How to make a dome type retractable badge holder
  • 4 Answers
PLEASE driver robot activation key
Posted on Jun 03, 2010
How do i remove the bonnet badge on a 2001 s type jaguar
hi .. if you mean bonnet badge and not grill badge .. I'm more than 90% certain it is fixed with a self adhesive pad on the back of the badge as I've never seen holes in the bonnet for the badge, have a careful look around the edge of the badge for signs of the adhesive pad.
Jun 15, 2014 | 2000 Jaguar S-Type
Fixing a blue badge to a mobility scooter
as far as i can find there is no such thing as a blue badge mount / holder for scooters, and i wonder why you would want to do that, it would be so easy to steal, and there are many people that would steel it given the chance. by its nature it is clear to traffic wardens etc that it is a disabled transport. if you must then you could get some clear sticky back plastic and cut to size and mount.
Sep 20, 2013 | Health & Beauty
How do I make my interior lights turn off without taking out the fuse?
The trigger for light is a return GROUND which goes to all the door switches and the light dome switch. so if there is a short on the holder or on the lamp return wire this willoveride the switches and the lamp will stay lit.
So remove the dome light and check holder and return wire to switches for short.
Oct 15, 2011 | 2002 GMC Yukon XL
I need a football badge on my profile
Login to Facebook and in the search box (top right), type in Manchester United and several groups will show up.
Choose the group you like and JOIN the group... that should put their badge on your homepage.
If you are REALLY into it, you can download an mimage file of the badge by doing a google search on it. Then update your profile so your profile photo is the badge.
Hope that helps!
Jan 31, 2010 | Facebook Social Network
S-type 2000 badge removel how to do it
Gradually heat up the badge with a hair dryer which will soften the sticky material holding it on, lift the bonnet , locate the badge underside and gently push off.
Jan 18, 2010 | 2000 Jaguar S-Type
How do I change out the dome lite on my 2005 150 king ranch
For a 2005 MY F-150 :
The rear ( if SCab or SuperCrew ) there is a little notch in the lens that is used to push in a tab and lower that side, slide out from the back.
The front, non rail system is open the rear sunlgasses compartment, and grab each corner. Pull down, there is 4 or 6 spring clips that hold the overhead console to the roof. Once down, you will see the gray bulb holders. Twist out the bulb holder, and the bulb plugs into the holder. They are 2 element over sized 194 type bulbs ( think it is a 39 or 67 ??? not sure on that ).
Rail system is slightly different
Jan 04, 2010 | 1998 Ford F150 Regular Cab
How do you change the inside overhead light on a 2004 f150 supercrew?
there are two different dome lights in the supercrew one is connected to the garage door opener and sunglass holder other wise known as map lights. to get these out just simply pull the unit and the blubs unscrew from the back insert the new blubs and replace the unit. the other type depends on the model of f150 you have one is the normal dome light in witch you just pop the cover off and replace the light. the other is just like the front map light where you just pull the unit out and replace the bulbs the same way.
Dec 03, 2009 | 1985 Ford F150
My dome light fell out how do I get it to stay in?
your dome light cover is held in place by a holder.if you cant get light cover to stay up.the holder is broken.need to replace it.
Jun 04, 2009 | 1999 Oldsmobile Alero
S-Type Jaguar
Heat up the badge with a hairdryer,this softens the sticky pad holding it on, lift the bonnet and locate the underside of the badge, whilst heating slowly push the badge away from the bonnet.
Jul 21, 2008 | 2001 Jaguar S-Type
Tape holder jammed
remove the battery and use the charger - press eject button repeatedly , while plugging charger in ( if mechanism is out of alignment , will start to eject but reload immediately ) ;
Jul 11, 2007 | Panasonic NV-GS17 Mini DV Digital...
Computers & Internet Logo
116 people viewed this question
David Payne
David Payne
