Question about Epson Stylus C62 InkJet Printer
I purchased an Emachine. I have an Epson C62 Printer with parallel printer cable. I would like to connect to computer, but the Emachine does not have a parallel port. Where can I purchase a converter cable for parallel printer cable to USB?
  • Epson Master
  • 11,800 Answers
From here
http://www.newegg.com/Product/Product.aspx?Item=N82E16812156005&cm_re=parallel_to_usb-_-12-156-005-_-Product
Posted on May 31, 2010
Testimonial: "Great help and Fast too. I thought I would have to wait 'forever' for an answer. Just what I needed."
Epson TM-U220D. Parallel to USB connection. Which drivers should I install?
Hi Ali
The problem by doing this is that not all Parallel to USB cables work right out of the box with your equipment.
What you need to do first is make sure that your computer sees the device through the cable. Then when it prompts you for the drivers for the printer install the driver set (parallel) the connection should not matter at this point. However the step of the computer detecting the device first is very important.
I hope this helped.
Philipp
Apr 16, 2014 | Epson TM-U220 Matrix Printer
How can connect with computer?
plug in your usb or parallel cable from the printer to pc.. then install the driver.
Switch on the printer to see if the pc can able to detect .
May 30, 2010 | Epson Stylus Color 440 InkJet Printer
It is possible to convert the cable of lq-2180 from parallel to sb cable?
No!
Are you trying to connect your printer to a PC using the USB port?
If so, it would be far better to purchase a USB to Parallel port cable.
The data passing over the USB cable will have to converted from a serial format to a parallel format before the printed can store the data,
Next, the converted has to add the required control signals in order for the printer to read and latch the data.
Don
Apr 18, 2010 | Epson LQ-2180 Matrix Printer
Epson TM-T90 wont work with USB plug
I have the same problem...Epson does not work with a parallel to usb cable or adapter. If you still want to use this printer you will have to use the parallel port or change the interface on the printer to USB.
Nov 21, 2009 | Epson TM T90 Printer
Connect printer to PC
Dear! It is very to solve that matter use the USB converter for that solution and you can purchase a PC USB slot for that solution.
Thank You
Jul 27, 2009 | Epson LX-300 Matrix Printer
Hook Up possible for EPSON Stylus 880 to new computer w/USB ?
There is no conversion cable that you can use with parallel connector since USB transfers data in Serial mode and the parallel cable handles data in Parallel mode.
Sorry.
Mar 01, 2009 | Epson Stylus Color 760 InkJet Printer
What do i do??
did you install the installation cd given with your printer .......if you have installed then go to printer settings and make the change
Jul 03, 2008 | Epson Stylus C62 InkJet Printer
Printer instilation
you have to download the drivers from the epson website then you can install
Apr 05, 2008 | Epson Stylus C62 InkJet Printer
Epson c62 printer parallel to usb
well...those are particularly quirky. Does the epson site suggest this is possible to use? I've not seen that happen too many times, due to the mix up from parallel interface to usb...usually it takes an active converter to accomplish this.
I'm assuming your computer has no usb ports?
what operating system are you running?
Mar 25, 2008 | Epson Stylus C62 InkJet Printer
Epson c62 printer
I assume your new computer is Vista ?
You need the appropriate Vista driver
Epson or do a Google
Jan 15, 2008 | Office Equipment & Supplies
Epson Stylus C62 InkJet Printer Logo
114 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
