Question about HP Pavilion Desktop PC
My SD card reader will not read a 4 gig card - HP Pavilion Desktop PC
  • 787 Answers
If it reads all other cards then you may want to think of replacing the card. However, more details about your problem will be helpful.
Posted on May 31, 2010
2 Suggested Answers
  • 79 Answers
SOURCE: my 9 in 1 card reader is not working
1. check whether you are inserting the sd card in the proper slot in the card reader.
2. try disconnecting and then reconnecting the card reader.
3. try any other sd card in the same reader. if it reads that the problem is with your SD card.
Posted on Aug 08, 2009
What's your problem?My husband got a Vivitar ViviCam 7028 as a rewards gift from his company and we've been busy taking lots of photos and video on it, but when I try to download the photos to my...
The first problem is explained by the error message. Your camera is consuming too much power to go through a USB hub. Try connecting it directly to a USB port on your computer, without going through a hub.
The second problem is most likely related to the card reader. You didn't specify the exact model of Belkin reader so I can't give you a definite answer, but it appears the reader is designed for SD cards. Your 4GB card is actually an SDHC card. While it fits into the slot, it will not work with devices not specifically designed to work with SDHC cards.
To sum up: If you want to use a USB port, connect directly to it without going through a hub. If you want to use a card reader, make sure the reader is SDHC-compatible.
If you have additional questions, or some part of the above isn't clear, please feel free to respond to this post.
Oct 22, 2011 | Cameras
I bought a 4 gig SanDisk Adapter micro SD, micro SDHC. my Acer Aspire will not recognize the card, i've tried the switch both ways multiple times. how can i get my PC to recognize the card?
My reader will not read mine either. I use a usb key card reader. It used to read the regular old SD cards but the new HC card format wont work. This is due to UDF differences. You can try to reformat the card but then your camera or device may not recognize it anymore. good luck
Jun 16, 2011 | SanDisk 1GB microSD Memory Card
My Acer 3692WLMi does not read my Fuji 8 gig SDHC card but it will read my Panasonic 2 gig SD card. Can someone give me an answer/solution. Thanks C
While I'm not directly familiar with this Acer model, it looks to be an older laptop. It's almost certain that it was built prior to the SDHC cards being created - a lot of older memory card readers are not able to read the High Capacity (HC) flash cards. I actually own a couple of devices that also would not read the 8GB card.
To test, I would recommend finding a newer USB SD card reader that you could either borrow or purchase (they're usually not too expensive) to see if that reader could get the information from the SDHC card.
If that works, the problem would be that your flash card reader does not support the higher volume cards. This is the most likely possibility.
If it doesn't work, there may be an actual problem with the SDHC card itself.
Hope this is helpful!
May 13, 2011 | Computers & Internet
I can not get my 51 card reader to read my 8gb mini sd card. It will read my 2.0gb card but not my 8. Help!
you might can find an update, but most of the older card readers didnt read above 2 gig
Sep 19, 2010 | Computers & Internet
Card reader not working?!
Have you tried another memory card?
Some devices can read SD but not SDHC. If your memory card is 1 or 2 gig, it's SD, if it's larger, it's SDHC which is not backwards compatible with SD.
Based on the age of the PSC 1350, I would bet it's a SD-only device.
Nov 02, 2009 | HP PSC 1350 All-In-One Thermal Printer
My acer 3680 laptop wo't read a 4 gig hc sd card
Good day sir/maam, you may need a driver for your SD card reader for vista. pop in the cd that came with your notebook to the cd drive. make sure its for Vista.
If still does not work, plug in a non HC sd, like a 1 gig SD card. if it works, then the card reader only supports non hc SD. ( I know it usually supports HC cards ) check also for viruses. there are viruses that can dissable sd card readers. just make sure your laptop is virus free.
Oct 05, 2009 | Acer Aspire 3680 Laptop
Every time i install my sandisk 4.0 gb sd hc into my computer it keeps telling me to install the card.
Check the specs on your computers card reader... Is it compatible with High Capacity SD cards? Anything over 2 gig is considered High Capacity. I'm quite sure you will find this to be your problem. Insert a 1 gig SD card and I'm sure it will read it fine.
Jul 15, 2008 | Computers & Internet
Sd micro card
it might not work because as i know the maximum external mem that you can put in sch-u740 is just 2-gig micro sd... that's why it won't work and there were times that it might shut down or turned off automatically....
Feb 26, 2008 | Samsung SCH-u740 Cellular Phone
Micro sd
i think that you should use amemory card of lower memory.
Jan 31, 2008 | LG Shine KE970 Cellular Phone
Unformatted sd card in xacti camcorder
I have one sd card HAMA 12 GB and my computer and another computer canoty read my cd card iI have so much photo and video and my computer sad o bytes. Why ? I have photo and video i don't like delete . my cd hama card is 12 gb
Sep 25, 2007 | Video Cameras
HP Pavilion Desktop PC Logo
75 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
