Question about Dishwashers
This a message for phil. The aquastop valve was not under the dishwasher. On my model, it was fitted directly onto the water inlet pipe. I replaced the valve as you suggested. After removing the old valve you could see through the clear plastic housing that water was leaking inside the valve. Anyway replaced valve but had to split wires and reconnect with connections supplied with the valve and according to instructions. Water leak has now stopped but when 'on' button is depressed and programme is selected the lights come on. Bur when door is closed machine sounds as if it is trying to start but nothing happens.
  • brian_burns Jun 07, 2010
    I just need an answer to my last message!
  • Dishwashers Master
  • 3,247 Answers
Please provide dishwasher make and model. Looks like you are retrofitting the valve to your dishwasher which may not be getting the correct supply voltage from the dishwasher control. Will need to understand part no. of the replacement valve you have used before providing any further advise.
Perhaps phil may also see this message and respond to you at some stage. Your message has been out there since 31st May.
Posted on Jun 07, 2010
  • 2 more comments
    Bosch part No. 263789 which is an Aqua Stop Valve
  • Sam Jun 07, 2010
    any chance of knowing what the make and model of the dishwasher is??
    cmmiuser01
  • brian_burns Jun 08, 2010
    Bosch model SHV43A03GB/42
  • Sam Jun 08, 2010
    Thanks for your patience. I have now been able to check out the dishwasher model that you have and how the AquaStop valve is connected.
    I can see two possibilities that could be preventing the dishwasher from operating -
    1. The electrical connections to the Aquastop valve are incorrect, causing the valve to operate and shut the water off in the normal state. How confident are you that you have the correct part from this dishwasher. Does it look like this?
    2. The flood switch inside the dishwasher has operated causing it to trigger the Aquastop valve.
    Possible solutions
    A. can you connect the water inlet hose direct to the tap and bypass the Aquastop valve? that way you can check if the the valve is the problem.
    B. if dishwasher appears OK in A, then check wire terminals in valve are ok and that it is connected in the correct direction.
    C. If results in A & B show Aquastop valve connection is ok then check if flood switch at base of dishwasher is not stuck or water has not leaked under the pump assembly. Will have to dry the base of the dishwasher - the part where motor etc are located.
    HOpe this helps solve the problem. Please post a comment to confirm what you find.
  • 19,396 Answers
Hi Brian.
Can you please state again the terms of the problem and please give us full model number. Unfortunately the Fixya system does not send the new questions always to the same expert and does not allow us to see each other solutions.
If you want to contact Phil, post an add on comment to your original post. He will receive an email notification. If you want to keep troubleshooting, please provide model number and briefly describe the problem from scrap.
Regards.
Ginko.
Posted on May 31, 2010
  • brian_burns Jun 03, 2010
    1) If the dishwasher is left overnight not in uses, water seeps slowly back into the dishwasher.
    With the door open and the 'on' button depressed, the dishwasher begins pumping away the water that's gathered. At this point the door is still open and no programme has been selected.
    I am told the water inlet valve needs replaced but on my model, the only thing I can see is a aqua stop valve.
    Spare parts suppliers quote Bosch part No. 167025 which is a Solenoid Vater Valve and Bosch part No. 263789 which is an Aqua Stop Valve
    2) On your model the aqua stop valve is the root of what is causing the leak, the check valve inside the aqua stop is reducing the pressure too far and the seat on the water inlet is bypassing due to the aqua stop.
    So to repair this order the second part you list No. 263789
    Let me know if you need more clarification
    3) The part is located under the dishwasher in the lower pan. It is between the water inlet from the house supply and the water inlet to the tank on the dishwasher.
    The dishwasher will have to be removed from the installation and the water and electrical supply to the dishwasher turned off while make the change.
    With the dishwasher out lay it down carefully, you should be able to remove the lower pan and see the component. It is not not difficult but can take a bit of time.
    Once you are done, check very good for water leaks!
