ON NEC colour Television FS-59V81 trying to retune channels. in the install sub-menu, the confirm (''Ok-Access'') does not show up as a choice down the bottom of the install sub-menu, just the position or exit options.
  • rumby371 Jun 13, 2010
    On a NEC colour Television FS-58V81 trying to retune channels. From the main menu, when I select, the ?Install? sub-menu, the confirm (''Ok-Access'') does not show up as a choice down the bottom of the install sub-menu, just the position or exit options. Have read through the Instruction manual and can?t see why can?t select the install sub-menu. Have trying tuning TV off at the power for an hour or so, removing batteries from the remote. But does seems to help. Still can't access the install sub-menu. The "OK " just doesn't become available down the bottom when trying to select the install sub-menu.
  • 12,061 Answers
Hi OK, first, unplug the set from the wall poser, and leave off for a while, 5-10 mins, then reconnect. This may re-set your set's tuning, and return functionality. However, If this doesn't work, then please find below your service and repair manual. You may need to "Hard" reset the TV, to "Factory Default Settings" and, you may also possibly even have to access the service menu, to put the set back, to "Factory" state. Please use the troubleshooting steps, this should help you re-tune your set. Now if you still cannot, get it to work, after resetting it. Them you can then use the manual to isolate the actual problem, and hopefully repair. The fault could be in one of a few places.
It, may also be caused, by a "Glitch" in the software, or perhaps, the memory where the settings are stored has gone faulty, and thus, the set cannot, "Save" the/any settings. I have seen this type of thing before it is not common though. It may even be the tuner itself, one would have to troubleshoot to isolate the problem.
Below, is your service manual. http://load2.givemefile.net/download.php?id=1377395
OF course if it does prove to be a "Fault"then really, in my professional opinion, you should contact a local or head office of you TV's manufacturer, and ask for a referral, to an Authorised service Center, here you will always get the best, service, as they only work, on this brand, have parts on hand, original parts too. Also one can aks for a "Quote" as to the cost of the repair, and then you can make an informed decision, as to repair or replace, as often, I find, that, often seemingly minor "Symptoms" can result in an uneconomic repair.
Posted on Jun 13, 2010
  • rumby371 Jun 14, 2010
    Tried turning TV off etc, no change. Then tried to download service and repair manual, does the address " http://load2.givemefile.net/download.php...
    " need to have "www" at the start or somewhere???
  • 666 Answers
You will want to look through your owners manual for a means to restore the television to its factory default setting sometimes its available through the tv menu other times it involves holding a few buttons on startup
hope this helps
Robb
Posted on Jun 11, 2010
  • rumby371 Jun 11, 2010
    Have read through instruction manual, doesn't say anything about how to reset factory settings
    Robb, the model is actually FS-68V81 if that makes any difference. Have trying tuning TV off at the power for an hour or so, removing batteries from the remote. But does seems to help. still can't access the install sub-menu. The "OK " just doesn't become available.
I just bought a 32bv701b. When doing auto scan no digital channels appear. My previous TV received them all fine. Help!
Do a retune to this TV.
Press MENU button on the remote control and select
Install and Retune by using Left or Right button.
Press OK button and the following menu screen
will be displayed
Select Automatic Channel Scan (Retune) by using
Up or Down button and press OK button. Automatic
Channel Scan options will be displayed. You can select
options by using Up or Down and OK buttons.
Auto Channel Scan Menu Operation
Digital: Searches and stores aerial DVB stations.
Analogue: Searches and stores analogue stations.
Full: Searches and stores both analogue and aerial
DVB stations.
Whenever you select an automatic search type and
press OK button, a confi rmation screen will appear
on the screen. To start installation process, select
Yes, to cancel select No by using Left or Right
and OK button.
After auto channel scan type is set and selected
and confi rmed, installation process will start and
progress bar will move along. Press MENU button
to cancel process. In such a case, located channels
are not stored. The television will start to search for
all available stations. You must allow the television
to complete the search.
Jun 13, 2012 | Panasonic Televison & Video
Retune channel every day
when you tuned after that try to exit menu by using remote press ok from remote.
by pressing ok it will save in memory .
Nov 14, 2011 | Sony BRAVIA KDL-40V3000 Television
TELEVISION
Samsung tellys top level menus should have a choice of four or five sub-menus.
The one you want is that represented by a picture of a satelite dish / antenna. Dont worry if you dont get your TV via satelite, this is just the symbol they use to denote the tuning options.
