Question about Seagate Barracuda 7200.9 (ST3250824A) 250 GB Hard Drive
Blinking red/green light
The hard drive is plugged in and connected to the PC but when switched on, theLED is blinking red/green and making a clicking sound (like a car indicator). I am a complete computer novice so it may be something really obvious but its baffling me and I am totally confused what this means. I want to repair it if possible as it stores all of my photos and music.
Any help would be greatly appreciated!! Thanks.
  • 11,800 Answers
Sorry to tell you but the clinking sound is the reading head trying and failing to access the data - your hard disk is dead, all the data on it is lost.
If you trully can't afford to lose that data there are companies that specialize in extracting data from damaged disks - but it will be extremely expensive, around $1000, and they will not be able to recover all .
Posted on May 31, 2010
Beeps red light hp pc
The blinking should be in a pattern.
Power Green On (S0) Computer on
Power Green 1 blink every 2 seconds (S1) Suspend Mode
Power Green 1 blink every 2 seconds (S3) Suspend to RAM
Power Green Off (S4) Suspend to Disk (if applicable)
Power Clear Off (S5) Computer off
Power Red 1 blink followed by 2-second
pause - Repeat
Power Supply failure
Power Red* 2 blinks 1 second apart CPU thermal shutdown
Power Red* 3 blinks 1 second apart CPU not installed
Power Red* 4 blinks 1 second apart Power supply overload (crow bar)
Power Red* 5 blinks 1 second apart No memory
Power Red* 6 blinks 1 second apart No graphics
Power Red* 7 blinks 1 second apart System board failure (detected prior to video)
Power Red* 8 blinks 1 second apart Invalid ROM
Hard Drive Green Blinking Hard drive activity
*Blinking
Aug 17, 2013 | HP Computers & Internet
The green light on front of my HP computer comes on for a couple seconds and then it goes to red light blinking and beeping try to turn off and back on several times and go right back to blinking red
test all leads that attach to your hard drive including electrical extensions SATA
the leads from your (motherboard to your hard drive) make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty
even something as small as an electrical extension or a faulty fan lead can cause you problems computer needs all of the data and power to travel through every working device and to have an end for a computer to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive check all electrical extensions make sure they are securely seated even the cd/dvd drives need to have current go through make sure these devices are working
check the CPU make sure it has thermal paste and dust free secure seating
also check your computer ram modules and cmos battery make sure they are dust free and securely seated some motherboards cmos batteries are soldered in
hope it helps
Jun 04, 2012 | Computers & Internet
Windows cannot detect (find) the netcenter. blinking light. makes 4 clicking noises when started.
the clicking noise is the reader arm jumping across platters on your hard drive you have a dirty hard remove the hard drive then give the hard drive a firm tap on the side to free the reader arm
all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
ports(com&lpt)right click update driver
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again, sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
hope this helps
May 26, 2011 | Western Digital Essential NetCenter...
When i connect to my pc, the light turns on but after sometime it blinks continuously. the drive cannot be detected even in disk management
if your computer came with a motherboard disc the drivers could be on it
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
make sure the lead/s that attach to this drive have a secure seating and are not bad/faulty the light on only tells that its getting power it might not be getting enough power you might test the lead/s or
hope this helps
May 12, 2011 | Western Digital 320GB MyBook External USB...
My ps3 turned off during a game, when you try and turn it on the light on the power switch goes green for about 3 seconds then switches off again and has a red flashing light
Your PS3's problems are actually being caused by a connection error between the hard drive and motherboard. Without a correctly working hard drive connection your PS3 is unable to function and goes into shutdown mode, with the flashing red light warning.
So in order to fix the blinking red light on your PS3 you will need to repair the connection between the HDD and the motherboard.There is actually a rather simple way that you can do this yourself; while your PS3 console is switched off, locate the hard drive enclosure on the end of your console. Remove the plastic cover plate, then using a screwdriver unscrew the hard drive itself from its socket. Carefully remove it completely, then put it back in again. Tighten the holding screw, then restart your PS3
Feb 03, 2011 | Sony Playstation 3 (PS3) Console
My lacie hard drive is not spinning up. the light
if still in warrenty return to reseller for replacement but if outta warrenty open it up and try the hard drive in a pc and see if it works ok if it does u just need a replacement external caddy which can be found quite cheaply on most auction websites ;)
Mar 11, 2010 | LaCie External USB 2.0 500GB 7200 RPM 500...
Not booting, blinking light
4 blinks, 1 second apart is a power supply overload. Have the power supply replaced if you haven't added any additional hardware lately. But also make sure your hard drive isn't bad and pulling an overload of power. it's rare, but I have seem that happen on some western digital hard drives.
Jun 13, 2009 | Compaq Presario 5000 PC Desktop
Drive stopped working
I had the same problem - green light on power cord but when plugged in the green light would go off and the hard drive would do nothing. I took it into Geek Squad finally and it turned out that the problem was hard drive casing, which I had to have replaced.
Jun 07, 2009 | Western Digital 500GB ELEMENTS 500 GB USB...
Blinking lights and not recognized by computer
Try to remove the internal drive from enclosure and connect directly to PC. Does it show up this way?
Does it make any new clicking/knocking/whirring/grinding sounds like any of these: http://datacent.com/hard_drive_sounds.php ?
Nov 04, 2008 | Acomdata (HD160UE5-72) (HD160UE572) 160 GB...
Blinking red light
What laptop brand and model is it? And where is the LED that blinks? Important details! Some laptops have a power light that blinks red while battery charges, then it turns steady green when battery is full. Some laptops have a red LED that lights whenever there is hard drive, CDrom, or floppy activity (read/write). This all depends on your laptop brand/model and where the LED is (side, near floppy/CD, top near screen, or on battery itself... so provide more details for me, please!
Nov 13, 2007 | Dell Latitude C640 Notebook
Seagate Barracuda 7200.9 (ST3250824A) 250 GB Hard Drive Logo
244 people viewed this question
Top Seagate Computers & Internet Experts
Computer Links
terminalcon
John Anderson
John Anderson
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