    Let me know if you have questions
    4)This a message for phil. The aquastop valve was not under the dishwasher. On my model, it was fitted directly onto the water inlet pipe. I replaced the valve as you suggested. After removing the old valve you could see through the clear plastic housing that water was leaking inside the valve. Anyway replaced valve but had to split wires and reconnect with connections supplied with the valve and according to instructions. Water leak has now stopped but when 'on' button is depressed and programme is selected the lights come on. Bur when door is closed machine sounds as if it is trying to start but no water is coming into the machine in effect, nothing happens.
What does the F7 code mean for my whirlpool dishwasher ADG6230
F7 or 7 times flashing
Flow meter failure
Symptom:
Water inlet valve (WV1) is switched on and the water indicator (WI) is on (level reached).
Reason:
  • Water tap closed during water inlet
  • Water inlet hose blocked
  • Water inlet valve (WV1) defective (mesure resistor ca 3,5 kOhm)
  • Flow meter (FM) sends too few / much pulses (less than 10 imp. in 10 seconds). Flow meter counts wrong (or the sump is full in less than 30 second).
Causation: Hose felt down and slipped the disc of the valve. The effect is a displacment of the valve tapped.
  • Aquastop defective
  • Flow meter (FM) defective
Dado
Feb 17, 2015 | Whirlpool Dishwashers
AEG Favorit 44090i Dishwasher will not fill with water
There may be a filter after the aquastop pipe which is blocked. This is usually at the back of the inlet valve. Also, the inlet valve may no longer work.
Nov 07, 2014 | Dishwashers
Diplomat ADP8322 Does not appear to load sufficient water thereby spray arms not rotaing
Hello there and thank you for choosing fixya
Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it. When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need to completely replace it. Dishwasher Water Inlet Valve Replacement
Be sure to read and understand any instructions that come with the new water inlet valve.
Tools required:
Adjustable wrench
Multi-Screwdriver
Pliers
Step 1. Disconnect the dishwasher from its power source.
Note: Dishwashers are usually wired directly to the home's electrical system. To disconnect the power, switch off the circuit breaker or remove the fuse for the electrical circuit the dishwasher is attached to. Try to turn the unit on after disconnecting the power to be sure you were successful.
CAUTION: If you're not sure you've shut off the power properly, DO NOT CONTINUE. Call a qualified appliance repair technician to complete the repair.
Step 2. Turn off the water supply to the dishwasher. This is usually underneath the kitchen sink or in the basement or crawlspace near the location of the dishwasher. Pliers may be helpful here.
Note: If there are no shut-off valves, you must shut the water off at the main water supply valve for your home.
Step 3. Remove the lower panel(s) of the dishwasher. These are usually held by 2 to 4 screws at the upper and lower corners of the panel(s).
The inlet valve is usually near the front of the dishwasher. Attached to the valve you'll see: 2 or 4 wires, the water supply line from the house and the water feed line that goes to the dishwasher.
Step 4. Remove the household water supply line from the valve. The line is usually secured with a brass compression nut. The water supply line is usually copper or braided stainless steel.
CAUTION: Water supply line may be hot.
Step 5. Remove the fitting from the valve the water supply line was attached to. This fitting may be very difficult to remove. It may help to put the valve into a vice in order to remove the fitting. If you cannot remove it, replace it. The fitting is not an appliance part but a plumbing part that is available at most hardware stores.
Step 6. Remove the screws holding the valve to the dishwasher frame.
Step 7. Label the wires to the valve so you'll be sure to reattach them correctly.
Step 8. Remove the wires from the valve.
Step 9. Remove the clamp on the black rubber water discharge tube and pull the tube off of the valve.
Step 10. Reinstall the old fitting (or a replacement fitting if necessary) onto the new valve the water supply line was attached to. Use Teflon tape or pipe joint compound as a thread sealant. Make this fitting tight to prevent leaks. Make sure that the fitting points in the same direction as the old one so that the water supply line will meet up with it properly.
