Question about Goldstar WG8000 Air Conditioner
Leaks water from back
My gold star started leaking a lot of water from the back
  • 158 Answers
This is not a water leak ! it is the humidity in the room which collects as water and drains out at the back.keep a bucket underneath or attach a drain pipe to the outlet .
Posted on May 31, 2010
Fix a water leak on a 1996 Yamaha Royal Star XVZ 1300 A
You're not giving enough info to pinpoint your problem area however I have seen coolant leaks on this model from the o ring that seals a cover bolted to the top of the crankcase. It is between the cylinders, under the carb assembly. Look for white dried coolant residue in this area. It is a tedious job but can be performed with the right tools without a lot of major dissassembly. Good luck.
Nov 15, 2014 | Motorcycles
Water leaking from hose on water filter housing
shut water off to ref and try cutting the end of the tube off, but only 1/8 to 1/4 of an inch.. insert back into housing firmly and turn water back on and see if leak stopped.... if still leaking order and replace the filter housing..... hope this helps....... ken
Oct 09, 2014 | Whirlpool Gold Black-on-Black 25.4 cu. ft....
I have a 5050 btu gold star ac and it starts up and just shuts off any suggestions?
Could be very low on gas (freon leak in sytem) or could be a bad start relay.
Aug 24, 2014 | Heating & Cooling
Why my toyota camry smoke at star up
The smoke might be white, blue, or sooty black.
If white, some such vapor is normal on a cold start, but lots and lots indicated a water leak into the inlet manifold or a cylinder, probably a gasket leak. If a head gasket leak, this would cause quick overheating.
If blue,this is oil smoke from worn piston rings or worn valve stem seals. Oil can also get into the inlet manifold via a faulty PCV valve. A compression check will tell you more.
If sooty black, this is over-rich fuel mixture, and may be due to a number of things, such as a faulty temperature sender, a faulty fuel pressure regulator, or a stuck-open injector.
Jun 08, 2014 | 1993 Toyota Camry V6
Whirpool Gold refrigerator model GR2SHTXKQ01 (water leaks from dispenser. This model has freezer on top, dispenser is inside refrigerator.
Water valves leak like a leaking faucet sometimes. They just will not close all the way allowing water to bypass the valve and either drip at dispenser or drip and make a mess in freezer. Your model takes a=> 2219592 Water Valve - Dual Outlet
Change the dual water control valve and I believe this will solve this problem, Thanks Sea Breeze
Jul 11, 2012 | Whirlpool Refrigerators
Leaking everywhere
sounds like the door was sprung and is not sealing properly,check around door carefully for air leaks,miss handling causes this, did the same guys deliver the last one, just a thought
Jan 31, 2010 | Kenmore 18.3 cu. ft. Top Freezer...
Leaks in coner
you can patch the leak with some marine epoxy from any hardware store or also some weldit.
May 02, 2009 | Goldstar DH304 Dehumidifier
Freezing water in bottom of Whirlpool Gold
remove back panel inside freezer. you will see a tray at the bottom with a drain hole in the middle and this is blocked with ice. melt ice off with a hairdryer and follow up with hot water till water flows away freely
Nov 26, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Goldstar WG8000 Air Conditioner Logo
215 people viewed this question
Top Goldstar Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Dan Webster
Dan Webster
Are you a Goldstar Heating and Cooling Expert? Answer questions, earn points and help others
