Question about Ovens
Hi I have a leisure cmtf94 cooker which had a lose door handle which I have now sorted. the problem i have encountered is after taking the door brackets off there is a small metal bracket that the door hinge screws fix into and this has dropped down inside the frame of the cooker. It is very difficult to line up this metal bracket as it keeps falling down any ideas please? Thanks Matt.
3 Suggested Answers
barkencoa
  • 3463 Answers
SOURCE: Belling 351 MK2AN Oven Door bracket back plate fallen inside!!
The only to do it, is to remove the side panel , and depending on the model number, you may have to remove the top also to gain access to the fixing screws.
Please rate my solution.
Thanks.
Posted on Nov 07, 2009
Testimonial: "v"
mc1bean
  • 3053 Answers
SOURCE: How do I remove the door to my Jenn-Air wall oven
Hello, marslyn
I was trying to help you out here. Maybe this will help some? I was going back to some customers that asked questions in the recent past and farther back, It appeared that no one answered some of them, So, I thought I would take some of my personal time to see if I can help. Even though this site may not have your exact model or brand, This link will help you tons. Here is a link to about everything you want to know about your oven, from repair to trouble shooting it. Even pictures and video's. Just scroll around and you will see tons of information to almost any question you might have on your Oven. If you go to this link and click around, I am sure you will find out so much about your oven, you will know more than the company that made it. The good thing about this link is, then you can make the decision of DIY or hiring a pro. Here Is the link for you to click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time to rate my help and some kind words written would be appreciated for my free help , I would appreciate it. Here is also my direct link to my own pages of other areas of my expertise for other problems you might have in Automotive,Appliance, and Electronics. Drop In anytime for my help. Thanks,Mike
http://home.howstuffworks.com/how-to-repair-an-oven.htm
Thanks,Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 28, 2011
Gas hob will not light on my leisure gas hob
At the rear of the oven is a gas cut off valve. Try twiddling it
Nov 24, 2013 | Ovens
Location of thermal fuse in leisure cookmaster range cooker
where is the thermal fuse located in a leisure cooker
Jul 22, 2010 | Ovens
Just bought a Leisure Gourmet Classic gas cooker. Connected the gas and plugged it in but none of the burners will light. The ignition is working but no gas is getting through. Any ideas folks? TIA, Andy
I had a similar problem when my new Leisure cooker was installed last December. The burners would light when I held the knobs in but when I let go the flame would go out. The engineer took off each of the burner knobs and stuck a small wad of aluminium foil between the inside of the knob and the contact on the front of the cooker - he said it's a design fault and the gap is just a bit too large for contact to be made reliably. This fixed the problem and I've had no trouble since.
Jun 22, 2010 | Ovens
I have a tecnik tkc 1255/ss range oven serial no 0704020076 COD. 0.41019xst0sq i need a replacement main oven door handle
You dont happen to have the LPG jets that were supplied with the cooker do you? I'm having trouble getting hold of any?
Thanks,
Apr 19, 2010 | Tecnik Ovens
I need a set of installation instructions for a Leisure 2100EL gas cooker
how do i uninstall a hotpoint doubl aven 27 inch wide 50 inches tall chris
Feb 03, 2010 | Ovens
I have a Beko 'Leisure alta AL6ND' oven. The thermocouple has gone in the oven (ignites but not staying lit, all other burners and grill fine). I can get the back off easily, but the thermocouple screws in...
remove rear panels (3; 1 white, 2 galvanised).
look under rear folded edge of hob. remove 2 screws in corners. dont lose 2 top hat rubber washers. from rear of cooker, lift hob slightly and push forward 1/2". lift hob off. dont over tighten new thermocouple union on back of valve (note how tight old one was)
Dec 01, 2009 | Ovens
Leisure rangemaster 55 gas cooker
It sounds exactly the same as I am experiencing on my oven of the same model. My theory is that the full flame gas is controlled by a thermostat, and that this has broken hence why the oven only stays on preheat. This will be a matter of a replacement part. Most likely the thermostat is a bi-metal strip that, because it has heated and cooled so many times in it's life it has simply finally given up. Try searching online for the correct part and get a corgi registered fitter or another suitably qualified fitter to come and replace it.
Nov 13, 2007 | Ovens
Ovens Logo
56 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
