Question about Krups Small Appliances Espresso Machine
KRUPS XP7240 leaking water
When I make coffee, the process starts out as normal, but after some seconds, water starts to flow out from a opening under the "drip bowl". I have folowed all the cleaning routines and programs. The XP7240 was bought 22/5 2008.
  • 4 Answers
My XP7240 has the same problem. I went through all cleaning cycles and the filter in the boiler still gets clogged up with coffee oils. This causes back pressure and blows the boiler seal out. Easy replacement if you can turn a screw driver.
Part number for Seal: MS-5015004. You might as well change the Jack too. (the part that slides into the boiler that compresses the ground coffee. (this is a redesigned double seal unit) Part Number MS-0697072.
Both these parts you can get at http://www.krups.com/Tools/Contact/Contact.htm choose your country and email the parts list. Mine cost in Australia $27.00 including shipping.
Good luck.
Posted on Sep 16, 2010
  • 17 Answers
Your pressure valve is blocked which can be easyy cleaned. You need to open the machine and remove the valve. See the other posts about leaking water. These explains how to open the machine and clean the valve.
Posted on Aug 14, 2010
  • 2 more comments
  • jon9621 Sep 16, 2010
    Both these parts you can get athttp://www.krups.com/Tools/Contact/Conta... choose your country and email the parts list. Mine cost in Australia $27.00 including shipping.
    Good luck.
  • paul_on_trav Oct 18, 2010
    The importer SGB sells the seal for $2.99 (pick up)
    Unit 1/10 Hills Road, Home Bush
  • Paul Jun 15, 2011
    Paul, can you explain to folks where the pressure relief valve is?
  • paul_on_trav Jun 15, 2011
    99% sure that it is the seal since that seems the weakest part in the design. Every machine seems to fail. The pressure valve is a little white round container screwed on (bajonet connection) the distributor. It contains a spring and a small plastic part. Sometimes coffee builds up in it.
The frother doesn't work on my 2nd hand Krups XP2070
The frother usually has a rubber tip. The rubber tip normally has an additional pipe right next to the frother. The pipe's black plastic tip has a very small hole in it. This can get clogged and the frother will not work. Take a pin/needle and unclog this very small hole. The pipe itself can be plugged with milk residue and will need cleaning.
If you take the strainer cup and hold it up to a light, you can see if all the holes are open. If not, this will slow down the brewing process and create a LOT of back pressure which can force the water to flow out through the sides above the strainer cup. Take a needle and open each hole of the strainer cup.
When grinding your own beans, try not to process the coffee too fine or it starts to fit into the holes of the strainer cup. This can also slow down the brewing process. If you grind a batch too fine, you can sometimes get a way with mixing it with a batch of coarse or under-ground beans.
Mar 20, 2014 | Krups XP2070 10 cup Coffee Maker/15 bar...
Problem with Krups XP7240
The hose connected to the heating element has unattached or is leaking.
Sep 03, 2017 | Krups Small Appliances Espresso Machine
I had some water problems with mij krups and try to solve it. Now it gives an error 0D. What does this mean?
I have a Krups XP7240 that came with the same error code (0d). I believe that the XP7240 and the XP7245 is pretty much identical inside. The sollution for me was that the connector to the front was loose. After pressing down on the connector, the machine worked perfectly again.
RuneBune
Feb 11, 2011 | Krups XP7245
Water leaking from the bottom of the XP7225. I empty the cup holder after every two or three uses - no luck. Any idea?
it is a common issue. See the posts for xp7240. The seal within the plunger is worn or dirty or the valve is sticky. Posted both instructions on other posts.
Aug 13, 2010 | Krups XP7225 Espresso Machine
I have a problem with my Krups XP7240, it is
You can just removed the water tank filter (the cylinder inside the water tank) and washed it up. (Actually the filter should probably be replaced). Fix it back in the water tank and tide it safety upon the exit ring.
Don't forget to unplug the machine BEFORE doing this.
Next, restart the machine and let it perform the automatic self testing.
May 10, 2010 | Krups Small Appliances Espresso Machine
My xp7240 has also started leaking water from beneath the machine
the distribuitor as down!
its dificult to substitute. maybe find an expert its a good option for this case.
Jul 02, 2009 | Krups Small Appliances Espresso Machine
Krups xp7230, no water running through nozzles
Yes, you're machine is identical to the xp7240. Look up the post on leaking xp7240 and follow the instructions on how to open the machine and fix the valve.
Jan 06, 2009 | Krups XP7230 Compact Super Automatic...
I have a 12 month old KRUPS XP7240 coffee maker. It has just ceased to grind the beans. I suspect that the grinder or hopper to the grinder is blocked? Any suggestions how it might be...
You need to open the machine which is easy see my other post on leaking krups xp7240. The grinder can be taken out by removing two torix screws. Probably the electical brushes are gone. Take the grinder engine to a repair shop where they replace them.
May 19, 2008 | Krups XP2070 10 cup Coffee Maker/15 bar...
Krups Small Appliances Espresso Machine Logo
5,019 people viewed this question
Top Krups Coffee Makers & Espresso Machines Experts
cyfred
Level 1 Expert
Ross Keen
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
