Question about DeLonghi CF210 Portable Air Conditioner
Noma Portable Air conditioner 12000 BTUs leaking
should not have water running out of it but it does.
There is no water run off tube with this model and so there shouldn't be any water pooling on the floor.
SOURCE: My portable air conditioner is posting a E4 on the
My air conditioner is reading E3, it is a portable Goldstar.
Posted on Aug 12, 2010
SOURCE: delonghi pinguino portable air conditioner
hose in back to much curve being restricted
Posted on May 06, 2008
  • 86 Answers
SOURCE: water leaking all over
The water leaks all over the floor instead of running into the water containner. if that is right then your condenser drain pan tubing is blocked or the pan is rusted out that cause the water leaks all over instead of running down the tubing into the water containner . You've to dismantle the panels to get into this condenser drain pan to have a good clean out . Hope this will help . God Bless.
Posted on Jul 25, 2009
james3751
  • 614 Answers
SOURCE: My air-conditioner is leaking a lot of water onto the floor.
You may jst have a stopped up draon or drain pan. If you can get to thesmall whole that it drain out of. **** it out with a shop vac. If you have one. Russ
Posted on Jul 26, 2009
blueextc3221
  • 15935 Answers
SOURCE: I have a wind chaser portable air conditioner
They make a few different 12,000btu models.
Click HERE for the manufacturer's web page to select and download your specific manual.
These error codes are not available in the manual.
Please contact them Monday through Friday, between 8:30 am - 4:30 pm PST,
Toll Free 1-800-405-2943 Inside the US
1-310-827-8615 Outside the US
Thanks for using FixYa - a Very Helpful rating is appreciated for answering your FREE question.
Posted on Jul 28, 2009
RE: IDYLIS Model #0625616 Portable Air Conditioner - what are the BTUs for this model? Thank you
Just get the tonnage and multiply by 12000 .That will give you your BTU
Jun 03, 2017 | Heating & Cooling
How much water do I need for the air conditioner
I've never seen an air condition device that needs to add water to work. Actually they RELEASE condensation water and you need to collect this water or drain it through a tube
Jul 20, 2015 | Sunpentown Spt Tn-12e Technitrend...
What is the tonnage on 48TME007-501
My guess is 4 tons. The 48 at the beginning of the model number could mean 48000 btus and with 12000 btus per ton that would mean 4 tons. Without a product name that's as good a guess as I can give. Good luck and hope this helps.
Oct 07, 2014 | Heating & Cooling
I need to know what the voltage for this unit
Model: REG-123H
  • UPC: 855326002968
  • Product Type: 12,000 BTU Window Air Conditioner & Heater
  • Product Dimensions: L: 24.00" x W: 24.00" x H: 16.00"
  • Product Weight: 88.00 lbs.
  • Product Color: White
  • Application: Used to cool individual rooms
  • Type: Window Air Conditioner
  • Warranty: 1 year; 5 years sealed system
  • Coverage Area: 550 square feet
  • Voltage: 230 volts
  • Heater: Yes
  • Air Flow: 266 CFM
  • Amps: 5.5 amps
  • Heating Capacity: 11000 BTUs
  • Frequency: 60 Hz
  • Cooling Capacity: 12000 BTUs
  • Dehumidifying Capacity: 3.6 pints
  • EER: 9.8
  • Heat Pump: No
  • Number of Fan Speeds: 3
  • Programmable Timer: Yes
  • Timer Length: 24 hour
  • Refrigerant Type: R-410A
  • Air Conditioner Type: Cool/Heat
  • Energy Star Rated: No
  • Air Filter: Yes
  • Built-In Air Purification System: No
  • Display Type: Digital
  • Remote Control: Yes
  • Adjustable Louvers: Yes
  • Adjustable Side Panels: Yes
  • Compatible Window Size: Min. Window
  • May 31, 2014 | Comfort-Aire RED-123 Air Conditioner
    Whats the tonage of this condenser
    Tons of cooling or heating are done by btus.
    So 6000 btus is 1/2 a ton,12000 btus is 1 ton.And so on.
    You need to get the total btu rating off the unit then figure it out.
    Dec 29, 2010 | Heating & Cooling
    Im just trying to find out how many btus my air conditioner is
    It says it in the model number 12000 btus or one ton enough to cool 700 to maybe a thousand feet.
    Jul 08, 2010 | Carrier XHB123D X/Y Series Heat/Cool Air...
    I want to replace a system
    Hello
    Tons of cooling is in btus.12000 btus is one ton,24000 is 2 tons.
    Somewhere on your unit is the cooling capacity in btus,take that number and divide it by 12000.
    Usually a 2000 sf house will need 3 to 4 tons of cooling,more is always good.
    Im sending a link to do an easy calculation that should be helpful.
    http://www.consumerreports.org/cro/appliances/heating-cooling-and-air/air-conditioners/sizing-worksheet/
    Jun 01, 2010 | Ruud UBHC Air Conditioner
    How many tons is my condensor with model number 10aja6001?
    Hello
    Find the btus, 6000 btu is 1 ton. So 12000 is 2 tons.
    Most home central units are 3 to 4 tons.
    May 05, 2010 | Weather King 10AJA6001AH Air Conditioner
    DeLonghi CF210 Portable Air Conditioner Logo
    1,100 people viewed this question
    Top DeLonghi Heating & Cooling Experts
    Paul Carew
    Donni Steen
    Are you a DeLonghi Heating and Cooling Expert? Answer questions, earn points and help others
