Question about Daewoo Washing Machines
Model"dwdF1021 front loader error E8 - Daewoo Washing Machines
  • rickso441 May 31, 2010
    No power board as such. Only wires (9) are to motor. Another (2) wires to waste pump
    President:
  • 1,902 Answers
The manual taped to the inside of the machine near the bottom side panel.
open the bottom access panel (3 screws on bottom front lip) and look for it as it will have the codes. near where the filter is .
while you were down there cleaning the filter did you check that the pump impellers move freely and were not clogged with any debris.
You will need to look for that manual because there are not fault codes anywhere online for this product. So that is the best advise to give you without actually knowing what is going on with your machine without more detail from you.
Posted on May 31, 2010
  • 10,515 Answers
This is a Common Problem with this Washer. There are many People who have got the same Error on these Machines.
This is a Drain related Error Code. These machines have a Speed Control Board for the Motor.If it's out it won't spin.You need to replace that Board.The Board sits under the washer tub. It is easy to replace. It has snap on harness. Set Boards side by side and swap wire harness.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Babylock rachel.... when I turn my stitch dial to 2 I get an e8 error, what does that mean my machine is brand new?
If it's brand new, take it back where you purchased it. It should be covered under store policy or warranty.
The manual usually describes error codes in the troubleshooting section. Or, you can search online:
Make + Model + the words "error code E8"
Nov 09, 2016 | Sewing Machines
My stitch indicater only goes onto E8
You didn't provide the make & model of your machine, so we can't even begin to give you a best guess.
Search the internet for:
Make + Model + error code E8
and see if comes up with anything.
Oct 25, 2016 | Sewing Machines
Washer fills and empties but doesn't agitate. Error code of 1.
Would need to know the make and model!
Sounds like the clutch may have gone if it is a top loader or the belt if a front loader.
Aug 16, 2015 | Washing Machines
Error code E8 always appear then the aircon automatically shut down
What is the make / model of your air conditioner. With out that information i cant help you with your ac repair problem. I can help if you provide this information.
Air Bulance AC Cleaning Repair Services
Apr 20, 2015 | Heating & Cooling
Error E8 HP Laserjet MP1136
See this... http://h30434.www3.hp.com/t5/Other-Printing-Questions/m1132-hp-printer-gives-me-e8-error-code-is-it-expensive-too/td-p/907661
Jul 04, 2014 | HP Office Equipment & Supplies
Samsung front loader washer Model: WF306LAW
The "3E" error code indicates that a high current is detected.
A "3E" error in a Samsung washer indicates that there is an issue with the motor. Restarting the cycle may clear the error, but a service technician should be consulted if the error code appears again.
Oct 17, 2012 | Washing Machines
E8 front loader washing machines
OVER CURRENT ERROR - Display shows 8E.IPM fault signal (this is caused by the overload of the MICOM INTO during motor action).
IPM: Integrated power module. The IPM controls the motor.
If the fault (low signal) happens to be sensed even once during the washing/rinsing stage, the motor stops immediately. However, during the dehydrating stage the signal is to be sensed, when the number of signals reads more than 6 per 500ms during the Washing or Rinsing cycle action.
If the motor stops working, in one direction ten times, "8E" Error is displayed.
During dehydrating, when the overload is sensed, the motor stops working at once and then feeds back to the initial stage of the dehydration unbalance sensing. When the feed back has occcurred twice, Error "8E" is displayed during the dehydrating unbalance sensing, No error happens by overload sensing. When it happens at more than 800rpm, the process is stopped compulsorily. Power Switch OFF can clear the overload error.
HOWEVER, the UK White goods website says:
E8
Temp too high on low temp washesNormally this will be the wash temperature thermistor or NTC that's faulty, please contact us if you need the thermistor with the model and serial number.
You can find more about your Samsung Washing Machine error codes at:
http://www.keepingupappliances.com/repair-help/appliance-repair/washing-machine-help/samsung-washing-machine-error-codes/
or
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/laundry-fault-codes/3069-samsung-washing-machine-fault-codes.html
Jun 21, 2011 | Samsung Washing Machines
Washing machine doesn't wash
E8 Means the temperature is too high. Replace the thermistor - temperature sensor, also known as NTC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 10, 2009 | Washing Machines
Daewoo Washer Error E8
Hi.
E8 is fault connection from CCU (Control board) to balancing sensor.
When you get E8, this is often because of a faulty control board.
Try first disconnecting power for a couple of minutes, to reset the appliance.
If you still get E8, then you need to call a technician. Testing is done jumping the two wires to the sensor to bypass the sensor, then replacing either sensor or control board.
If you want to arrange a repair, then you can call the phone number listed on the machine owners manual.
Regards.
Nov 22, 2008 | Washing Machines
Washing Machines Logo
176 people viewed this question
Top Daewoo Washing Machines Experts
dweatherby
Paul Bade
Are you a Daewoo Washing Machine Expert? Answer questions, earn points and help others
