Question about Troy-Bilt Pony Garden Tiller
Troy bilt pony tiller will only work in reverse not forward how do I fix it I may have hit a rock because it stopped all of a sudden and I cleaned the tines and around them already
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 221 Answers
These kinds of problems almost always require opening and inspecting the gearbox. Hopefully if you can do this is will be something simple you can repair. Good luck.
Posted on Jul 01, 2010
Pony size Troy-Bilt 30 years old\r\nQuestion; Can motor be replaced?
Yes but unless you purchase a engine with the two shafts, one for forward and one for reverse, you will lose your reverse. If you don't mind not having a reverse just go to a nearby Harbor Freight store or order on line a Greyhound 6.5 HP engine. these are Honda clones and run great they just had a sale here in Columbia Mo. and it was on sale for $99.99. I have used these on many of the Troy Bilt Horse tillers and they work great. They have metric threads and you may not be able to use your throttle cable but for the price you can't beat it.
Frank
Oct 03, 2010 | Troy-Bilt Pony Garden Tiller
1980 pony rear tine tiller: when I put it into gear it just sits there and will suddenly lurch ahead uncontrollably.
That will happen when the tines are engaged while the wheels are in Neutral as the tines simply drive the whole machine forward without the drag of the wheels being in gear. If the wheel transmission is engaged and this is still happening, then you have need for repair.
farmerbear at FixYa.com
Sep 22, 2010 | Troy-Bilt Pony Garden Tiller
Reverse belt or transmission won't lock into place
The reverse on the Pony tiller will not lock. You pull back on the reverse lever and as soon as you let go it will stop. This is normal operation for reverse.
Frank
Aug 30, 2010 | Troy-Bilt Pony Garden Tiller
My 2008 Troy Bilt Pony lawn tractor will not engage in iether forward or reverse. No clear reason just stopped working. The transmission locks up and the tract or will not start either (probably because it...
Make sure the brake pedal is fully depressing. Check the linkages for the forward / reverse and brake pedal. Check for grass build up causing the linkages to bind.
Nov 26, 2017 | Garden
Troy-bilt tiller
The only way to roll around is to remove the pins on the axle and slide the wheels in and replace the pins. If this has never been done sometime its rather hard to do. Hope this will help
Apr 25, 2010 | Troy-Bilt Pony Garden Tiller
When going forward the tines are going in reverse
I've never seen one of these so excuse my ignorance. Is it possible that the cable to change from forward to reverse is out of adjustment? Can you go to where the cable attaches to the shifting mechanism, detach it and manually try to change from reverse to forward? Hope this helps. Good luck!
Mar 13, 2010 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
I just bought a used Pony tiller. It runs good, but after tilling for a couple no hours the forward and tines just stopped. Had not hit anything. It goes in reverse and the tines work in reverse, but I...
Check under the metal or plastic cover just behind the engine. This covers the forward and reverse belts. Your belt either broke, jumped off fthe pulley, or needs a tension adjustment.
Frank
Jul 04, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Tiller will not till in forward motion.
sounds like your drive belt is worn or the handle bar adjustment is too tall and your handle is not adjusted.
Apr 26, 2009 | Troy-Bilt Pony Garden Tiller
Troy-Bilt Pony Garden Tiller Logo
289 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Jim Parker
Jim Parker
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