Step 11. Install the new valve in the reverse order of the removal instructions.
Note: The water supply line is under high pressure. Be sure to tighten the fittings properly.
Step 12. Turn on the water to the machine, and check for and correct any leaks.
Step 13. Reinstall the access panel(s). Restore the power to the dishwasher and test.
Note: You may have to let the dishwasher run a few minutes before it reaches the next water fill cycle.
Aug 04, 2011 | Dishwashers
Water keeps coming into the machine, looking for electric valves.
The solenoid valve is under the machine. It will be a block of metal installed with fittings into the water pipe and it has a plastic cylinder attached to it. The cylinder will have two wire terminals on the end opposite the valve block and is typically about 3/4" dia. x 1 1/2" long.
Jul 04, 2011 | Dishwashers
No water getting through. Has a sort of electrical box near the connector at the end of the inlet pipe. Advice please
hello
your appliance is fitted with an aquastop these are desighned to prevent the machine from filling if it detects a leak, this is probaly whats happened if you can remove the machine tip it over too one side if water comes out onto floor you will have a leak as the base holds around a pint of water.
Nov 02, 2010 | Dishwashers
My dishes are still dirty after washing
There might be may reasons. Let me provide you with all the steps :-
Water-inlet valve Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it. When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need to completely replace it. Dishwasher Water Inlet Valve Replacement
Tools required:
Adjustable wrench
Multi-Screwdriver
Pliers
Note: Dishwashers are usually wired directly to the home’s electrical system. To disconnect the power, switch off the circuit breaker or remove the fuse for the electrical circuit the dishwasher is attached to. Try to turn the unit on after disconnecting the power to be sure you were successful.
CAUTION: If you’re not sure you’ve shut off the power properly, DO NOT CONTINUE. Call a qualified appliance repair technician to complete the repair.
The inlet valve is usually near the front of the dishwasher. Attached to the valve you’ll see: 2 or 4 wires, the water supply line from the house and the water feed line that goes to the dishwasher.
Step 7. Label the wires to the valve so you’ll be sure to reattach them correctly.
Oct 14, 2009 | Zanussi Dishwashers
Upper spray arm doesn't move. Replaced inlet
Does it feel free to turn? It's water powered and works in conjunction with the water pump. Do you hear the water/booster pump come on?
Oct 04, 2009 | Frigidaire PLDB998A Built-in Dishwasher
When starting wash cycle the dishwasher cda cw447 doesnt appear to be getting enough water in and is making a droning / whirring / electrical ? noise. pipes all connected ok inc aquastop water supply unit,...
Try removing the inlet pipe, and refitting, might fix it, else likely that the
Inlet water soleniod failing/failed or tiny mesh filter (it does come out for cleaning) behind the inlet hose clogged. Temporaily bypass the aquastop water stop unit; it might be the culprit!
A replacement solenoid is usually only about £10 from www.espares.co.uk, or ebay sellers (no connection with these but they are very good), fits in minutes (2 or 3 electrical spades ,and a posidrive or two) and usually fixes all water related problems. the noise you can hear is probably the solenoid trying to actuate, will be droning/buzzing sound.
could simply be stuck with some foreign matter in there that's got through the mesh filter but unlikely. they normally fail and sound terrible.
Don't throw your dishwasher away for the sake of a £10 part.
Good luck
Sep 12, 2009 | Dishwashers
Leaves silverware dirty
Tools required:
Adjustable wrench
Multi-Screwdriver
Pliers
May 23, 2009 | Dishwashers
Zannussi de4744
Aquastop on water inlet tripped. Turn off and slightly undo main inlet hose. find water inlet valve and remove thin pipe from nipple. Turn m/c on for a few seconds, turn off and replace all pipes m/c will now fill and continue
Dec 05, 2006 | Zanussi 18 in. DE4744 Free-standing...
Dishwashers Logo
120 people viewed this question
Top Dishwashers Experts
