Question about Magimix L'Expresso Espresso Machine
My magimix coffee nespresso machine has just been descaled but still has flashing lights - how can i stop the flasing lights
Thanks Tish3030! By far the most helpful answer! The manual did not help at all. Besides, I can get the manual anywhere on the internet. :p Removing the tray worked! Genius!
Posted on Sep 15, 2014
SOURCE: After descaling le Cube two flashing buttons won't stop so can't
I had the same issue. This is what a did:
Turn off the machine
Remove the tray/container and leave it outside
Turn on the machine and this time the power button should be flashing (preheating) then hold both cup buttons for 3 sec and it will be back to normal opertion....
For some reason the sensor needs to read that the tray/container is out of the machine...
Posted on Feb 05, 2011
SOURCE: After performing a descaling cycle, the descaling light still flashes, what is wrong?
The manual states that after you descale, you have to hold down the hot water button for 6 seconds, that will turn it off and "reset the timer" till the next time it needs to descale.
Posted on Feb 02, 2009
micromatikal
  • 2777 Answers
SOURCE: I need the instructions for
It is fairly complicated, but luckily I found the manual for the device that goes into detail on exactly how to descale it. You want to go to page 8 of the manual. I will provide the manual at the end of my answer here...
Please make sure you rate my answer 4 thumbs up, it is extremely important to me. I would be forever grateful if you could do so. If you need more help on this question please just respond to my answer here and I will get right back to you.
http://www1.nespresso.com/precom/sav/pdf/HD_RO_en.pdf
Thanks
Tim
Posted on Oct 13, 2010
SOURCE: manual instruction in pdf doc
The manual can be found at the following location:
http://www.nespresso.com/precom/sav/pdf/User_manual_CLA.pdf
Posted on Apr 14, 2009
SOURCE: Flashing red light. Nespresso Citiz & milk coffee machine.
I had the same problem today. "http://www.singleservecoffee.com/archives/007209.php" talks about filling the frother above the max line, so that the whisk does not suck in air and does not pop off. I tried it and works. Make sure you close the lid properly to avoid spillage.
Posted on Feb 05, 2010
Had a nespresso magimix for xmas.orange light indicates needs descaling' surely not already'the coffee parts working but the steamer isnt'hardly used steamer. any ideas?
Pretty simple from my vantage... YOU THINK IT IS DEFECTIVE: TAKE IT BACK AND EXCHANGE IT FOR ONE THAT BEHAVES THE WAY YOU THINK IT SHOULD...
As for me I'd descale it... and consider getting a filter
Carnac the Magnificent
Feb 04, 2017 | Nespresso Coffee Makers & Espresso...
The 2 buttons keep flashing & the water won't heat up
You must re press both buttons at once again sow you will remove mashein from descaleing mode
Oct 09, 2016 | Nespresso Coffee Makers & Espresso...
1.My Nespresso Pixie Lights never stop flashing. 2. I also want to reset to factory settings because the cup portions are off. 3. I feel the water temperatures is never hot enough for the coffee
1: Depending on how long you've had your machine, it may need descaling. The machines are preset for hard water - if you're in an area with soft water, try pressing and holding the Lungo button while you turn the machine on. Hold until the lights stop flashing.
2: The Pixie can be reset to factory settings by holding both buttons down before and when you turn the machine on, again until the lights stop flashing - this will reset to factory settings.
3: The temperature is preset to be the optimum temperature for the extraction process. If, after following the above steps, the temp is still too low, call the Nespresso Club and they will advise you.
Hope this is of help to you!
Mar 18, 2015 | Nespresso Coffee Makers & Espresso...
Nespresso U - the lights keep flashing but doesn't work
have you done descaling try pressing the two buttons at the same time but keep holding them for 5 second tell me is it flashing fast or slow?
Sep 08, 2014 | Krups Nespresso U Xn250a40 Coffee Machine
Nespresso magimix
Check the relay on circuit board
Jul 20, 2014 | Nespresso Le Cube
Brand new Nespresso Inissia M105 won't heat the water
Just a brief addition, I don't have the Magimix model, but I have a similar one. It loses it's programmed settings if it is unplugged or switched off at the wall, but if you leave it plugged in but turn it off with the switch at the back it keeps the settings you have put in. It draws virtually no power when it's switched off with the switch on the machine, (I checked it with a power meter).
Just thought I'd share that with you.
May 15, 2014 | Nespresso Coffee Makers & Espresso...
Nespresso leaks coffee in capsule tray
check the gaskets or orings for cracks and replace if they look bad .perhaps a little lubricant is needed
Mar 19, 2013 | Coffee Makers & Espresso Machines
Small and large cup lights won't stop flashing
Tish3030 response worked PERFECTLY. Thank you, Tish.
Apr 19, 2010 | Nespresso Essenza C100 Espresso...
Magimix L'Expresso Espresso Machine Logo
3,991 people viewed this question
Top Magimix Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Magimix Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