Down arrow to the satelite dish sub-option and select enter. This should then give you several more options, one of which is Tuning, Select this and then select Auto Tune, then press enter and the set will completely retune itself.
If youre asking this as a result of yesterday's Freeview retune, then you may well end up with some "dummy" channels - i.e. they either have nothing at all displayed or a message telling you the channel has moved - or some of the channels have an incorrect name. I'm hoping that now the retune has happened, in the near future these dummys or errors will be fixed.
Some Samsung TV's dont have a "tuning" sub-menu but "Channel(s)". Selecting this will then give the Auto Tune option.
Oct 01, 2009 | Televison & Video
Samsung le26r74bd won't retune digital channels
Updating the Channel List Automatically You can update the channel list when the broadcaster adds new Services or if you move the TV to a new location.
1. Press the MENU button to display the menu. Press the ▲ or ▼ button to select "Digital Menu", then press the ENTER button.
2. Press the ▲ or ▼ button to select "Channel", then press the ENTER button.
3. Press the ENTER button again, to select "Country".
4. Select the appropriate country by pressing the ▲ or ▼ button. Press the ENTER button to confirm your choice. Even though you have changed the country setting in this menu, the country setting for Analogue TV is not changed. (Refer to page 11 of the user guide)
5. Press the ▲ or ▼ button again, to select "Auto Store". Press the ENTER button. When it has finished, the number of scanned services will be displayed. The existing favourite channel list will not be deleted when the channel list is updated. To stop the scan before it has finished, press the ENTER button with "STOP" selected.
6. Press the EXIT button to exit. If the signal status is poor, the "No Service found! Check the aerial connection" message is displayed. Check the aerial connection and the try the procedure again
Sep 30, 2009 | Samsung LE26R74BDX 26 in. HD-Ready LCD...
Can not get menu option for retuning
If youre asking this as a result of today's Freeview retune, then you may well end up with some "dummy" channels - i.e. they either have nothing at all displayed or a message telling you the channel has moved - or some of the channels have an incorrect name. I'm hoping that now the retune has happened, in the near future these dummys or errors will be fixed.
Sep 30, 2009 | Samsung LN-S3251D 32 in. LCD HDTV
SAMSUNG LE32R73BDX/XEU TV Digital TV Stuck on bbc1, no access to DTV menu to reset or retune. Sometimes picture is frozen, always it shows BBC banner and Mono. Standby - Info - menu - Mute - Power is not...
just spoke to Samsung support and it turns out that the freeview tuner had froze and needed resetting. To do this put TV on standby and then push in series these buttons on the remote: 'info, menu, mute, power' the TV will then turn itself on and display a menu. Press the 'down arrow' untill you've highlighted option 12 - 'reset' and then press the 'right arrow' to enter the option. TV will turn off and when you turn back on it will start in 'plug & play' mode as if new. Set the time and country options and then it will perform a complete scan. I've just retuned mine and all back to normal. Hoorah!!!! :-)
Sep 27, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Digital channels have stopped working, only blue screen!
Try resetting the TV:
  1. Switch on TV and switch to any analogue channel.
  2. On the TV: Press and hold the MENU button.
  3. Menu screen will appear on the display.
  4. Do not release the MENU until the menu screen disappears.
  5. TV will go blank for about 60 seconds and then display initial set up screen.
  6. Follow the on-screen prompts to re-tune the TV.
If this does not work then the problem is likely to be a loose ribbon cable or main small signals board inside the TV.
May 17, 2009 | Philips 37PFL5332D 37 in. LCD Television
Retuning digital TV
You need to use the (what looks like a large sattellite) button to retune your tv.
Some Samsung tv's let you access the button but other models have a "D MENU" button on the remote. Press this button, then scroll down to the icon that looks like a large sattellite. Then scroll across and click on "Auto Store" this will then go through all the available channels
Mar 26, 2009 | Samsung LE32R41BD 32 in. HD-Ready LCD...
NEC fs 5197 tv blank screen
I cannot assist but do you please have an owners manual for the FS 5197. I'm not sure if its against this sites "rules" but little fingers have tuned the menu's instructions into Arabic. Contact me directly at factotum.inter.alia@gmail.com. Thanks
Feb 10, 2008 | NEC-Mitsubishi AccuSync LCD72V 17" LCD...
Televison & Video Logo
194 people viewed this question
Top Televison & Video Experts
Electro Med Services...
