brick wall. please e-mail me for any other assistance. good luck :)
Jul 07, 2009 | Washing Machines
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
